GameBoy CD Player
Intro: GameBoy CD Player
Build a CD player with an old GameBoy, an ATAPI drive and some electronics. The CD player it's a kind of game cartridge to play CD. This is the final version, plug it to a GameBoy and listen to music!
Wanna see how it works?
http://personales.ya.com/proyecto_gb/ ->down
the new web page is http://perso.wanadoo.es/jordi__87/
Do you like it? Give me feedback please!
STEP 1: Get a GameBoy!
First of all we will need some things:
-A GameBoy to show track information and control the playing.
-A GameBoy cartridge: we will need it to interface the GameBoy to a board.
-An ATAPI drive to play the CD.
-A 12v-5v power supply.
-An interface board: we can find it at http://personales.ya.com/proyecto_gb . Go to Hardware section and build the schematics. We will talk about later.
STEP 2: Let's Make a Cartridge!
We need to wire the GameBoy pins to a board. We can open it, but we prefer to preserve the GameBoy to play our favourite games. So let's make an adaptor cartridge. Get a boring game and open it with a screwdriver, be careful not to broke the board inside.Well Prince of Persia was not boring but I had no one else.
STEP 3: Cutting the Inside Chips.
We see some chips, the game program and some interface chips. We need to remove it, so let's use a cutter to cut it. We could use a soldering iron but that would wear away the board.
STEP 4: Wiring the Cartridge
Get a ribbon cable and solder it to the board following a logical order, I mean, the pin 1 of the cartridge to the pin 1 of the ribbon cable. I used an IDE cable as a ribbon cable.Follow the pins paths to get a termination solder point,it's easier and better(then you can close the cartrigde).Check for shortcircuits when you finish. If it's all ok, fix the cable to the board with glue.
STEP 5: Cutting the Plastic Case.
In order to put the cartridge inside we need to cut the plastic box. Use a cutter or a tool you consider better.
STEP 6: Building the Board
I will not cover the board construction process, but i will put the schematics and some comments. I've made modular schematics, you must interconnect them to have the complete board.Axx , Dxx and /RD,/WR,RESET signals come from the GameBoy cartridge.GND and +5V are common to the power supply,chips and GameBoy.You must burn the z80cdplayer.gb in the EPROM. Sorry it's in spanish I will translate it some day.
The schematics also are at http://personales.ya.com/proyecto_gb/
STEP 7: Putting It All Together
This is the last step. We must put it all in a box to make it useful. You can use a wood box,plastic box or even a cardboard box!! With imagination all it's possible.You can see how it works at videos section of http://personales.ya.com/proyecto_gb/
78 Comments
engquiky 12 years ago
It looks like the ship put into the Delorean in Back to the Future Part III !
dude22072 13 years ago
survivorwolf 13 years ago
cdmaster 13 years ago
mariomurder 15 years ago
Kasm279 13 years ago
mariomurder 13 years ago
Colonel88 14 years ago
dude22072 14 years ago
sc4rzz 14 years ago
What did you use to flash the chip?
I'm thinking about recreating this, only with an atapi to SD adapter, and flash to chip to play the roms from the SD... that would be epic. Now for the code.. anyone that can help me with that?
dfc849 17 years ago
ARVash 17 years ago
nature223 15 years ago
denniSinned 14 years ago
ReCreate 15 years ago
drummonkey92 15 years ago
dfc849 15 years ago
