General Tso's (mostly Natural) Lozenges
Intro: General Tso's (mostly Natural) Lozenges
I don't get sick often but growing up I was getting Strep throat every year; luckily I haven't had it for a few years. Right now I can almost feel it coming on so I was looking into prevention/home remedies because I'm currently on the Curonian Spit, in Lithuania, which is quite isolated...So for a variety of reasons I came up with this recipe to prevent/cure my Strep Throat paranoia, based on some research.
The basic principle of how these lozenges work come from this video, which suggests that it works just like antibiotics: http://youtu.be/P10JNNvyH-k
...but it's basically "get-better tea" in lozenge form and it's really easy to make.
The recipe makes between 50-60 drops; one should be taken every half-full hour hour, that you're awake, until you feel better.
Ingredients (+ why they work):
Medicinal uses of common herbs/spices from UCLA's website
Tools:
Optional (but useful):
- 4tbsp honey (coats the throat, antibacterial and anti-inflammatory)
- 1/2c sugar (hardens into a solid)
- 1tsp cayennepowder(brings blood to surfaces which it touches, boosts circulation, high source of Vitamin A + C, has the complete B complexes, AND is very rich in organic calcium and potassium...among other things)
- 4 cloves of garlic, finely chopped or grated (stimulates the immune system, reduces pain, antibiotic as well as being anti-fungal/viral/parasitic...etc.)
- 1tsp ginger , finely chopped or grated (reduces inflammation and antiviral are the uses we'll concentrate on for this recipe)
- a pinch of salt (flavor and is less irritating to the mucous membranes in the mouth)
- zest from your favorite citrus (antibacterial, antifungal, aromatic, boosts metabolism)
Tools:
- A small saucepan w/ lid
- A sharp knife
- A spoon
- A citrus zester/micro-plane or cheese grater with a fine grade
- A non-stick surface
- A candy thermometer
STEP 1: Make a Sweet and Spicy Danger-sauce.
Mix the honey, sugar and cayenne in a small saucepan and bring to a boil. Once boiling, cover for 4 minutes.
STEP 2: Drop It Like It's Hot.
Remove the cover of your boiling honey/sugar/cayenne mixture and once it reaches 295/300 degrees Fahrenheit or 146/148 degrees Celsius remove it from the heat...You can use your candy thermometer for this or, if your like me, you don't have one at the moment and then you can do a drop test: drop a small amount of the candy mixture into cold/icy water, if it becomes a brittle mass/threads then it's at the right temperature and you should remove the saucepan from the heat.
I didn't have a candy thermometer or ice so I went and got some snow and poured water in the middle of it. In the second picture you can see some little hard balls in my snowater.
For more non-thermometer ways of telling what stage your candy is at check this out: http://www.ehow.com/how_7778842_tell-temperature-candy-thermometer.html
Once it's ready remove the mixture from the heat and let it cool for 5 minutes.
STEP 3: Flavor Bomb
This is when you're going to add, and mix in, most of the flavor and some of the best of the medicine (salt, ginger, garlic, citrus zest) to your cooling honey/cayenne/sugar mixture.
The reason you add it now, and not earlier, is because you don't want to destroy/modify the acting compounds in the ginger, garlic, and citrus zest.
STEP 4: Pop Off and Go Loco!
Now your part in lozenge making is almost done. With the honey/sugar/cayenne mixture cooled for 5 minutes and the citrus zest/garlic/ginger/salt mixed in you can start pouring the mixture onto your non-stick surface. Drop 1/2 teaspoons of the mixture onto your nonstick surface, making sure to leave some space between the drops (because they spread a bit). I couldn't find a silicone mat, parchment or wax paper so I just used 2 non-stick frying pans.
Allow them to cool for 30 minutes and you should have brittle lozenges which sooth your throat and provide a constant stream of ingredients which kill viruses/bacteria/fungi while increasing blood flow and a host of other awesome properties.
Stay well!
Stay well!
106 Comments
Pamela Gaffney 11 years ago
Great idea, good 'ible - thanks a bunch!
Flagg707 11 years ago
They do have a good spicy zing to them. I made the mistake of not letting the honey/sugar/cayenne mixture reach the proper temperature, even though I had let it go the four minutes. I pulled the sauce pan too early as the cayenne smell made me think it might be burning. I now have chewy lozenges with a "Bit-O-Honey" consistency. Still very tasty and my sinuses are open and happy.
Also, careful when dropping onto the parchment paper (or other non-stick surface) as it is easy to make big ones. My lozenges are a bit larger than recommended here (I made 40 instead of the 50-60).
Note to you single people out there, don't take these before going out on a date! The garlic makes itself known.
I can see all kinds of alternative ways to use this "platform." I highly recommend it.
merilalla 11 years ago
I used pure cane sugar and raw honey, and as my once fresh ginger root had shriveled, I used a tsp of organic powdered ginger. I passed the whole thing through a sieve once the flavors had a chance to amalgamate for a few minutes, but I must have screwed up the temp, cause mine, while "delicious" came out more like toffee than hard drops. WIll have to try again with white sugar and the right temp. Still can't stop eating them :-) thanks soo much for this great recipe!
Justin Tyler Tate 11 years ago
shutLNdevR 11 years ago
No word on their medicinal properties but if I miss the nasty flu that's going around I will ascribe all my success to General Tso's Lozenges. I always did feel like Hot n' Sour Soup was a great cure-all for colds... so this is the portable version.
Definitely something to share with a spicy or aromatics-loving friend. Next stop- sriracha caramels? Mmmm...
duckspeaker 11 years ago
GayleJ 9 years ago
I'm going to give these a try. I made some herbal tea "cough drops" last night, but they are quite bitter (horehound, marshmallow root, and some others) so my children are refusing them, though the sore throats were quickly soothed with use of them. I am going to make these for hubby & I, then a less spicy variation with cinnamon for my littles.
Just my experience with making hard candy is, adding something to your cooked candy mixture after its hit hard crack stage & been removed from the heat, is going to cause it to separate. So I will try once your way, then if it doesn't work, I'll add the "goodies" in the last few seconds of stirring and cooking after I hit hard crack. Oh, one other thing, not stirring your sugar/honey mixture & just cooking it with a lid on can be dangerous and also cause your candy to burn -- scorched candy is an awful thing to get off a pan. I always, ALWAYS cook my hard candy mixtures on medium heat while stirring. Too many bad experiences of ignoring it; I firmly dislike scraping burned sugar off my pans, so I stir. Also, for anyone else who finds this recipe (and reads through all the comments like me), put hot, preferably boiling, water into your pot after you've got the drops made -- it cuts down on the cleaning process dramatically. I sometimes use cooking spray to coat the inside of my candy-cooking pan too, that little bit of oil keeps your mixture from bubbling too much.
Thank you for posting your recipe, and the YouTube video link -- I passed that one along to a friend who has strep this week.
Emily_Gant 9 years ago
I've got a sinus infection, and boy let me tell you! This is not fun to deal with being a full time student (and its midterm exam week!) and working full time as well! I have a bad stomach so antibiotics and medications don't sit well with me and end up making me feel ten times worse! So Pinterest is my best friend when it comes to remedies! I am so happy I found this because I felt like I was dying with my cough and other symptoms, this is a great help!! I used clove honey and blood orange zest. It's awesome! Thanks for the help!
Dominic Bender 10 years ago
TidyKeeper 11 years ago
Used wax paper. Should have used the nonstick pan. Can't get the drops off of the paper.
Good stuff! Thanks for posting!
TN777 11 years ago
Aira.vj 11 years ago
lordgarion514 11 years ago
But I will be trying these out as a preventative. The science behind them seems quite sound, but there are some diseases that just should not be played around with.
kalimo 11 years ago
avenger2109 11 years ago
