Ford Grille Area 30" LED Light Bar Install Guide
Introduction: Ford Grille Area 30" LED Light Bar Install Guide
About: Everything about automotive LED lights
This is a guide on how to install the 30" 150W single row CREE LED light bar for the 2011-2016 Ford F-250 F-350 Super Duty. The included mounting brackets allows you to mount this LED light bar on the upper or lower end of the Ford grille.
Please note that this project will involve modifying your grille, so prepare a handsaw and a drill before getting started.
Step 1: Remove the Grille.
Unfasten the grill bolts and the push pins on top and undo the spring clips at the bottom. Pry open the grille to give yourself clearance the reach the spring clips. Use a long screwdriver to push down on and undo the spring clips.
Step 2: Cut Off the Plastic Beams.
You can easily use a handsaw to cut off the plastic beams. We recommend you lay down the grille on top of a carpet surface to make this step easier to perform.
Step 3: Prepare the LED Light Bar for Installation.
Assemble the rail mount base piece into the slot in the middle of the LED light bar. Lock it in at 5" from the edge using the included hex tool. Place the M6 bolt in between the base piece and slide in the longer M8 bolt through the rail piece and the M6 bolt. Secure them with the included spring washer and nut.
Step 4: Mount Your LED Light Bar Base Bracket Onto the Columns of the Grille Behind.
Place the brackets where they will be mounted and mark your drilling locations with a marker. Drill holes through the marked locations. Place the base brackets back, route the bolts through the holes and thread the nuts through the bolts.
Step 5: ​Secure the LED Light Bar on Top of the Base Brackets.
Run the nuts through the M6 bolts to secure the LED light bar to the base brackets.
Step 6: Reinstall the Grille in the Reverse Order You Removed It.
Afterwards, connect the wires to an existing stock harness or to the included relay harness with on/off switch. Use our guide to learn how to wire a relay harness with on/off switch.
Step 7: Test Your LED Light Bar to Make Sure It Lights Up.
This installation involved minimal modification on your part but maximum style and light output for your Ford F-250. We hope you can fully enjoy your new LED light bar. For all kinds of LED light bars for offroading, visit iJDMTOY's truck offroading LED lights page to browse our selections.
Step 8:
Be the First to Share
    • Metal Contest
      Metal Contest
    • Crayons Challenge
      Crayons Challenge
    • Microcontroller Contest
