Fun With Acid!
Intro: Fun With Acid!
I'll show you something neat you can do with some easy to obtain acid.
STEP 1: Supplies
You'll need the following:
- Muriatic acid (hydrochloric acid)
You can find this at your local hardware or paint store.
- Small glass
- Some shiny pennies
Only pennies from 1982 and newer will work.
- Small glass
STEP 2: Grind Away
File away some of the copper on the side of the penny you don't want to keep.
In doing so, you'll expose the zinc inside.
STEP 3: Now for the Bubbly! (and an Explanation)
Put the penny in the glass with the exposed zinc facing up.
Next, pour in just enough acid to cover the top of the penny.
Leave it for several hours or overnight.
So what's going on in the glass?
The composition of U.S. pennies changed in 1982.
Before 1982 (for about 20 years), pennies were an alloy of about 94% copper and 6% zinc.
The increasing cost of copper made this impractical. Therefore, some 1982 pennies and all
pennies produced after that time have a pure copper shell with a zinc interior.
The new pennies contain only about 2.4% copper and weigh 2.5 grams as opposed to the 3.1-gram weight of the older type.
Zinc is a more active metal than copper. In this experiment, we see that zinc will react
with acid to produce hydrogen gas:
Zn(s) + 2 HCl(aq) => ZnCl 2(aq) + H 2(g)
The hydrogen gas generated by the reaction will bubble up because it is less dense
than the penny and the acid solution.
However, towards the end of the reaction some bubbles of hydrogen may adhere to the copper or be trapped inside the shell. If this occurs, the combination of copper and hydrogen gas may be less dense than the acid solution and what is left of the penny may float!
STEP 4: The Next Morning...
After the acid has finished reacting with the zinc, you will be left with a thin copper foil and a copper shell of a penny only one thousandth of an inch thick!
The shell will be very fragile, so use tweezers or a cotton swab to pull it out of the acid.
You can rinse the shell in the sink with some tap water.
NEVER, NEVER pour water into acid. Dispose of the acid by pouring it in the sink and then rinsing it down with water.
You can also neutralize the acid with some baking soda.
STEP 5: Clean It and You're Done!
Now carefully clean the inside of the shell with a cotton swab. Be sure to place it on a flat surface so you don't bend it.
Now you're done!
You can use the penny shell to hide a dime in for an oldie but goodie magic trick.
More information can be found in these fine books on Amazon.com:
Experiments That Explore Acid by M.Gutnik
365 Simple Science Experiments with Everyday Materials
Classic Chemistry Experiments by Hutchings
Now you're done!
56 Comments
DWinker 16 years ago
The Real Elliot 16 years ago
laci37 15 years ago
soapmaker72 8 years ago
Certainly, adding hydrochloric acid to water is far less dramatic. Still I notice a significant rise in temperature by adding 30+% into water. If that water is already 90 Celsius then you could get a POOF of HCl vapors in your face from the exothermic dilution.
skegger 16 years ago
lemonie 16 years ago
Grimling 16 years ago
minerug 16 years ago
mannys9130 15 years ago
minerug 15 years ago
FrozenFire 13 years ago
x z i t 15 years ago
James (pseudo-geek) 16 years ago
Supreme_Angler 16 years ago
Kataze 16 years ago
Silas 16 years ago
macingtosh 13 years ago
Kiteman 16 years ago
