Introduction: Fix Broken UMD Disks
Have you ever broken your beloved UMD game and can't play it anymore? Well here's a fix to that, all you need is thin a flat-head screwdriver and superglue.
Step 1: Here's How You Do It
Now see if your UMD case is "fixable".If the case was just split in half or the clear plastic cover with "UMD" printed was pushed in, then you don't have to buy one.
If your UMD case is cracked or badly damaged, buy a replacement from here.
Note: if the case of the UMD was just split into half go directly to step 4
1.start by slowly opening the broken case, the flathead screwdriver may help.
then get the UMD out and place on a surface that is flat and smooth (NOT THE FLOOR!) printed side down.
2. for ones that the UMD plate at front messed up, just pop it back into it's original position and apply some glue on the edge where the clear plastic meets white plastic. Then put the disk in, close the case and put some glue along the side.Look at photo for description.
3. for ones that got the new case(s). open the new case, put the disk in and pop it close. You may need to apply a small amount of glue around the side to seal it.
4. for ones that case is split in half, close the case and simply apply glue around the side.
Step 2: Done!
You're done! I hope the instructable has helped fix your UMDs, any questions or comments are appreciated
5 Comments
10 years ago
My disc case is open
10 years ago
What if my disc opened
11 years ago on Introduction
what are the games used in this instructable i already know daxter. and i know it becouse my cousin has it but what are the other ones? my game disk split in half when i went to go take it out of the case.and that game is my favorite gretzky nhl 06 but any way thanks for makeing this instructable becouse i was just going to taape mine/.
13 years ago on Introduction
my UMD just split in half. the whole case split right down the seam on the side, and rattles all over. is that step four on the first page?
Reply 13 years ago on Introduction
before you glue it back together, make sure the disk WITH the metal ring in the center are aligned. Hope this helps.
