Flayed Alarm Clock
Intro: Flayed Alarm Clock
It is just that a flayed alarm clock. I was tired of how it looked so I made into a functional art peace.
STEP 1: Flaying
I dont have a photo to show you but its straight forward. Just take the clock apart.Then lay the guts out flat and mount. I used Liquid Nails to glue it down.I know there are exposed wires but its not a toy .You can mount it on or in anything nonconductive.Also stabiles the power cord so it wount put stress on its soldered joints. This is more art than science but use common sense. Leave it unpluged untill after you have it mounted.
39 Comments
BC-45 16 years ago
2manyprojects2littletime 13 years ago
The ground is there as a safety precaution, so that if:
a) the live (hot) touches a piece of metal that it isn't supposed to, like the case that here has been flayed away, or
b) the neutral (return) wire touches the case *and* the load in the circuit the clock is plugged into is unbalanced
then the current will go through the case, down the ground line (which is attached to the case) and into the earth.
Without the ground conductor attached, if either (a) or (b) happened and someone touched the clock's case while it was happening they'd get lifted by mains power.
FYI: Ground Fault Circuit Interrupt (GFCI) plugs (like the ones that are usually in bathrooms with the "Test" and "Reset" buttons in the middle) go an extra step by monitoring the connections and if current begins to leak (i.e. go from hot/neutral to ground, like in the above example) it isolates the device, i.e. disconnects it from the mains. You would then have to hit the reset button to get the plug working again, but the shock you get would be so small and quick that you probably wouldn't even feel it.
leevonk 17 years ago
James (pseudo-geek) 16 years ago
Adam Manick 13 years ago
leevonk 16 years ago
Dracanse 14 years ago
davidprosser 14 years ago
Derin 14 years ago
Daddio_UK 16 years ago
VIRON 17 years ago
zootboy 16 years ago
VIRON 16 years ago
Clarify that.
