Gas Pipe Flashlight
Intro: Gas Pipe Flashlight
This instructable will show you how to build a LED flashlight.
STEP 1: Tools and Materials Needed
Tools
Soldering Iron
Hot Glue gun
Nail clippers
Wire strippers
Marker
Materials
1/2" Pipe Cap
4.5" x 1/2" Threaded Pipe
1/2" to 3/4" Pipe adapter
Perforated circuit board
Spring
Wire
Solder
Hot glue sticks
10 5mm LEDs
Sheet of foam
Shears or Dremel with cutting wheel
Soldering Iron
Hot Glue gun
Nail clippers
Wire strippers
Marker
Materials
1/2" Pipe Cap
Spring
Wire
Solder
Hot glue sticks
10 5mm LEDs
Sheet of foam
STEP 2: Cut the Perforated Circuit Board
Cut a circle out of the perforated circuit board that will fit inside the pipe adapter.
STEP 3: Dry Fit the LEDs
Put the LEDs into your circular circuit board to see how they fit. Then trim the LED leads and leave the longer lead slightly longer.
STEP 4: Solder the LEDs
First solder the LEDs to the circuit board. Then solder all the positive and all the negative LED leads together. Test your LED board with a 3 volt power source to make sure you have soldered the LEDs correctly.
STEP 5: Create a Spring
Create a spring for the flashlight.
STEP 6:
Screw your LED board into the steel adapter. Leave an uninsulated wire connected to the negative connection of the LED board hanging so it makes contact with the steel adapter when screwed in.
Test your connections. If it is working properly make a contact with a washer and some solder. Fill the area behind the contact with hot glue.
STEP 7:
Cut some foam spacers that go between the battery and the contact point. The spacers create a switch that is on when the adapter is tightened.
STEP 8:
Tweak the number of foam spacers so that the flashlight turns on only when the adapter is tightened.
35 Comments
Nemesistant 11 years ago
tyler303047 12 years ago
jk a very very useful instructable.
snowluck2345 13 years ago
Nyanman 13 years ago
both a flashlight AND a holdout weapon.
seriously, how much does it weigh?
kurshiukas 13 years ago
Wasagi 13 years ago
DaPope 13 years ago
rossjima 13 years ago
Skyfinity 13 years ago
Congratulations on bing featured on the Make: Magazine blog!!! Way Cool.
qxnixrfnaozqqx 13 years ago
omnibot 13 years ago
bombmaker2 13 years ago
djdole 13 years ago
junits15 13 years ago
ScubaSteve 13 years ago
swinfos 13 years ago
