Gas Sensor Using Arduino
Intro: Gas Sensor Using Arduino
We pass our day-to-day life with fun and joy. We use IOTs, Cloud Network, Computers as an aid to decrease work stress or for security. Still the truth is IOT or any other advanced technology is not available every where in this world.
My aim through this project is to give security to all the people around the world from lpg gas leak. We can prevent it from happening with the expenditure of few dollars.
In this work I will be using one gas sensor and two indicator led and a buzzer and we are using general arduino micro-controller.
Step 1: Get the components
1. Arduino Uno / Genuino uno board
https://www.sunfounder.com/genuino-uno-rev3-control-board.html
2. USB cable
3. Buzzer
https://www.amazon.com/Goliton-High-decibel-Electronic-Continuous-Arduino/dp/B01MT5V0FM/ref=sr_1_2?s=electronics&ie=UTF8&qid=1501340858&sr=1-2&keywords=buzzer
4. red and green leds
5. Breadboard
6. MQ5-LPG or gas sensor
https://www.amazon.com/WINGONEER-Combustible-Propane-Butane-/Detector/dp/B06XHKPV2Q/ref=sr_1_2?s=electronics&ie=UTF8&qid=1501340934&sr=1-2&keywords=mq+5
7. Jumper wires
STEP 1: Connections
Connections to this project is very simple just follow the table given below
The MQ-5 sensor has 4 pins.
Pin-------------------------------------Wiring to Arduino Uno
A0-------------------------------------Analog pins
D0-------------------------------------none
GND-----------------------------------GND
VCC------------------------------------5V
And for other components
D13------------------------------------- +ve of buzzer
GND------------------------------------- -ve of buzzer
D12------------------------------------- anode of red light
D11------------------------------------- anode of green light
GND------------------------------------- cathode of red light
In the end, connect the UNO board to the computer with a usb cable.
STEP 2: Code
Open Arduino IDE, write the code
code
DESIGNER : ADARSH C
DATE :12/8/17
WORK : GAS SENSOR
int red_led=12;
int green_led=11;
int buzz=13;
int gas_value;
int gas_avalue;
int sensorThres=400;
void setup()
pinMode(red_led,OUTPUT);
pinMode(buzz,OUTPUT);
pinMode(green_led,OUTPUT);
pinMode(A1,INPUT);
Serial.begin(9600);
void loop()
gas_avalue=analogRead(A0);
if (A0 > sensorThres)
digitalWrite(red_led, HIGH);
digitalWrite(green_led, LOW);
digitalWrite( buzz, HIGH);
Serial.println(“DANGER!!!!”);
Serial.println(gas_avalue);
else
digitalWrite(red_led, LOW);
digitalWrite(green_led, HIGH);
digitalWrite( buzz, LOW);
Serial.println(“NO LEAKAGE”);
delay(100);
STEP 3: NOTE :-
1. Select the board you are using in
Tools --> Board
otherwise it will give you an error while dumping the code
2. sometimes even selected com port will be diffrent so go to
Tools --> Port
and set the com port which you have connected the board
3. Sometimes sensor won't give a perfect value try changing gas threshold value in the program
4.If you are testing with lighter the amount of BUTANE produced is very less so it might take 2 or 3 seconds to detect
STEP 4: OUTPUT
OUTPUT
In the presence of LPG (BUTANE) it will glow red and buzzer will turn on
In the absence of LPG (BUTANE) it will glow green
5 Comments
GanganiR 5 years ago
Hey, After some changes work properly but they can't detect Natural Gas any idea about that?
I am posting my own code please verify that work properly but can't detect natural gas.
int red_led = 12;
int green_led = 11;
int gas_value = A1;
int buzzer = 10;
int sensorThres = 200;
void setup() {
// put your setup code here, to run once:
pinMode(red_led, OUTPUT);
pinMode(buzzer,OUTPUT);
pinMode(gas_value,INPUT);
Serial.begin(9600);
void loop() {
// put your main code here, to run repeatedly:
int analog_sensor = analogRead(gas_value);
if(analog_sensor > sensorThres)
digitalWrite(buzzer,HIGH);
Serial.println("Danger");
// Serial.println(gas_avalue);
} else {
digitalWrite(buzzer,LOW);
Serial.println("No leakage");
delay(100);
Adarsh C 4 years ago
Arsal Arain 6 years ago
Adarsh C 6 years ago
HI Arsal Arain,
the problem plz try tuning the gas sensor. In the gas sensor you eill be able to see a potentiometer (pot) plz vary it and try
Sorry for delay i wasnt so active
It doesn't glow led
