Wearable Beating Heart LED Box
638
Introduction: Wearable Beating Heart LED Box
About: Rosedale Designs
https://www.behance.net/gallery/53247375/Wearable-...
// Title: DATT 2000 Foundations Project - Heart
// Name: Dale Rosen
// Date: October 8th, 2015
// Description: This arduino project simulates a heartbeat at three different speeds to represent walking, jogging and running.
The small box "pumps" off of your chest via the servo motor attached to the back of the box.
// Instructions: Rotate the potentiometer counterclockwise to speed up. Rotate the potentiometer clockwise to slow down.
Step 1: Schematic
Heart Rate Sensor ( Not Included )
Step 2: Simulate
Step 3: Code
// Name: Dale Rosen
#include
// variable section Servo myservo; // create servo object to control a servo int pos = 0; // variable to store the servo position int ledPin = 13; // pin 13 for the LED int sensorPin = A0; // pin A0 for the POT int sensorValue = 0; // variable to store the value coming from the POT
void setup() { // pin section myservo.attach(9); // attaches the servo on pin 9 to the servo object pinMode(ledPin, OUTPUT); // initialize digital pin 13 as an output. pinMode(sensorPin, INPUT); // initialize analog pin A0 as an input. sensorValue = analogRead(sensorPin); // value of LDR }
void loop(){ while(sensorValue < 200){ // 78 BPM sensorValue = analogRead(sensorPin); // value of LDR digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 20) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(20); // waits 10ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 20) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(20); // waits 20ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(400); // wait for a 4/10th of a second digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 30) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(30); // waits30ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 30) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(30); // waits 30ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(200); // wait for a 2/10th of a second digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 30) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(30); // waits 30ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 30) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(30); // waits 30ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second }
while(((sensorValue >= 200) && (sensorValue <= 500))){ // 102 BPM sensorValue = analogRead(sensorPin); // value of LDR digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 15) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 15) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(300); // wait for 3/10th of a second digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 22.5) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(22.5); // waits 30ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 22.5) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(22.5); // waits 22.5ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(150); // wait for 1.5/10th of a second digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 22.5) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(22.5); // waits 22.5ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 22.5) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(22.5); // waits 22.5ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(750); // waits for a 3/4 of a second }
while(sensorValue > 500){ // 129 BPM sensorValue = analogRead(sensorPin); // value of LDR digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 10) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(10); // waits 10ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 10) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(10); // waits 10ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(200); // wait for a 5th of a second digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 15) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 15) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(100); // wait for a tenth of a second digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) for(pos = 90; pos >= 0; pos -= 15) // goes from 90 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } for(pos = 0; pos <=90; pos += 15) // goes from 0 degrees to 90 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW delay(500); // wait for a half second }
Step 4: Photos + Video
The video is available online here: https://www.behance.net/gallery/53247375/Wearable-LED-Beating-Heart-Project
You can hear the servo motor moving in the video
Be the First to Share
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    • Hand Tools Only Challenge
    5 Discussions
    kksjunior
    kksjunior
    3 years ago
    I would love to see the video of it in action but i can't download the file you've attached!
    ahmet_024102
    ahmet_024102
    3 years ago
    video not work
    Swansong
    Swansong
    3 years ago
    That's a cute idea :)
