Garbage Picked Desk to Gorgeous Portable Bar
Intro: Garbage Picked Desk to Gorgeous Portable Bar
I always tell my wife not to garbage pick items because she has no vision as to what project it can actually become. Go figure, I was asked to build a bar for my mother-in-law and ended up garbage picking a solid wood desk to use as the base and inspiration for this build. I ended up using primarily items I had laying around or picked up at an affordable price to make this build. The result is a great bar she can roll around the basement or roll outside to her covered deck area.
**This post contains affiliate links and I may be compensated if you make a purchase after clicking on my links.
STEP 1: Sand the Desk
We sanded this desk for hours and hours trying to work out any water marks and imperfections. We sanded from about an 80-100 grit, up to 150 grit, and finished off with 220 grit.
STEP 2: Seal in Any Stains And/or Smells
After the thorough sanding, we started to get a whiff of urine. My best guess is that the desk sat on the floor near where a cat or dog had an accident. You can only smell it directly on the bottom grain of the desk, so we decided to use Kilz Original Oil Based Primer and sealed the edge-grain at the bottom of the desk.
STEP 3: Add Caster Supports
In order to make sure the casters were anchored in, we added some 2x3 scrap of pine to the bottom of the desk using countersunk Spax screws, our forstner bits, and some dowels and glue. We trimmed the dowels using our Dremel Multi-Tool. We did this before our last round of sanding so that we could sand these supports as part of the last round.
STEP 4: Install Casters
We installed the casters using some wafer head screws we had laying around by pre-drilling and then driving the screws in. After they were fit in place, we removed them for a quick sand and prior to staining the bottom of the unit.
STEP 5: Stain the Desk
We decided to stain the desk at this point in time, but just the desk. We chose a darker stain, very similar to the finish it started with, so that any areas missed during sanding or imperfections would be less noticeable.
STEP 6: Trim the Top to Size
We wanted to make the top stand out, so we trimmed about an inch off of each side so it could be used to double the depth of the edge before adding a rounded edge.
STEP 7: Glue and Nail in Edge
We used our Ryobi nailer and some wood glue and mirrored the cut pieces so that the grains lined up perfectly.
STEP 8: Route and Sand Top
We used a round-over bit around the entire piece, top and bottom and then sanded down the entire piece.
STEP 9: Cut Mounting Brace
This took a little thinking, but we really wanted to use some black piping we had laying around. We needed to raise the top a few more inches from the desk (including casters) to get the height we wanted and to allow for some space for stemless glassware. To do this, we cut some scrap 1x4 pine down to the width of the flanges we were using and then cut them to length.
STEP 10: Attach Mounting Hardware
We affixed the flanges to the cut pine boards using some 1 inch wood screws we had laying around. Then we pre-drilled the matching flanges and affixed them to the desk at an angle. It was the only way we could think of to attach them given the limited space. We then removed the brace for staining.
STEP 11: Stain and Clear Coat the Top and Mounting Brace and Clear Coat the Desk
We chose a lighter stain for the top (actually changed stains after seeing the first selection) to allow for some contrast. We stained and used the Triple Thick Polyurethane on the top and the mounting braces. While we had the polyurethane out we cleared the desk as well. We used the think paintable polyurethane first and then used spray cans to finish off the units with at least 3 coats total.
STEP 12: Add Lighting Mounts
We got really, really creative for this step. We were going to add some battery powered string lights but didn't want to use hot glue or anything like that, so we decided to use staples. We stapled at roughly a 45 degree angle around the interior of the top and fed the lights through the staples after the unit was put together.
STEP 13: Mount the Top
We used 1 1/4 inch drywall screws left over from another project to mount the top. The mounting brace has to be affixed to the desk first, then using weights we drove an angled screw into the bottom of the top.
STEP 14: Cut Shelf
Although we wanted to make something more elaborate, like a wine rack and built in shelving, we decided to go low-key/low-tech. We measured and cut a piece of OSB board (scrap) to lay on trim under the desk. This allows the end user to potentially remove the shelf for a small dorm-size fridge or put any other storage options in that space. At the end we used some left-over spray paint and sprayed the shelf black.
STEP 15: Party!!!
We delivered the unit to my mother-in-law and tested out the lighting (although we couldn't get the room very dark). Overall, we think the bar turned out fantastic. It was a great way to re-use garbage from one of the neighbors. We definitely think she'll appreciate the portable nature of the bar so she can roll it outside and entertain guests outside on nice days. Let us know what you think and please check out our YouTube page, Subscribe, and give us a Like as you check out some of our other projects.
