Fully Utilize the Power of a Push Button
2,759
29
Introduction: Fully Utilize the Power of a Push Button
Push button is a very very common component used in most of the DIY projects.
Programming a push button is a piece of cake. Right ?
Anyway, there are still some ticks on it.
Step 1: Control LED on and Off by One Push Button -- 1st Way
//Button_01
//Control LED on and off by a push button
// created by uvvvvw
// 2015-04-05
const int Button = 12; //Define button pin
const int LED = 4; //Define LED pin
int LED_state = LOW; //Status of LED : LOW(on), HIGH(off)
void setup()
pinMode(Button, INPUT);
digitalWrite(Button, HIGH); //Use internal pull up resistor for the button. It saved a resistor for the button.
pinMode( LED, OUTPUT);
digitalWrite( LED, LOW);
void loop()
if (digitalRead(Button)==LOW) //if button is pressed
if ( LED_state == LOW)
{//if the LED is off at this moment,
digitalWrite( LED, HIGH); //turn it on
LED_state = HIGH; //new status of the LED is HIGH
else
{//if the LED is on at this moment,
digitalWrite( LED, LOW); //trun it off
LED_state = LOW; //new status of the LED is LOW
delay(300); //A very simple way to handle button bouncing, but need to adjust the delay time to optimize the result.
Step 2: Control LED on and Off by One Push Button -- 2nd Way
Same as "Button_01", except bitwise XOR is used for simplification purpose.
//Button_02
//Same as "Button_01", except bitwise XOR is used for simplification purpose
// 2015-04-05
void setup()
void loop()
digitalWrite( LED, digitalRead(LED) ^ 1); //read the state of the LED, reverse it by XOR(^).And turn it on or off accordingly
Step 3: Control LED On, Blink and Off by a Push Button
//Button_03
//Control LED on, blink and off by a push button
// 2015-04-05
int LED_state = 3; //Status of LED : 1(on), 2(blink), 3(off)
//handle the blinking while LED_state == 2
long interval = 500; //interval of blinking (milliseconds)
unsigned long currentMillis; //record the current time for blinking
long previousMillis = 0; //store the last time LED was updated
void setup()
pinMode(LED, OUTPUT);
void loop()
if (digitalRead(Button) == LOW) //if button is pressed
LED_state++;
if (LED_state > 3) LED_state = 1; //button State from 1 to 3
switch (LED_state)
case 1://LED on
digitalWrite(LED, HIGH);
break;
case 2://LED blink
currentMillis = millis(); //start the interval counting
if (currentMillis - previousMillis > interval)
digitalWrite( LED, digitalRead( LED ) ^ 1 ); //read the state of the Led, reverse it by XOR.And turn it on or off accordingly
previousMillis = currentMillis;
break;
case 3://LED off
digitalWrite(LED, LOW);
break;
Step 4: Turn Three LEDs on and Off in Sequence by One Push Button
//Button_04
//Turn three LEDs on and off in sequence by one push button
// created by
// 2015-04-05
const int LED_01 = 4; //Define pin# of 1st LED
const int LED_02 = 3; //Define pin# of 3nd LED
const int LED_03 = 2; //Define pin# of 3rd LED
int LED_state = 1; //Status of LED : 1(LED_01 on), 2(LED_02 on), 3(LED_03 on)
void setup()
pinMode( LED_01, OUTPUT);
digitalWrite( LED_01, LOW);
pinMode( LED_02, OUTPUT);
digitalWrite( LED_02, LOW);
pinMode( LED_03, OUTPUT);
digitalWrite( LED_03, LOW);
void loop()
LED_state++;
switch (LED_state)
case 1://LED_01 on
digitalWrite(LED_01, HIGH);
digitalWrite(LED_02, LOW);
digitalWrite(LED_03, LOW);
break;
case 2://LED_02 on
digitalWrite(LED_01, LOW);
digitalWrite(LED_02, HIGH);
break;
case 3://LED_03 on
digitalWrite(LED_03, HIGH);
break;
Step 5: Turn on All Three LEDS Gradually Through One Single Push Button
//Button_05
//Turn on all three LEDS gradually through one single push button
// created by
// 2015-04-05
int LED_state = 0; //Status of LED : 0(all LEDs off), 1(LED_01 on), 2(LED_02 on), 3(LED_03 on)
void setup()
void loop()
LED_state++;
if (LED_state > 3) LED_state = 0; //button State from 0 to 3
switch (LED_state)
case 0://All LEDs off
break;
case 1://LED_01 on
break;
case 2://LED_02 on
break;
case 3://LED_03 on
break;
Step 6: Turn Two LEDs on and Off Individually by One Single Push Button
That is use one single button as two buttons.
//Button_06
//Turn two LEDs on and off individually by one single push button
//That is use one single button as two buttons
// created by
// 2015-04-05
int Button_still_pressed = LOW; //Status of the Button
long Button_count = 0; //Record the pressing time
int LED_affected = 0; //Affected LED : 0(no LED affected), 1(LED_01), 2(LED_02)
void setup()
{ pinMode(Button, INPUT);
void loop()
do {
Button_still_pressed = HIGH;
Button_count++;
if (Button_count <100000)
LED_affected = 1; //for short press, LED_01 is affected
if (Button_count == 100000) //this value defines the time required for long press
LED_affected = 2; //for long press, LED_02 is affected
digitalWrite( LED_02, digitalRead(LED_02) ^ 1); //read the state of the LED_02, reverse it by XOR(^).And turn it on or off accordingly
else
}while (Button_still_pressed);
if (LED_affected == 1) digitalWrite( LED_01, digitalRead(LED_01) ^ 1); //read the state of the LED_01, reverse it by XOR(^).And turn it on or off accordingly
LED_affected = 0;
Button_count = 0;
Step 7: Control Value Changing Speed Based on Pressing Time of a Push Button
If the button is pressed one time, the value will be increased by one.
But if the button is pressed continuously, the value will be increased by one continuously at the
beginning. And later on, the value will be increased by 10 continuously. And then 100 if keep on
pressing the button.
//Button_07
//Control changing speed based on pressing time of a push button
// 2015-04-05
#include
#include
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
long Value = 0; //Value that will be increased while the Button is pressed
void setup()
lcd.init();
delay(400);
lcd.init();
lcd.clear();
lcd.cursor();
lcd.blink();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print(Value);
void loop()
do {
Button_count++;
if (Button_count < 20)
Value++;
lcd.setCursor(0,0);
lcd.print(Value);
lcd.print(" ");
else
if (Button_count < 100)
Value = Value + 10;
lcd.setCursor(0,0);
lcd.print(Value);
lcd.print(" ");
else
Button_count = 100;
Value = Value + 100;
lcd.setCursor(0,0);
lcd.print(Value);
lcd.print(" ");
else
Button_count = 0;
Step 8: Enjoy It :)
There are many other ticks to manipulate a push button.
Wish you all share yours. :)
Be the First to Share
    • Fruits and Veggies Speed Challenge
    • Digital Fabrication Student Design Challenge
    • Leather Challenge
      Leather Challenge
    0507478785
    0507478785
    6 years ago
    good work dude ! its exactly what i was looking for !
