Fix TV Remote Control Buttons
Intro: Fix TV Remote Control Buttons
Certain buttons on a TV remote can get worn out over time. In my case it was the channel up and channel down buttons. The contacts on the bottom of the button are likely worn out. This is how I fixed mine.
STEP 1: Snip a Small Piece of Wire From a Copper Wire
In the photo, the small speck in between the spool of wire and the wire cutters is the piece of wire snipped off for use.
STEP 2: Pound the Piece of Wire Into a Little Copper Disc.
With smooth faced hammer, pound the tiny piece of wire into a flat round itty bitty disc. The dot in the middle of the paper is the copper disc pounded out from the wire in the last photo. If the shape is too elongated, trim it with the wire cutters.
STEP 3: Disasemble the Remote Control
Using a screwdriver, pry the remote control apart and pull apart the pieces. The screw driver may need to be very small, such as a jewelers screwdriver. On underside of the buttons, there are conducting contact pads that can wear out. Sometimes they only need to be cleaned. This how to addresses a worn contact pad.
STEP 4: Glue the Copper Plates Over the Worn Button Contacts
In this photo I've glued small copper plates over the contact pads on the underside of two buttons that were worn. Channel up and channel down. Let the glue dry. I've found that a good strong glue is necessary. I used Gorilla Glue.
STEP 5: Put Everything Back Together and Click Away!
Happy surfing!
45 Comments
jackster-1 4 years ago
Today I had to fix my remote & came to this site in hopes of finding an easy, non-destructive way to open the units, but it seems that prying at an edge is the only way.
A nail file is a good tool for that because they are flat & thin with curved edges & are very strong.
I had forgotten that I had posted comments here 6 years ago when I first repaired this same Samsung remote using punched aluminum duct tape as originally suggested by "Passing You".
Those repairs are still effective & I just did the same repair on a couple of buttons that had never required anything before now.
kkelley5 4 years ago
rkengineer 7 years ago
I used household aluminum foil. Cut it into small pieces of sizes enough to cover the buttons. After cleaning all parts of remote, stuck these pieces to buttons with super glue (cyanoacrylate adhesive). After drying for few minutes, assembled the remote and it works wonderfully well.
ArchitS8 7 years ago
JonM134 7 years ago
2WYCE 8 years ago
jackster-1 10 years ago
In a matter of minutes I fixed the on/off button on my remote using the aluminum
duct tape/hole punch method suggested by" Passing You".
There is no bounce issue, & the operation is so smooth that there's no damage being done to the circuitry below.
Since conductivity is a key element here, one must make sure that the tape is actually metallic... there's a cheaper type on the market that is shiny, & looks like metal, but is actually plastic, and that is NOT CONDUCTIVE, so it wouldn't work in this application.
The shape of the IR lens on my remote made it easier to place the keypad & top face onto the base, but to keep the pad aligned, & from falling out of the face plate on reassembly, I'd used some masking tape, which was easily removed after snapping it back together.
finton 8 years ago
Jackster-1 said "make sure that the tape is actually metallic". Good point. Mine wasn't, as it turned out, so I used KevinM21's foil and glue instead as I had them at hand.
antiproduct 9 years ago
Difficulty: fix only with what you can find in an office.
Solution: scissors, pencil, and post-it note.
Just go into the top corner of the post-it note, use the pencil in a small area until it's completely dark (make sure you push down hard). Cut out the small part, apply the sticky side to the pad, re-assemble.
I had a presentation remote that stopped working because the button wore out. I was able to fix it with the above steps. Not sure how long the thing will stick in place, but it works for now.
finton 8 years ago
Boy, antiproduct, I hope you're a New Zealander, 'cos your Post-it note idea would go well with our "number 8 wire" philosophy! Great McGuyverism!
finton 8 years ago
Thanks so much for posting this mmelville3! I actually used the glue and foil as suggested in previous comments, but the concept works great. Now, after such a long time, and for no cost, we can finally lower the TV volume without a struggle!
stuart1972 8 years ago
Going to Give this a try as my stereo remote is 26 years old and has been playing up for some time. I had previously Fixed the power button about 15 years ago with Sellotape and tin foil.
Passing You 11 years ago
Take off the backing of the metal duct tape before cutting small pieces. With the hole punch the backing often comes off the metal tape as you can just punch through the metal. The metal tape works great. No glue involved.
KevinM21 8 years ago
I like the aluminum duct tape idea thats cool i used aluminum foil folded up but had to glue it to the button with crazy glue .
Passing You 8 years ago
Thanks. You idea is a good derivation and probably more practical for people, as people are more likely to have aluminum foil and crazy glue.
mmelville3 11 years ago
I used folded up aluminum foil and crazy glue its what i had laying around epoxy glue is better probably
NeilH3 9 years ago
Hi Gogizmodo,
Depending on the equipment in question (for most flat screen TV's) it is most likely a fault on the power supply board for the unit. The most common fault by far, is high temperatures combined with small spaces causing the electrolyte in the capacitors to dry out. This may or may not "take out" other components with it.
Neil
