Fluffy Monster Case
Intro: Fluffy Monster Case
Win this monster case!! Only $1! This cute case fits a Blackberry, digital camera, mobile phone, iPod or iPhone and is the prize in a charity lottery to raise money for Haiti
In this Instructable i'll show you how to make a simple case for a small (or big!) precious object, with a sleepy monster face on. This makes a great iPhone or camera case, and a very easy to personalise gift for a loved one :)
You can make it out of any fabric but i recommend something thick-ish (to protect against bumps) and non-stretchy
A new instructable every week on www.alittlestranger.com
STEP 1: You Will Need
a) Polar fleece
b) Fur fabric
c) Black and white felt
d) Velcro
e) Pins
f) Thread
g Scissors
b) Fur fabric
d) Velcro
e) Pins
f) Thread
g Scissors
STEP 2: Cut Your Fabric Out
1) Place your phone onto your fleece fabric, as far away from the edge as the phone is thick, and mark this distance again underneath the phone.
2) Mark this same distance all along the fabric, and cut along the line, making a long strip.
3) Place your phone onto the strip of fabric with enough overhang on one side to wrap all the way over it.
4) Mark this same distance on the opposite side of the phone and cut out. You should now have a rectangle of fabric that can comfortably encapsulate the phone, with enough for a flap to come back down over the front.
5) Place the fleece onto the reverse side of your fur fabric noting the direction of the fur. Cut out the fur to the same size as the fleece.
6) This is what you should have so far, a piece of fleece and a piece of fur the same size
STEP 3: Sew the Ends Together
7) Now you need to work out what part will be the main case and what part will be the flap. Pin the fabric together, right sides in, at each corner, and fold the fabric over the phone with about 5mm extra (to account for the seam) marking where it lands.
8) Leaving a 4mm margin on the 'flap' end, sew around the three edges to the marks you made. On the other end just sew straight across the end.
9) Tip: Trim the corners off at 45 degrees, this will give sharper points once you turn it right-way-out.
10) Turn the case the right-way-out, it will look like this.
STEP 4: Sew It Up and Add the Velcro
11) Take the edge where you only sewed straight across and fold it to meet where the base of the flap end. Pin in place on both sides.
12) Leaving a 4mm hem sew along this edge with a straight stitch, finish the edges with a zigzag stitch.
13) Cut a piece of velcro about 1cm shorter than the edge of the case, sew the rough side of the velcro onto the lining side of the flap, 5mm away from the edge.
14) Tip: To get the fluffy fibers out of the stitches on the front of the case run an un-picker or knitting needle (don't use anything sharp or you'll tear the fur) horizontally along the edge.
15) Put the phone into the case and close the flap, mark the case with a pin where it comes down to.
16) Pin the soft piece of velcro onto the case about 5mm above the marker pin you just placed. Sew the velcro in place
STEP 5: Making the Monster Face
17) Take your white felt, place it just underneath the end of the case flap and mark some sharp teeth on it. Cut out being careful to trim away any pen lines.
18) Trim the teeth to fit just underneath the velcro, pin into place. Handsew along the long edge using small neat stitches.
19) Cut two semi circles shapes from black felt and sew on using neat zig zag stitches.
Win this monster case!! This monster case fits a Blackberry, digital camera, mobile phone, iPod or iPhone and is the prize in a charity lottery to raise money for Haiti
41 Comments
danamrox 8 years ago
made one zebra collerd
danamrox 9 years ago
LOVE it ! Im making this
mine will be pink
GaryMeow 13 years ago
a tail cut i will to
cassidylynn 10 years ago
marionpixie 10 years ago
ilikecory 10 years ago
porcupine24253 10 years ago
TeganJovanka 11 years ago
TheFawns 13 years ago
Jessie Marie 11 years ago
YellowBlu Co. 11 years ago
Dusk Shadows 12 years ago
JessieT 13 years ago
A-Violent-Shock 13 years ago
