Introduction: Flying Wolf Pistol Crossbow Mods
I decided to change the existing foot stirrup, which was a strange T bar shape which was fine if you're barefoot otherwise you need to use both feet, as well as add some sort of clip for holding the bolts/arrows.
First up was the stirrup which I made from a length of 5mm steel bar that was welded onto a tab of metal, making it easier to bolt onto the xbow, this was then wrapped with paracord.
The bolt clip was a strip of stainless steel, which is a fairly hard metal to work with, aluminium would be a lot easier, that was bent into a U shape and screwed into an existing hole the xbow. Holes were drilled into the metal strip which then had rubber grommets inserted that hold the arrow shafts.
8 years ago
Super bad ass
