Friend of Humanity Dog Poo Warning Spray System
Intro: Friend of Humanity Dog Poo Warning Spray System
This system will allow you to warn fellow humans beings that there is dog mess in their path, and give them time to sidestep it.
You have done a good thing.
STEP 1: The Inspiration.
Britain is tiny and it is absolutely covered in dog mess; running, walking or cycling requires constant vigilance.
One day I found some fluorescent powdered chalk in a skip.
I decided to mark every poo I encountered on my jogging route, as I ran.
The next day, when I jogged, I easily avoided every one of them.
Also, I had the humourous vision of people looking at these turds and wondering who would have been sad enough to annoint them.
It was me.
Anyway, then my mind came up with a bike mounted spray system.
I didn't want to make it but my brain just wouldn't shut up until I did,(I'm sure you know the feeling.)
O.K., I didn't really have a plan except to make it a simple and quickly as possible.
Here are the bits that I started with...
A brake lever, Aluminum pole, a bit of wood, and some brake cable.
Also pictured is a stencil; the idea was to turn a thing of revulsion into a thing of beauty.
Unfortunately, tests showed that the stencil would have to actually be laying on the poo to be effective; I gave the stencil idea up.
It was me.
STEP 2: Step 1.
Drill a hole in the tube.
Wrap some inner tube around your spray-can.
Cable-tie it together.
STEP 3: Step 2.
Get a strip of metal or wood and drill a hole at one end and also a small hole in the middle, (for the cable).
Drill a small hole in the pole, (also for the cable).
Affix on the pole, quite loosely.(I used a folded inner-tube as a washer, to give some flexibility.)
STEP 4: Step 3.
Affix the pole to your front fork any way that you can.
I wrapped the pole in inner tube and used a cable-tie and a fork-boss.
STEP 5: Step 4.
Attach brake lever to bike.
Attach brake cable to pole.
Stick on a bit of tape to keep everything on track.
STEP 6: Step 5.
O.K., cycle along and if you see a Richard-the -Third, then spray it.
(I have used a block of wood to spare your delicate sensibilities).
This does work; the riding action mixes the paint.
If you are as sad as me , this adds a certain pleasure to a routine cycle ride. (Such as cycling to work.)
I'm sure that line-marker paint would be brighter but it's just too expensive over here.
STEP 7: Epilogue.
Like all pivotal points in human history, this device can be used for good or evil.
It has potential to make huge works of graffitti art.
It has potential to surreptitiously spray cars that have been naughty to you on the road.
I would hate either of the above to happen but there you go, people are morons.
Anyhoo, thanks for reading my drivel and hopefully my brain will shut up now.
38 Comments
sammyBoy 15 years ago
FriendOfHumanity 8 years ago
I know that this is 7 years too late but your comment was the best.
matseng 16 years ago
Grazerquart 9 years ago
Instead of spray painting the owners maybe using the chemicals that cause rashes in poison ivy to mark the owners
Wasagi 12 years ago
malkanero 14 years ago
Gorfram 14 years ago
bob.smitty 15 years ago
echo_anomie 16 years ago
duct tape apprentice 16 years ago
SerialATA 16 years ago
copycat42 16 years ago
berserk 15 years ago
headphoned 15 years ago
copycat42 15 years ago
omnibot 15 years ago
haptotrope 16 years ago
