Introduction: Fundamentals of Basketball: How to Dribble, Pass, and Shoot Effectively
When it comes to playing any sport, basketball included, a key component is understanding how and when to get closer to your objective. In this tutorial, the fundamentals of dribbling, passing, and shooting a basketball will be covered so that you can begin practicing and join the court soon enough.
Supplies:
- Basketball (or proper substitute)
- Basketball Hoop
Partner or Wall to Bounce against for Passing
Area to bounce basketball for:
- Dribbling
- Passing
Dribbling
Dribbling is the name given to bouncing the basketball to the floor and back to the player so that they may bring the ball across the court without a teammate’s help. This skill is key to keeping the basketball in your team’s possession while positioning properly.
When to Dribble:
- When you want to keep the ball to yourself
- When you are trying to decide the next action
- When you want to reposition yourself
- When you want to move the ball down the court when you cannot pass to a teammate
Step 1:
It is recommended to start using your dominant hand, and switching to your non-dominant hand once you have grown comfortable with the process. Begin by bouncing the basketball off of the floor, keeping one hand over the ball as it returns upwards
Step 2:
Try slowing the ball down with your fingertips as it bounces back to your hand
- Make sure to have your fingers loose. If your fingers are too stiff, it will begin hurting and will not allow you good control of the bounce.
- As the ball reaches the hand, allow your fingers to curl around the ball as it reaches the palm of your hand
Step 3:
Once you have grown comfortable with keeping your hand near the ball when it bounces, begin trying to push the ball downwards gently in order to keep it bouncing
- If you are struggling with this, continue tossing the ball on the floor to bounce it and keep your hand over it to get into a rhythm
Step 4:
As you add more force into your bounce, take care not to have the ball bounce higher than your chest or lower than your knees
Step 5:
Remember to try and keep the ball from bouncing from side to side. This will help in keeping the ball’s movement manageable.
- It is suggested to limit the range to your shoulder width
- A recommended height to stop the bounce is around your stomach height
Step 6:
Once you have began to consistently bounce the ball, try moving into a lower stance consisting of:
- Bending your knees
- Leaning slightly forward at the waist
- Having your arms bent at the elbows
Step 7:
Putting these steps together, you want to maintain your stance, bounce the ball down and create a steady pace while keeping the ball within the suggested range.
2 years ago
Thanks for sharing :)
