Introduction: Flower Pot Topsy Turvey Doll
I love designing and making unique toys and other things for my beautiful granddaughters and am always coming up with new ideas for things to make for them.
It is nearly spring here and I was inspired to make something to keep me focused on the days when the flowers will be in bloom.
Here is the outcome of combining 2 of my favorite things.
Materials
* See note about yarn weight below *
Flesh color yarn
Flower color yarn
Yellow yarn
Hair color yarn
Green yarn
Pot color yarn
Small amount of pink yarn
Crochet hook suitable size for yarn weight
Polyester stuffing
Scissors
Darning needle
Optional
1 1/2” x 6mm (1/4”) dowel
Pink crayon
2 x 6mm (1/4”) safety eyes
Steam Iron
Yarn Weight
You can use any weight and type of yarn, just be sure to use a crochet hook that is a bit smaller than you would normally use to ensure that the stitches are tight enough to hide the stuffing.
In this sample, I used #1 fingering weight cotton and a 2mm crochet hook.
Here is what I recommend for the different yarn weights:
#1 Superfine – sock / fingering weight – 2mm
#2 Fine – sport / baby weight – 2.5mm
#3 Light – DK / Light worsted weight – 3mm
#4 Medium – Worsted / Aran weight– 3.5mm
Step 1: Abbreviations
ch - chain
sc - single crochet stitch
hdc - half double crochet stitch
dc - double crochet stitch
tr - treble crochet stitch
dec - decrease
inc - increase by making 2 single crochet stitches in the same stitch
Hdc inc - increase by making 2 half double crochet stitches in the same stitch
( ) - instructions to be repeated or done in a single stitch
x - followed by a number indicates how many times to repeat what is in the brackets
st - stitch
sts - stitches
sl st - slip stitch
Step 2: Make the Leaf Base
1. Magic circle, sc 6
2. (Inc) x 6 = 12 sts
* Place a marker at the end of the round
3. (Inc, sc) x 6 = 18 sts
4. (Inc, sc 2) x 6 = 24 sts
5. (Inc, sc 3) x 6 = 30 sts
6. (Inc, sc 4) x 6 = 36 sts
7. (Inc, sc 5) x 6 = 42 sts
8. (Inc, sc 6) x 6 = 48 sts
Make 12 spokes
9. (Ch 5, sl st in 2nd ch from hook and next 3 ch, sc in next 4 sc through front loops) x 12
Work around spokes
10. Work along the right side of spoke - (2 hdc, sc, in top st (sl st, ch 1, sl st) - work along other side - sc, 2 hdc, skip 1 sc on leaf base, sl st in next sc) repeat around each spoke to make 12 leaves
* Cut yarn leaving a 16” tail
* If leaves curl up and you prefer them to be flat, iron flat with a steam iron before sewing on the flowers
Step 3: Make and Attach the Flowers
Make 7
Using Yellow
1. Magic circle- sc 10
* cut yarn
Join blue
2. (Ch 2, (dc, tr) in sc, (tr, dc) in next sc, ch 2, sl st in same st, sl st in next sc) x 5 - makes 5 petals
* Cut yarn leaving an 8” tail for sewing
* Sew the flowers to the leaf base starting with center flower
* Be sure to keep the stitching within the line formed by working through front loops of row 9 of the leaf base
Step 4: Make the Arms & Body
Arms - Make 2
1. Skin color- Magic circle - Sc 6
2. - 10. Sc 6
* Cut yarn
* Do not stuff the arms
Body
*Start with a 10” tail
With dress color, ch 14, join to work in rounds
1. - 6. Sc 14
* Mark last st as center back
* Add the Arms
7. Sc 4 of body, sc 6 around arm #1, sc 6 of the body, sc 6 around arm #2, sc 4 sts of the body = 26 sts
8. Dec, Sc, dec, hdc 4, dec, sc, dec, sc ,dec, hdc 4, dec, sc, dec = 19 sts
9. Change to skin color - Sc 19
* Stuff body
10. (Dec) x 9, sc = 10 sts
11. - 12. Sc 10
* Stuff body & shoulders
Step 5: Make the Head
Continue from where you left off...
13. (Inc) x 10 = 20 sts
14. Sc 2, (inc, sc 2) x 6 = 26 sts
15. Sc 2, (inc, sc 3) x 6 = 32 sts
16. Sc 2, (inc, sc 4) x 6 = 38 sts
17. Sc 2, (inc, sc 5) x 6 = 44 sts
18. (Inc, sc 10) x 4 = 48 sts
19. - 22. Sc 48 (4 rows)
Make nose at center front of face
21. Sc to center front of face. In the next st, start 3 dc sts, then pull yarn through all 7 loops, sc to end of row
22 - 27. Sc 48 (6 rows)
* Cut yarn
* Insert 1 1/2" dowel in neck or stuff firmly
* Insert safety eyes between rows 22 & 23, 5 sts apart (be sure the nose is in the center)
* (Optional) Instead of using safety eyes & if this is for a baby, make eyes using dark yarn - Magic circle, sc 6, pull into a circle and sew on the face as above
* (Optional) Embroider eyebrows & eyelashes with brown yarn
* Embroider mouth with pink yarn
* Stuff head leaving some stuffing above the head as show in picture
* (Optional) Use a pink crayon to add cheek color
Step 6: Make & Add the Hair
Using hair color
1. Ch 33, sc in 2nd ch from hook, sc 31, ch 1, turn = 32 sts
2. Sc 2, (ch 8, sl st in 2nd ch, sl st 6, sc 4) x 7, repeat spoke but end with sc 2 - makes 8 petal spokes, turn
3. Work around spoke (4 dc, hdc, sc, sl st, ch 2 , sl st, sc, hdc, 4 dc, skip sc, sl st in sc, skip sc) x 8. petals - end with sl st in last sc
* Cut yarn leaving a 20” tail for sewing
* Mark st at center front of face
* Sew hair to top of head starting at 7 sts away from the center marker
* Tack down hair strands - stitch halfway down petal to join to the head and stich along sides at front edges
Step 7: Attach the Flowers & Embroider the Bangs
* Sew the leaf base to the top of the head using the front loops made in row 9 of the leaf base
* Embroider bangs along the sts at the front of the face as show in the picture
Step 8: Make the Flower Pot
Use Flower Pot color
1. Magic circle - sc 7
2. (Inc) x 7 = 14 sts
3. Work through front loops - (inc, sc) x 7 = 21 sts
4. (Inc, sc 2) x 7 = 28 sts
5. (Inc, sc 3) x 7 = 35 sts
6. Work through front loops- (inc, sc 4) x 7 = 42 sts - sl st to join round, ch 1
7. Work through back loops of row 6 - Hdc 35, join round with sl st, ch 1
8. Hdc 35, join round with sl st, ch 1
9. (Hdc Inc, hdc 4) x 7, join round with sl st, ch 1, = 42 sts
10. - 12. Hdc 42, join round with sl st, ch 1 (3 rows)
13. (Hdc Inc, hdc 5) x 7, join round with sl st, ch 1 = 49 sts
14. - 16. Hdc 49, join round with sl st, ch 1 (3 rows)
17. (Hdc Inc, hdc 6) x 7, join round with sl st, ch 1 = 56 sts
18. - 21. Hdc 56, join round with sl st, ch 1 (4 rows)
22. Hdc 56, join round with sl st, turn and work from inside of pot
23. Work through back loops - (Skip sc, 5 dc in sc, skip sc, sl st in next sc) x 14
* Cut yarn & weave in the end
Step 9: Make & Sew on the Skirt
Use skirt color
1. Magic circle, sc 8, join round with sl st, ch 1
2. (Hdc Inc) x 8, join round with sl st, ch 1 = 16 sts
3. Work through back loops - (Hdc Inc, hdc) x 8 = 24 sts, join round with sl st, ch 1
4. (Hdc Inc, hdc 2) x 8 = 32 sts, join round with sl st, ch 1
3. (Hdc Inc, hdc 3) x 8 = 40 sts, join round with sl st, ch 1
4. (Hdc Inc, hdc 4) x 8 = 48 sts, join round with sl st, ch 1
5. - 6. Hdc 48, join round with sl st, ch 1
7. (Hdc Inc, hdc 5) x 8 = 56 sts, join round with sl st, ch 1
8. - 17. Hdc 56, join round with sl st, ch 1(10 rows)
18. Hdc 56, join round with sl st
* Sew the skirt to the bottom of the body around row 3 of skirt
Step 10: Sew the Body to the Inside of the Flower Pot
Use flower pot colored yarn
* Turn the skirt inside out so it covers the body and head of the doll as seen in picture
* Turn the flower pot inside out
* Make a stich in the center of skirt at bottom of body and the center of the flower pot. Pull to join
* Sew the doll body to the flower pot joining the front loops of row 3 of the skirt to row 3 of the flower pot
* Turn the skirt right side out so the flower pot is inside the skirt
Using tail from skirt
* Sew the skirt to row 22 of the flower pot - not the scalloped edge
Step 11: Make and Sew on the Dress Leaf Trim
Use green or desired color
1. Ch 21, sc in 2nd ch from hook, sc 19, ch 1, turn = 20 sts
2. Sc 2, (Ch 6, sl st in 2nd ch from hook, sl st 4, sc 5) x 3, ch 6, sl st in 2nd ch from hook, sl st 4, sc 5), sc 3, ch 1, turn - makes 4 petal spokes
3. Work 4 petals along spokes - (2 dc, hdc, sc, sl st, ch 2, sl st in same st, sc, hdc, 2 dc, skip sc, sl st in next 2 sc, skip sc) x 3, 2 dc, hdc, sc, sl st, ch 2, sl st in same st, sc, hdc, 2 dc, skip sc, sl st in last sc - 4 petals
* Cut yarn leaving a 12” tail
* Wrap around the body and join both end together to form a ring
* Stitch to body where skirt joins the body
You're done. Enjoy!
