Introduction: GLOWING TREES!!!
MAKE YOUR TREES OR TREE POT GLOW UP BEAUTIFULLY AT NIGHT TIME USING THIS SIMPLE METHOD,.
Step 1: THINGS YOU WILL NEED
1)LED (AS MANY AN REQUIRED)(PREFERABLY GREEN COLOURED)
2)RESISTOR(100 OHMS X2)
3)5V 1A POWER SUPPLY OR 3V 1A POWER SUPPLY(NO RESISTOR NEEDED IN THIS CASE)
4)NAILS(TO PLLACE LEDS FIRMLY IN SAND)
Step 2: MAKING SETUP READY
TAKE LEDS AND WIRE THEM UP.
CONNECT POSITIVE TERMINSL TO RED WIRE OF ADAPTER AND NEGATIVE TERMINAL TO BLACK.MAKE SURE TO ATTACH 2 100OHM RESISTANCE IN PARALLEL TO PREVENT LEDS FROM GETTING DAMAGED.
USE LED CASE SO THAT ITS TERMINALS DONOT GET DESTROYED WITH TIME DUE TO EXPOSURE IN SAND AND WATER
PIERCE A NAIL THROUGH LED CASE TO FIX LED INSIDE MUD OR SAND.
Step 3: PLACING LEDS IN SAND
PLACE LEDS IN SAND
CONNECT ALL OF THEM IN PARALLEL.
MAKE SURE THAT THE POWER SOURCE OR ADAPTER WHICH YOU ARE USING MEETS THE POWER REQUIREMENTS.
IF YOU ARE USING 5V 1A POWER SOURCE THEN CONNECT 2 100 OHM RESISTANCES IN PARALLEL.
IF YOU ARE USING 3V 1A POWERSOURCE THEN NO NEED OF RESISTANCE. YOU CAN CONNECT LEDS DIRECTLY TO ADAPTER.
Step 4: TEST
ALL LEDS SHOULD GLOW IF YOU FOLLOWED MY INSTRUCTIONS CORRECTLY AND YOU CAN ENJOY YOUR TREES.
MAKE SURE THAT NO WIRE TOUCHES SAND AS WET SAND MAY CONDUCT ELECTRICITY AND IT MAY DAMAGE THE PLANT.
