Gas Saving Tip
Intro: Gas Saving Tip
Extend gas milage and save money, using acetone and xylene.
STEP 1: Fill Your Car..
Fill your car up with gas. All the way you can fill it up.
STEP 2: Acetone
Pour 2 ounces of acetone into a cup for every 10 gallons of gas.
STEP 3: Pour Into the Gas Tank..
Pour the 2 ounces of acetone into your gas tank.
STEP 4: Xylene
Pour 2 ounces of Xylene (Xylol has two names) into the cup for 10 gallons of gas.
STEP 5: Results
Acetone and Xylene work together to burn the gasoline even more than it would without them. It even becomes a bit stronger because it gives higher RPM's. It will take you several tries to see your results. It gave 75 extra miles on my Toyota Camry 98. Extend gas milage and same $$$ now!
34 Comments
1909tuc 8 years ago
Outlander 15 years ago
Already posted what happened to my suv on another thread when I tried this trick.
It does work, the reason why it works you have to understand that almost nothing burns as a liquid, your economic rice burner, it is about 30% eff. at best. The reason is that we use "atomized" fuel instead of vaporized, so most of the fuel goes right out the tail pipe, or burns in the exhaust system creating excess heat.
What the Acetone does when mixed with gasoline is helps it vaporize faster. If I remember right it helps break the surface tension or something else, it's been awhile.
Acetone's enemy in this is alcohol, what is ethanol? it's a type of alcohol, and it's in almost all gasoline now. Acetone mixed with gasoline/ethanol has the opposite effect and will decrease mileage.
Another bad thing is it will damage certain types of seals and plastic after long term use of the chemical. Some cars may suffer damage, some may not. It's really a guessing game.
The real answer would be of course to move to vaporized fuel and have 100mpg cars out there, but it will never happen. I personally don't see why not though, the gas companies could charge $20 a gallon if they went to vaporized gasoline.
edma194 15 years ago
dirac19 15 years ago
tcase4 11 years ago
earthwindwater 12 years ago
Here is just one example. All cars and trucks still require at least one and usually 2 catalytic converters. One of the jobs they perform is to "catalyze" the unused fuel that comes out of the exhaust manifold. That is why the converter is always hotter on the engine side.
Vapor is the ultimate goal. You should do some more research on this.
Please take this as constructive criticism only!
Take care.
edma194 12 years ago
I can and will comment to any open posts that permit member comments.
Again, you should do your homework, research, and your own applications before commenting on peoples posts.
littleangels 15 years ago
bombmaker2 15 years ago
patthesoundguy 15 years ago
jack the baptist 15 years ago
carpespasm 15 years ago
Crash2108 16 years ago
theburn7 15 years ago
HAL 9000 16 years ago
