Introduction: Foam Clone Trooper Armour
This Instructable will show you how to build a suit of Clone Armour out of ordinary foam, cardboard, and duct tape. This particular suit was constructed for my 12-year-old step-brother, using an action figure as reference. A few pieces are missing (such as the hand guards, ab plate, and thermal detonator) but the look is definitely conveyed. From start to finish, this project took about a month and-a-half to complete. I can't accurately determine a budget, as I already had several of the materials on hand, but expect to pay $50+ if you are buying everything. Anyway, on to the steps!
Step 1: Materials
Interlocking Foam floor mats- Found at Home Depot and Harbor Freight Tools, comes in packs of four-$18 (you will need 2 four-packs)
Cardboard-Any will work as long as it's corrugated-Free!
Craft foam-Sold at most craft stores in 12"x18' sheets-99 cents a sheet
Plasti-Dip Spray-Sold at Home Depot-$6.95 a can-This build requires at least six cans
Glossy White Spray Paint-$4.48 a can-You will need about four cans.
Poster board or other stiff paper-For making templates
Duct Tape!-Also found at Home Depot and most craft stores
Elastic straps-Found at most craft stores
Heat gun-Used for shaping the foam
Hot glue gun+hot glue-Used to assemble the suit
Dremel-Used for relief details
(Optional) Latex caulking-Used to fill in the seams where the foam comes together. Gives a more "solid" look, but isn't entirely necessary
Step 2: Making Templates
Using an action figure or reference photos as a guide, take your poster board and tape multiple pieces to your model. Work out the shape of the pieces, cutting away and taping on where necessary. The chest is made in two pieces to give it more dimension. Note that the chest, cod/butt plate, and shoulder bells will be made from the foam floor mats, while the arm and leg pieces will be made from cardboard covered with craft foam.
Step 3: Cutting Out the Pieces
Using a marker, transfer your templates onto the foam and cardboard, and cut them out with a sharp ex-acto blade. Use the heat gun to give the chest and back plates a curve. Simply heat up the piece, bend it into shape, and let it cool. Assemble the arm and thigh pieces with duct tape. Be sure to seal the cut ends of the cardboard: this will help prevent tearing.
Step 4: Glueing It All Together
Hot glue the chest pieces together, and glue the craft foam pieces to the cardboard. You'll also want to carve a groove down the center of the chest plate with the dremel. Also carve a groove following the blue line shown on the codpiece. If you choose to use the latex caulking, lay down a line along the seam, and smooth it with a paper towel. After that's done, cut some elastic straps and and glue the chest and back together at the shoulders and sides. I didn't get many pictures of the strapping process, as I was wrapped up with college at the time, but I'll try to explain it as best I can. The shins (not pictured) are held together by three straps on each side. The shoulder bells connect to the shoulder straps with a single piece of elastic, and an additional strap is glued to the bottom edge of the bell that connects to the upper arm. There is also a loop on the bell that keeps it from flopping around. The thighs are connected to the codpiece with a single strap on each side. The bottom of the cod piece connects to the bottom of the butt plate with a single strap.
Step 5: Plasti-dip
Before you can paint the pieces, they will need to be sealed, as foam is porous (and will therefore absorb paint). Plasti-Dip is a rubberized spray that is usually used to give tools "grip," and will seal porous surfaces. Prepare your working area, set up your pieces, and spray. Each piece will need two coats. For the first coat, just spray until you can't see the color of the foam anymore. After it dries, the foam will have absorbed the spray in a few areas. For the second coat, spray a heavier coating on the areas that got absorbed, and rub it in with a paper towel. Use a circular motion, as this will give a smooth surface.
Step 6: Painting
Now take your glossy white spray paint and spray your pieces. Like the Plasti-Dip, each piece will require two coats of paint. Be sure not to go too heavy, or else the paint will crack when it flexes(it will crack slightly, but it isn't too noticeable unless your are really looking for it).
Step 7: Put It All On!
Now that your armor is complete, suit up and grab a blaster!
Halloween Epic Costumes Challenge
35 Comments
4 years ago
If I can finish it in time in the late fall, maybe winter, but I am going to use it for air-soft with some of my friends, and I wanted to know if the small ball bullets will damage the armor? plz respond
Reply 2 years ago
I found a video about it, and a normal EVA foam mat will get damaged if shot more than once by an airsoft rifle. If you want to add protection to your armor while keeping the design, maybe try making plastic pieces of the plates with your cardboard templates (if you still have them) and apply it over the armor with some gorilla glue or something like that. I would recommend plastic with a white color, but having thinner layered translucent plastic may work too. Though I cannot guarantee a success, maybe trying that May work. And if you use tape, you can just repaint over it with white. Hope this works.
Reply 1 year ago
It depends the fps of the gun, try plating your armour o the outside with cardboard.
1 year ago
can u do one for clone commando armor?
Tip 4 years ago
You could add a stomach cover up in the armor, like in this clone trooper model I had made a screenshot of, the stomach area is closed and covered up. and in the area of your stomach area is opened and black. I just wanted to do point that out, but other than that it is a really good model, I like it actually. I am going to do it.
Reply 2 years ago
There are a lot of online stores that sell plastic abdomen plates separately from a whole armor set, though they are stormtrooper and not clone trooper (agony intensifies) but they can be cut to just cover the abdomen.
Question 2 years ago
Is it possible to make the arm and leg pieces with the floor mats as well?
2 years ago
This is definitely a great base for modifications after or during the construction process. Adding more details like closed shoulder straps, an abdomen cover, and other things, will give it more detail like you actually are a clone trooper. This is by far the best clone costume instructable I’ve ever seen.
4 years ago
Can you also make one where you show the size of 5 feet and 25 inches please? that is the size that I am. Thank you! :)
Reply 2 years ago
Pretty sure you would be 7 feet 5 inches if you were 5 feet 25 inches brother! XD
Reply 2 years ago
Definitely XD
Question 2 years ago on Introduction
Is it possible to add details, like dust from a recent battle, without messing up the overall structure or paint of the armor, but also so it doesn't look too brand new, so it looks believable to be a real clone? Thanks! :)
4 years ago
Can you update saying how much craft-foam you need please? it doesn´t say
4 years ago
can you send templates please thank you
10 years ago on Introduction
Couple of question here first, how tall is your step-brother? Is the back piece to the chest armor the same cut out as the front apart from the "pecks?" Thanks in advance!
My step-brother is between 5'1"-5'2". The back piece is a seperate cut-out. As you can see in the pictures, the front piece curves upward on the bottom so he can bend at the abdomen.
Reply 6 years ago
Can you only make it that size
Reply 6 years ago
It can be made at any size. All the patterns were free-handed.
6 years ago
The armor looks good keep up the good work!
6 years ago
Hello,
I was wondering, what would I use to harden the plastic?
