Fix an Annoying Bra
Intro: Fix an Annoying Bra
This is my first attempt at publishing an i'ble. Having massive issues with it not saving and not being able toadd photos. Might be a bit brief as it's been like groundhog Day typing the same stuff... Typed loads and lost it all. Probably will update and improve plus if I do any after this they should be better!!!
STEP 1: Supplies:
STEP 2: Measure and Cut.
Measure the length of the strap at its correct length. Make sure the tape measure is taut and the strap is straight but not stretched, Asif is probably a bit elastic. Add 1.5cm to this and then cut. Remove the slidey buckle type thing and put it with wall the other small random metal/plastic items that you are keeping for no discernible reason.
STEP 3: Fold and Sew.
STEP 4: Repeat on the Other Side ☺
It helps if you make them the same... But my stitches changed
as I got in the groove.
STEP 5: Ta Daah!!
Feel smug that you have actually completed a little project, and squashed one of life's little nuisNses
2 Comments
DIY Hacks and How Tos 5 years ago
CoconutPi 5 years ago
