Folding Chair for Hand Tools or CNC Router
Intro: Folding Chair for Hand Tools or CNC Router
This folding chair was designed with the intention of laying it completely flat for storage (based on a Youtube video by "Mr. NK," which you can access at https://www.youtube.com/watch?v=yyEmcc5JLaY). We modified the video's design so that it has a higher seat, which is better for accessibility and comfort. It requires a roughly flat surface, so it can be used outside on even-surfaced lawns, in parking lots, or indoors. We made multiple prototypes of the chair before finalizing the design. At first, we used hand tools, which was effective, but not as clean as when we used a CNC router with a 1/4 inch bit. Either works well, but the attached drawings' dimensions in these instructions were made specifically for hand tools.
STEP 1: Dimension Drawings
a. If using the CNC router, either download the CAD file below, or draw your own with desired dimensions.
b. If using a jigsaw, make your own drawing of the chair, using the pdf. attached below.
STEP 2: Cut Out the Chair
a. Cut out the chair using the CNC router, using a 1/4 inch bit.
b. Cut out the chair using the jigsaw. Try to get as close to 1/4 inch margins as possible. It helps to trace an outline of the chair on the plywood first, using the drawing's dimensions above.
STEP 3: Sand the Curve at the Top of the Chair
3. Use a belt sander to trim down the back of the chair, so that the piece of wood is slightly curved. This makes it a more supportive and comfortable back-rest.
STEP 4: Use a Wood Router
4. Use a wood router to smooth out the sides. Use sandpaper to smooth out the sides, if desired/necessary. Then, use an orbit sander to smooth the surface of the entire chair.
STEP 5: Sand the Chair
STEP 6: Make the Hinge Holes
Use a drill press to create holes for the hinges.
STEP 7: Screw on the Hinges
Using a drill, screw on the hinges. We used an internal hinge method for the upper legs of the chair at first, but the plywood actually broke due to its lack of thickness. We recommend using three hinges in total: one for the seat as shown above, and two for the chair legs.
STEP 8: Stain the Chair
Stain/finish the wood. Make sure to do this carefully to avoid drips.We used a blue and medium colored stain for our chairs, then coated them in a polyurethane sealant.
STEP 9: Optional: Attach Locking Mechanism
Attach some sort of locking mechanism to keep the chair from unfolding during transport. This is not completely necessary if the chairs are made for the same location and don't require frequent movement.
STEP 10: Done!
The chair is complete! We hope these instructions were helpful!
10 Comments
HeinrichS 1 year ago
ParKit 11 months ago
ParKit 1 year ago
infradata 1 year ago
charlessenf-gm 1 year ago
They I recalled that 'they' make thicker plywood - one inch for sure and quite possibly thicker. Then, as I typed this I thought about laminated lumber - so why not simply glue two sheets together and make a thicker chair?
Or use two sheets of thinner ply and a torsion box approach - after all, if you've got a CNC what's stopping you?
ParKit 1 year ago
cburg 1 year ago
Thanks for your time investment for both the project and sharing...
Cburg
ParKit 1 year ago
