Fix or Replace Bath Tub Mixer Cartridge - Moen
Intro: Fix or Replace Bath Tub Mixer Cartridge - Moen
I have recently had a problem with my Moen mixer for the bathtub. As I searched the Internet for some insight before I attacked the faucet, I found very little in the way of images or step by step instruction. So, being a long time Maker and long time Instructables user / contributor, I thought I would fix that issue and share what I learned. In fact, I will take things an extra step and say that if you are careful, you may be able to actually fix the problem without a new cartridge.
My mixer control is shown below. You simply rotate the handle to get the right temperature. On models that require you "pull out" first and then turn to "mix" this information probably will not be as helpful.
I needed the following tools:
Allen Wrench (only for handle set screw)
Vise Grips
#2 Phillips Screwdriver
Standard Screwdriver (small)
Vise Grips
STEP 1: Safety First and Then an Ounce of Prevention
Let me just say, be careful, wear safety goggles and keep your face clear of injury.
Next, turn off your water at the main inlet to your house and release the pressure by running a faucet nearest the mixer until there is no more running water.
Now an ounce of prevention, close the drain, plug the drain or cover the drain. Losing a screw down the drain would really make this a whole new kind of job with added trips to the plumbing supply or hardware store.
STEP 2: Remove the Mixer Handle
Locate the set screw that holds the mixer handle and remove it.
STEP 3: Remove the Nylon Guides
Locate another set screw at the tip of the brass mixer spindle. Remove it and the nylon pieces that it retains. Follow through by removing the chrome or brass cover tube that keeps the internals from showing.
STEP 4: Remove Cartridge Retaining Clip
I used a small Allen wrench through the retainer clip to gently pry up and get the retainer loose. Check the photos for a clear view of what I'm trying to describe.
The retaining clip must be removed completely and set aside.
STEP 5: Pulling the Cartridge - the Hard Part
This is the hard part.
There is a lot of rubber surface area which may have grown attached to its surroundings inside the pipes. Getting the cartridge to start moving was a task. Most important, you do not want to break something inside the wall by prying or tugging too hard.
What I did:
I took the Nylon fittings and reversed the white ones so that they were longer by the length of the geared section, (back to back instead of front to back), then I placed them over the exposed spindle.
Next I placed the black Nylon piece into its original home, inserted the screw and slowly tightened. This created mechanical force between the pipe and the cartridge that literally leveraged the cartridge forward almost 0.25 of an inch.
Once the cartridge began to move, I removed the Nylon parts and set them aside again.
Now, using vice grips on the flats of the spindle I was able to pull straight out to remove the cartridge. This still took quite a bit of effort.
In the second image, you can see the cartridge almost free of the pipe.
What I did:
STEP 6: Fix or Replace
If you are replacing the cartridge, simply wipe the inside of the pipe to clean it and then use a little plumbers grease on the rubber parts of the new cartridge and reverse the steps from here.
If you want to try a fix:
The next few steps are for taking apart the cartridge and there is no guarantee this is your problem or that it will fix anything. In fact, it may just finish off the cartridge completely, but at least you will know how the darn thing works. : )
STEP 7: The Cartridge Exposed
In this image, you can see the most obvious components. Inside the mixer is a two layer moving section, one that moves specifically with the spindle and one that moves by water flow.
STEP 8: Dissasembly of the Cartridge
First, push the spindle into the cartridge so that the insides are forced out the back. Note that the rubber gaskets that separate the Hot and Cold water are all that keep this together.
Once it starts to move it should become easier to slide out.
Remove the inside section completely as shown in the second photo.
STEP 9: Remove the Plastic Retainer
Using a very small screwdriver or blade type tool, very carefully pry all around the edge of the plastic retainer. It will only come up a teeny bit before it lets go.
Set the retainer to the side.
You can now try simply dumping the last part out of this section of the cartridge since the retainer is no longer there to keep it. However, if it does not freely fall out, this may be the problem with the cartridge.
Using a flat blade screwdriver, insert the screwdriver into the end where the retainer was and gently twist the inside section to break it loose. Next, using the holes along this unit, help the inside piece to come completely out.
STEP 10: Clean Everything and Reverse the Process
OK.
If you came this far, hopefully you discovered that inner piece was stuck and causing problems. Now, you need to clean everything. You may want to soak the parts a few minutes in vinegar and then rinse with water before re-assembly. Keep in mind your water is still turned off and turning it on would be messy right now. I wiped my parts really well with a rag and was successful.
Simply reverse this whole process for re-assembly, pushing parts together and being careful not to bend, flex or otherwise do anything to break them. Applying some plumbers grease can make the re-assembly easier.
I hope this helps you as much as it helped me. : )
By the way, don't forget to double check everything and that the retaining clip is installed before you turn your water back on.
Now that you have a fully functional bath tub, get some candles and bubble bath for your valentine!
13 Comments
BradH113 5 years ago
Next, yesterday, we had another plumber come out to put in the Delta trim kit and he told us it was a Moen. He did FIX the leak but left us without a shower handle. He replaced the cartridge but had to drill the set screw out to get it off. No replacement handle.
So, today we went up to our local Home Depot and what they have for replacement handles, I guess, will not fit what we have. Right now I have the handle soaking in vinegar to see if I can get the set screw out but .. to the question:
What model number IS that trim kit pictured, or in what way can I identify what kind of Moen handle will work. Evidently, 'Posi-temp' is not what I need.
Any assistance would be greatly appreciated!
Pictured is my handle
Thanks,
Brad
MichaelS1410 6 years ago
Home Depot and others sell a repair kit #98040 called PosiTernp 1222 Cartridge Repair Kit. About $14. You get new rubber parts, the plastic that goes around the brass stem, grease and allen wrenches along with a plastic removal tool. Just finished the job. What a bee-ach getting the cartridge out. Injected vinegar and Lime-a-way toilet cleaner into the works. The plastic removal tool allows you to rotate the cart back and forth. I placed vice grips of the stem and pulled and pulled and rotated the cart. Little by little it started coming out. A lot of muscle was needed. I injected hot water and dish soap as a last resort. I finally got it out. The o-rings and pads were trash. The author of this piece fails to include the removal of the retention clip. That's the first step before trying to remove the cart. I rebuilt the brass stem with the kit, o-rings and pads, grease, and inserted the cart into the valve. I could not get the retention clip to snap in like they show on the Moen vid. Apparently I could not get the cart inserted the last mm. So I installed it all without the clip. Works like new. I would never buy a Moen again. Spend more money and get something with a ceramic cart.
Sorry he did show the removal of the clip, it just looked different than mine.
ErnestF9 6 years ago
philesra 8 years ago
Very helpful in disassembling the cartridge, thanks!
mtairymd 9 years ago
I just cleaned out my cartridge.. Thanks for the instructable!
Groundshine 11 years ago
tosenbach 13 years ago
Getting it out is a bugger, but using a pliers or vise grip will help. I screwed the main screw back into the faucet and used it to pry the cartridge out (be careful not to ruin the threads). After you get the cartridge out, take off the black rubber pieces and try to pull the inner metal rod free from the plastic holder. It didn't immediately come out - I had to soak it for a while, as it had a lot of mineral buildup.
The only comment I'd suggest is to soak the pieces in vinegar for about an hour. Acetic acid (the power and smell of vinegar) does an amazing job of cleaning. All the metal pieces looked new again and the vinegar was a yucky grey/green color. It helps to have some water handy to rinse your hands before you do this as the tap will be turned off when you do it (or else you can use the toilet if you're brave enough). My cartridge looks brand new and its was originally installed in the 70's. Excellent tutorial!
elbruceo 13 years ago
caitlinsdad 14 years ago
vlcowley 13 years ago
caitlinsdad 13 years ago
dataphool 14 years ago
