Introduction: Foam Plate Plane
Are you tired of buying overpriced parts for your rc plane? Well this is for you I have saved over $50 with this plan
Step 1: Get the Materials
You need the following things, 1. Old styrofoam plate 2. Old airplane part 3. Hot glue You also need siscors
Step 2: Get a Templet of the Part
Tape up the old part as best you can or just design a new one
Step 3: Start Drawing
Trace or draw the part on the plate make sure you draw where the hinges are
Step 4: Cut Out
Cut out the part be carful don't cut where the hinges go
Step 5: Make Hinges
To make the hinges just run it over with a pincle a couple of times to push in the styrofoam but don't go all the way through and then test it
Step 6: Add Control Horn and Wheel
Mark where the control horns go and the wheel and install just like you usually do
Step 7: Install
Mine was a perfict fit but if yours is to thin you might have to ca some plates together to get it right but install like normal and go fly
Epilog Challenge V
Instructables Green Design Contest
3 Comments
9 years ago
Ya it did mine
9 years ago on Introduction
Nice fix... I think ca glue would melt Styrofoam.
9 years ago
Dylan get a life this is jacob
