Introduction: GPQ滑板
Skateboard sport is a favorite sport of many people. This work adds a hook, a ring and a handle on the basis of ordinary skateboard. Hooks and rings can be used to hang the skateboard when it is not in use, saving space and preventing people from stepping on it by mistake. Handle makes skateboard more portable.
Step 1: Step 1: Build the Base Board
The basic plate consists of three parts: 90x40x2 cuboid plate and two 14x40x2.95 semi-circular slightly warped plates. The semicircle plate is obtained by removing part of the material from the Angle plate.
Step 2: Step 2: Set Up the Support Gasket and Base.
The support gasket is a rectangular of 13x13x1, and the base is obtained by cutting the rectangular body of 10x6.5x5.
Step 3: Step 3: Establish the Scaffold Body
The bracket body consists of five parts: a 20x5x5 cylinder, a 5x8x1 semi-cylinder, a 2x1.5x3 elliptic cylinder, and two 3x14.7x3 cylinders.Arrange them as shown and dig a cavity of radius 7 between the cylinder and the semi-cylinder.
Step 4: Step 4: Set Up Shock
Shock absorbers consist of three parts: a 5.4x5.9x1.3 cylinder, one6.5x6.5x0.8 cylinder and a multi-point cylinder. The 4 and 5 radii of the 1-point cylinder are 4, and subtract 0.3 from both sides, forming according to this figure.
Step 5: Step 5: Add Tires
Add two 15x5x15 tires to the skateboard as shown in the figure.
Step 6: Step 6: Slide Forming
Duplicate the skateboard base and tire with the two bases and tires distributed symmetrically along the central axis of the skateboard.
Step 7: Step 7: Add Decoration
Step 8: Step 8: Add Hook and Ring
The hook consists of a 15x2x2 cylinder, a 20x2x2 cylinder and two 6x2x2 cylinders, and the ring consists of a 15x2x2 cylinder and a 10x10x2 ring.
Step 9: Step 9 Add the Tree
The handle consists of a 10x2x2 cylinder, two 2x5x2 members and two5.7x5.4x2 90 degree bend pipe composition. Two handles are symmetrically distributed on both sides of the slide.Using the handle is beneficial to improve the portability of skateboard.
Skateboard Contest
2 years ago
I like how you added the handles :)
