Flexible Fabric Pressure Sensor
Intro: Flexible Fabric Pressure Sensor
How to make a flexible fabric pressure sensor from 3 layers of conductive fabric.
This Instructable is somewhat outdated. Please view the following Instructables for improved versions:
>> https://www.instructables.com/id/Conductive-Thread-Pressure-Sensor/
>> https://www.instructables.com/id/Flexible-Fabric-Pressure-Sensor/
>> https://www.instructables.com/id/Pressure-Sensor-Matrix/
>> https://www.instructables.com/id/Stickytape-Sensors/
STEP 1: Materials
You will need:
(The amounts of material depend on how large you want the touch pad to be)
- Ex-static fabric from www.lessemf.com
(also see http://cnmat.berkeley.edu/resource/ex_static_conductive_fabric)
- Stretch conductive fabric from www.lessemf.com
(also see http://cnmat.berkeley.edu/resource/stretch_conductive_fabric)
- Cotton thread or a kind of non-conductive adhesive
Optional:
- Another material as padding on either side. In the example I'm using Neoprene (ordered from Sedochemicals)
- An LED to show it works
- Energy source. In the example I'm using 3x1.5 Volt batteries
- Cables to connect
Optional:
- Cables to connect
STEP 2: Layering
Layer you materials as follows:
TOP
(- Optional layer or neoprene)
- Stretch conductive fabric*
- Ex-Static conductive fabric*
BOTTOM
*VERY IMPORTANT:
Layer the Stretch and the Ex-Static conductive fabric so that the layers of Stretch DO NOT touch!
The layers of Stretch conductive fabric should be displaced from one another in opposite corners (so that later they can both be sewn into place without the thread ever passing through both Stretch conductive layers at one time) and sticking out slightly at opposite ends (so that later on they can be connected to a power source and electric components).
TOP
BOTTOM
*VERY IMPORTANT:
STEP 3: Sewing
Now that the layers are in place, carefully sew around the edges making sure never to stitch though both Stretch conductive layers at the same time.
This step can be tricky and you can use either a sewing machine or sew it by hand as in the example.
STEP 4: Setup
This setup demonstrates how that applying pressure to the touch pad changes the brightness of the LED.
- Connect one of the (sticking out) Stretch conductive layers to the + pole of your energy source (4.5 Volt)
- Connect the + pole of the LED to the other (sticking out) Stretch conductive layer
- Connect the - pole of the LED to the - pole of your energy source
- Apply pressure to the touch pad
The amount of current changes depending on the amount of pressure to one point and the area of pressure.
54 Comments
Astro01 5 years ago
Cheers!
asurasnyx 7 years ago
Hi
I don't know if this is something you can help with, but i'm looking to modify a chair so when it is sat on music/stories/sounds are played through something like an ipod shuffle do you have any idea how i would go about it, i assume somehow linking a pressure sensor to an ipod would work? but i don't know how to do it!!
Many thanks
RobertY29 7 years ago
I think it might be hard to queue the ipod BUT if you just let the ipod run you could get a cheap headphone extension. If you cut the extension in half you can kindof pull apart the wires inside it. If you strip off some of the insulation and then connect them loosely you can see which one turns off the headphones when disconnected. Wire that one through the switch. Then put the extension in line between the ipod and your speakers and put the switch wherever you want and you are good to go.
cuzzea 12 years ago
Plusea 12 years ago
and MUTR in england >> http://www.mindsetsonline.co.uk/index.php?cPath=418_6_572
Hybrid.Bruce 12 years ago
Plusea 12 years ago
>> http://www.kobakant.at/DIY/?p=65
ivsfl 12 years ago
Thank you
Plusea 12 years ago
haunted.haunt 12 years ago
I want to make ti the size of a standard "Welcome!" mat.
Is there a difference?
Plusea 12 years ago
also, this is a rather old Instructable, be sure to look at some of the newer designs:
Mike Nelson 13 years ago
B.F.L.M 14 years ago
Plusea 14 years ago
if you are you are using "wire" and not conductive fabric or thread for the long (how long?) connections then you should be fine.
also check out the following instructable:
>> https://www.instructables.com/id/Conductive_Thread_Pressure_Sensor/
i've had better results with the velostat (or eeonyx fabrics) than the ex-static fabric.
cantthinkof bettername 15 years ago
Graceria 15 years ago
Plusea 15 years ago
wupme 15 years ago
myrtou 15 years ago
