Foldaway Door Bench
Intro: Foldaway Door Bench
You can never have enough bench space, until it gets in the way. I needed a bench under the window so I had somewhere to grow seedlings.
Having a few internal doors and hinges kicking around the garage so I put them together. Using the hinges on the door as the lift hinge and a couple of supports hinged into the wall.
STEP 1: Make the Supports
I made a pair of hinged supports to fit between the uprights. I also wanted them to fit into the wall, but this proved a little tricky so I did the best I could.
STEP 2: Attach the Door
Because I could not get the supports flush with the door I needed to attach padding so when the table is dropped down it cleared the supports.
I also had another spare bit of bench top which I was able to use an inch of the left hand support to hold up.
Finally i covered the door with a sheet of plastic to protect it from the wet stuff (not shown).
Penolopy Bulnick 10 years ago
