Fix Earbud Headphones With Sugru
Intro: Fix Earbud Headphones With Sugru
"Sugru" (sugru.com) is a air-drying silicone goo invented by Irish artist and businesswoman Jane ni Dhulchaointigh and a team of materials scientists.
Sugru starts out slightly sticky, like Silly Putty, but after a few hours solidifies into a harder rubbery texture which retains its shape but is still pliable. It can be used to fix any variety of things, or to "hack things better" as the Sugru motto suggests.
This instructible details how to fix the silicone rings on the earbud headphones that come with the Apple iPhone.
STEP 1: Start With Broken Earbuds
My earbuds started out in pretty bad shape. I use them for many hours every day and when driving.
The rubber rings on both sides was separating from the plastic. That's bad, because obviously it looks bad, but also because the lack of ring leaves a slight sharp edge on the surface which was beginning to irritate the inside of my ears.
Additionally, one side of the earbuds was coming apart, the two plastic parts no longer glued together.
You can see what remains of the rubber from one side in the photo.
STEP 2: Get Some Sugru
Sugru comes in a pouch of 12 sealed packets.
Each packet contains one of four colors, black, orange, green, or blue.
A single packet has far more Sugru than needed for this repair, so I did my best to seal up the rest of it to use for something else.
STEP 3: Make a Sugru "worm" and Wrap the Earbud
Pinch off a little blob of Sugru and roll it on a flat surface into a very thin "worm."
Note: Although the Sugru people say it's safe for your skin, I have sensitive skin, so I wore food-handling gloves for this step.
If you want a clean-looking repair, it's important to get the worm as uniform as possible - it should be one thickness its entire length, with no bulges.
Stick one end on the seam of the repair. Do not crush the worm yet!
Slowly and carefully stick the rest of the worm along the seam of the repair.
Some of the worm will be left over. If there is no worm left over... start over with a longer worm.
STEP 4: Cut Sugru Worm to Length
Using an "X-acto" knife or a thin box-cutter knife (scalpel maybe?) carefully cut the worm right where it meets the start of the worm where you started.
STEP 5: Smooth Sugru to Desired Contour
Now that the Sugru is evenly applied, now is your chance to sculpt it to shape. I used my fingers to crush it against the earbud.
Because the Sugru is so pliable, it's easy to mess up in this step and make an uneven repair.
Let the finished repair sit for a few hours. The Sugru will solidify and lose its tackiness.
Within 24 hours your part should be safe to use without deforming the repair.
Good luck!
Good luck!
STEP 6: Use the Rest of Your Sugru for Other Repairs
I also had a USB cable that had a hole in its insulation, so I fixed that too!
51 Comments
chimbisimo 12 years ago
Ethanal 13 years ago
musick_08 13 years ago
monkeywidget 13 years ago
thelmer44 13 years ago
A is for Anarchy 13 years ago
Specifically:
https://sugru.com/buy/
BOOM5601 13 years ago
Kiteman 13 years ago
Give Kiteman sugru now!
(Once they're in production, we should have a sugru-sponsored contest!)
DavidRobertson 13 years ago
nickodemus 13 years ago
your dog 13 years ago
lukeyj15 13 years ago
iMakeItHappen 13 years ago
