The 4" flapper valve chronically leaks, but then it only has about 2 inches of water to hold it in place. I bought a pound of 10-gauge PLAIN solder (not acid or rosin core) and wound it into a coil using a soup can. The solder is stiff enough you can form a loop to hold the coil in place. This stopped the repetitive running of the toilet, which was costing us 13 gallons per hour.
Is this still holding up? Glad I saw this as I was thinking of doing something similar to create a better seal. I have replaced the gasket 3 times in the least year alone.
Thanks for the video. I wasn't able to get to the store soon so I was able to cut off the "bump", almost like a bubble of air that contained some water. The cut side I put up since it doesn't help with the seal at all. The good side is down now minus the bump which is what was causing the seal to leak. Nice and flat now. Got to just be careful not to cut too much off or damage the seal. Works great and saved a trip to the store and I guess $5 for parts.
Thanks for the video and instructions. I followed them exactly, nice and simple. However, if the toilet still leaks, what could be the source of my problem?
i check the price here http://www.champtoilet.com/americanstandard-2034014020-champion4/ and its $388 , though i believe its one of the best one-piece toilet in the market today
Awesome video! I have an American Standard Champion 4 installed currently and I love it! Thank you for the tips and tricks.
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
9 Comments
DangerousB 4 years ago
lbb1028 3 years ago
JohnO285 5 years ago
brumey1107 6 years ago
Thanks again.
Thanks for the video and the instructions. I followed them exactly. So if my toilet is still leaking what else could the problem be? Thanks again.
Dejesam 7 years ago
the green cap has a few broken off pieces, can I replace the cap too? I can't find this flapper cap in any stores
CarrollV 8 years ago
AndyP2 9 years ago
chloemariebenson 10 years ago
