Floating Candles
Intro: Floating Candles
Float some candles in the air for a spooky and magical feel.
Be careful and safe with this one, OK? These should not be left unattended.
STEP 1: Find Your Candle's Center of Gravity
The key here is to find the center of gravity of your candle so that you know where you can hang it from. Here I'm holding the candle between two fingers to see if it settles correctly You can also try balancing it on a finger. Now make a mark just slightly above this point.
I'm doing this test on a new candle, but I'd recommend letting the candle burn until the flame "settles" inside the candle before doing this. The candle will be burning a little slower here and give you a bit more burn time in the end.
STEP 2: Drill It!
Using your smallest bit, drill through the candle at this point. Make sure you're going straight across it.
STEP 3: Thread the Wire Through
I'm using a guitar string here. It's thin and strong. It's also very shiny as you'll see later. You can either try finding a strong thread to do this as well or try painting the wire so that it has a matte finish for a better effect.
STEP 4: Hang It and Light It!
Attach the wires to the ceiling somehow and make sure the candles are completely done moving before you light them up.
Here you can see the reflection off of the wires. Even with this so visible the effect is quite nice.
Keep an eye on the candles and be sure to blow them out before the flame gets too close to the wires and they pull through the soft wax. That's a mess that nobody wants to clean up.
Oh, and again, be careful if you try this. In fact, I recommend that you don't. However, if you're feeling brave and stupid, then go for it.
STEP 5: The Hanging Candle Holder!
Oh, but wait, there's more!
I also tried this variation with a heavy candle holder. Without the wax keeping the wires on opposite sides you'll need three wires for this one.
Using the same types of wire, loop them around the top of the candle holder and connect to three points on the ceiling.
Thanks to randofo for the help with the messy trial and error.
60 Comments
Andrewtkinsman 5 years ago
Thank you in advance for any suggestions.
fungus amungus 5 years ago
So many of these options are messy. You could also use sheets of beeswax and roll them up in a tube instead.
Creating a flame-shape diffuser with hot glue is a good idea. You'll be losing some intensity, but it spreads out the light nicely. Problem is getting the shape right. Might be able to carve it down with an xacto.
As for LEDs, it could be interesting to try multiple flickering LEDs. Having one flickering LED always looks too artificial for me. It lacks the liveliness of a flame dancing. Having multiple LEDs could likely reduce that feeling.
srivastav 9 years ago
Excellent Tutorial..
Only pain is HOT wax falling on your hair. so i used electric candles - See "Electric candles preparation (DIY)" for this. Best part is, we can control brightness :D
lorrainet 14 years ago
maven 12 years ago
tellner 12 years ago
greentea 14 years ago
This is a good instuctable but its just a thought I had while reading it. I'm going to play around with doing this now.
hanelyp 13 years ago
rhino21 14 years ago
sharlston 14 years ago
Jezter Long 14 years ago
revelae 14 years ago
jeffconnelly 14 years ago
lol
bdunni88 14 years ago
jhvh.one 14 years ago
Goodhart 14 years ago
zimmemic25 15 years ago
