Introduction: Gesture Control Mouse
About: YouTube Content Creator 📽️ Robotics Enthusiast / Maker 🤖 Learn to make robots that are beyond your imagination 🚀
Greetings everyone, and welcome to my Instructables tutorial. Today, I'll guide you through the process of creating an Gesture Control Mouse.
Project Overview:
In this project, a gesture-controlled mouse is developed using a Node MCU, MPU 6050, and a flex/bend sensor. The MPU 6050, leveraging its gyro and accelerometer, moves the mouse pointer in all directions, while the bend sensor triggers a right-click when bent. Initially prototyped on a breadboard, the system is tested in scenarios like playing Asphalt 8 game and scrolling the roboattic Lab website. This innovative, sensor-based design is lightweight and runs efficiently on low-spec PCs, unlike camera-based gesture systems that require heavy computational resources, making it an ideal, accessible choice for college or school projects.
Before beginning a huge shoutout to JLCMC for sponsoring.
Now, let's get started with our project!
Electronic Components Required:
  1. Node MCU
  2. MPU 6050
  3. 47 KΩ
  4. Flex/Bend Sensor
  5. Breadboard
  6. Dotted PCB Board
  7. 18650 Battery
  8. 18650 Battery Holder
Additional Tools:
  1. Soldering Iron
  2. Hot Glue
  3. Cutter
Softwares:
  1. Arduino IDE
  2. VS Code
Step 1: Breadboard Assembly
What You Need to Do:
  1. First, gently pop the Node MCU and MPU 6050 onto the breadboard—don't worry, they fit in nicely!
  2. Next, connect the VCC and GND pins of the MPU 6050 to the 3.3V and ground pins on your Node MCU respectively.
  3. Then, hook up the communication lines: connect SDA to the Node MCU's D2 pin and SCL to its D1 pin. These connections are super important because they let the components “talk” to each other.
A Quick Tip:
Make sure you double-check every wire connection. Trust me, a loose wire can become a real headache later on!
Step 2: Installing Required Libraries
To ensure smooth execution of your Python and Arduino code, install the necessary libraries as outlined below.
Python Libraries:
For Python, create a `requirements.txt` file with the following contents:
requests
numpy
pyautogui
Then, install all required packages using the following command in your terminal or command prompt:
pip install -r requirements.txt
Arduino Libraries:
For your .ino (Arduino) code, you need to install the following libraries:
1. ESP8266WiFi
This library allows the ESP8266 module to connect to Wi-Fi.
Installation Steps:
  1. Open Arduino IDE.
  2. Go to File > Preferences.
  3. In the "Additional Board Manager URLs" field, add:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
  1. Go to Tools > Board > Boards Manager.
  2. Search for ESP8266 and install the package ESP8266 by ESP8266 Community.
  3. This will also install the ESP8266WiFi library automatically.
2. Adafruit_MPU6050
Supports the MPU6050 accelerometer and gyroscope sensor.
Installation Steps:
  2. Go to Sketch > Include Library > Manage Libraries.
  3. In the Library Manager, search for Adafruit MPU6050.
  4. Click Install.
  5. For more details, visit the Adafruit MPU6050 GitHub repository.
3. Adafruit_Sensor
Provides a unified sensor interface.
Installation Steps:
  3. Search for Adafruit Unified Sensor.
  4. Click Install.
Step 3: Basic Code to Fetch API
Okay, now it’s time to wake everything up with some basic code! Here’s what you do:
  1. Open up your Arduino IDE and upload the basic code to your Node MCU.
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <Wire.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
// WiFi credentials
const char* ssid = "YourWiFiName"; // Replace with your WiFi network name
const char* password = "YourPassword"; // Replace with your WiFi password
ESP8266WebServer server(80);
Adafruit_MPU6050 mpu;
void setup() {
Serial.begin(115200);
Wire.begin(D2, D1); // SDA=D2, SCL=D1
// Initialize MPU6050
if (!mpu.begin()) {
Serial.println("Failed to find MPU6050 chip");
while (1) {
delay(10);
// Configure sensor settings
mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
mpu.setGyroRange(MPU6050_RANGE_500_DEG);
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.print("Connecting to WiFi");
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
// Define server routes
server.on("/", handleRoot);
server.on("/data", handleData);
// Start server
server.begin();
Serial.println("HTTP server started");
void loop() {
server.handleClient();
void handleRoot() {
String html = "<!DOCTYPE html>\n";
html += "<html>\n";
html += "<head>\n";
html += "<title>MPU6050 Sensor Data</title>\n";
html += "</head>\n";
html += "<body>\n";
html += "<h1>MPU6050 Sensor Web Server</h1>\n";
html += "<p>Use the /data endpoint to get sensor readings in JSON format</p>\n";
html += "<p>Server IP: " + WiFi.localIP().toString() + "</p>\n";
html += "</body>\n";
html += "</html>\n";
server.send(200, "text/html", html);
void handleData() {
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
// Create JSON response
String json = "{";
json += "\"accelerometer\": {";
json += "\"x\": " + String(a.acceleration.x) + ", ";
json += "\"y\": " + String(a.acceleration.y) + ", ";
json += "\"z\": " + String(a.acceleration.z);
json += "}, ";
json += "\"gyroscope\": {";
json += "\"x\": " + String(g.gyro.x) + ", ";
json += "\"y\": " + String(g.gyro.y) + ", ";
json += "\"z\": " + String(g.gyro.z);
json += "}, ";
json += "\"temperature\": " + String(temp.temperature);
json += "}";
server.send(200, "application/json", json);
  1. Once the code is uploaded, check the serial monitor. You should see a local server IP appear. That’s your magic number!
  2. Open up your VS Code and copy & paste this code:
import requests
import json
import time
from colorama import Fore, Style, init
init()
def fetch_data(ip_address):
try:
response = requests.get(f"http://{ip_address}/data", timeout=2)
if response.status_code == 200:
return json.loads(response.text)
else:
print(f"{Fore.RED}Error: Received status code {response.status_code}{Style.RESET_ALL}")
return None
except requests.exceptions.RequestException as e:
print(f"{Fore.RED}Error connecting to server: {e}{Style.RESET_ALL}")
return None
def print_data(data):
if data is None:
return
print("\033c", end="") # Clear the terminal screen
print(f"{Fore.CYAN}===== MPU6050 Sensor Data ====={Style.RESET_ALL}")
print(f"{Fore.GREEN}Acceleration (m/s²):{Style.RESET_ALL}")
print(f" X: {data['accel_x']:.4f}")
print(f" Y: {data['accel_y']:.4f}")
print(f" Z: {data['accel_z']:.4f}")
print(f"{Fore.GREEN}Gyroscope (rad/s):{Style.RESET_ALL}")
print(f" X: {data['gyro_x']:.4f}")
print(f" Y: {data['gyro_y']:.4f}")
print(f" Z: {data['gyro_z']:.4f}")
print(f"{Fore.YELLOW}Temperature: {data['temp']:.2f}°C{Style.RESET_ALL}")
print(f"{Fore.CYAN}============================={Style.RESET_ALL}")
def main():
# Ask for the NodeMCU IP address
ip_address = input("Enter the NodeMCU IP address: ")
print(f"Connecting to NodeMCU at {ip_address}...")
print("Press Ctrl+C to stop")
try:
while True:
data = fetch_data(ip_address)
print_data(data)
time.sleep(0.1)
except KeyboardInterrupt:
print("\nExiting program")
if __name__ == "__main__":
main()
  1. Now, take that IP address and paste it into your Python code in VS Code. Hit the run button, and boom—you should see the MPU 6050’s gyro and accelerometer data streaming in your terminal.
Step 4: Elevate Your Electronic Projects - JLCMC
JLCMC is your one-stop shop for all electronic manufacturing needs, offering an extensive catalog of nearly 600,000 SKUs that cover hardware, mechanical, electronic, and automation components. Their commitment to guaranteeing genuine products, rapid shipping (with most in-stock items dispatched within 24 hours), and competitive pricing truly sets them apart. In addition, their exceptional customer service ensures you always get exactly what you need to bring your projects to life.
To show their support for our community, JLCMC is offering an exclusive $19 discount coupon. This is the perfect opportunity to save on high-quality components for your next project. Don’t miss out—visit https://jlcmc.com/?from=RBL to explore their amazing range of products and grab your discount coupon today!
Step 5: Let’s Make the Mouse Cursor Move
Alright, now for the really fun part—moving the cursor with your hand! Here’s what you need to do:
  1. First, update your Node MCU code and upload it.
#include <Wire.h>
// WiFi credentials
// Use static IP to prevent IP address changes
IPAddress staticIP(192, 168, 31, 212); // The IP you want to assign to NodeMCU
IPAddress gateway(192, 168, 31, 1); // Your router's IP address (typical gateway)
IPAddress subnet(255, 255, 255, 0); // Subnet mask
IPAddress dns(8, 8, 8, 8); // DNS (Google's DNS)
void setup() {
delay(100); // Short delay for serial to initialize
Serial.println("\n\nMPU6050 Web Server Starting...");
// Initialize I2C for MPU6050
if (!mpu.begin()) {
Serial.println("Please check your wiring!");
while (1) {
delay(10);
Serial.println("MPU6050 Found!");
// Configure WiFi in station mode with static IP
WiFi.mode(WIFI_STA);
WiFi.config(staticIP, gateway, subnet, dns); // Set static IP
Serial.println("Connecting to WiFi...");
// Wait for connection with timeout
int timeout = 0;
while (WiFi.status() != WL_CONNECTED && timeout < 20) {
delay(500);
Serial.print(".");
timeout++;
if (WiFi.status() != WL_CONNECTED) {
Serial.println("\nFailed to connect to WiFi! Check credentials and try again.");
while(1) {
delay(1000);
Serial.println("");
Serial.print("Connected to WiFi network: ");
server.on("/", HTTP_GET, handleRoot);
server.on("/data", HTTP_GET, handleData);
server.onNotFound(handleNotFound);
// Start server
server.begin();
Serial.println("Web interface available at http://" + WiFi.localIP().toString());
Serial.println("Data endpoint available at http://" + WiFi.localIP().toString() + "/data");
void loop() {
delay(2); // Small delay to improve stability
void handleRoot() {
html += "<html>\n";
html += "<head>\n";
html += "<meta http-equiv='refresh' content='5'>\n"; // Auto-refresh page every 5 seconds
html += "<style>\n";
html += "body { font-family: Arial, sans-serif; margin: 20px; }\n";
html += "h1 { color: #0066cc; }\n";
html += "p { margin: 10px 0; }\n";
html += ".data { font-family: monospace; background-color: #f0f0f0; padding: 10px; border-radius: 5px; }\n";
html += "</style>\n";
html += "<body>\n";
html += "<p>Server is running successfully!</p>\n";
html += "<p>Server IP: <strong>" + WiFi.localIP().toString() + "</strong></p>\n";
html += "<p>Get raw data at: <a href='/data'>/data</a> (JSON format)</p>\n";
// Get current sensor data
html += "<div class='data'>\n";
html += "<h2>Current Sensor Data:</h2>\n";
html += "<p>Accelerometer (m/s²):<br>\n";
html += "X: " + String(a.acceleration.x) + "<br>\n";
html += "Y: " + String(a.acceleration.y) + "<br>\n";
html += "Z: " + String(a.acceleration.z) + "</p>\n";
html += "<p>Gyroscope (rad/s):<br>\n";
html += "X: " + String(g.gyro.x) + "<br>\n";
html += "Y: " + String(g.gyro.y) + "<br>\n";
html += "Z: " + String(g.gyro.z) + "</p>\n";
html += "<p>Temperature: " + String(temp.temperature) + " °C</p>\n";
html += "</div>\n";
void handleData() {
// Enable CORS to allow requests from any origin
server.sendHeader("Access-Control-Allow-Origin", "*");
server.sendHeader("Access-Control-Allow-Methods", "GET");
server.sendHeader("Access-Control-Max-Age", "10000");
server.sendHeader("Access-Control-Allow-Headers", "Content-Type");
String json = "{";
json += "}, ";
json += "}, ";
json += "}";
void handleNotFound() {
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i = 0; i < server.args(); i++) {
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
  1. Open up your VS Code and copy & paste this code. We’re using pyautogui here to map the MPU 6050’s gyro data directly to your cursor movement. Basically, when you tilt the sensor left, the cursor moves left, and when you tilt right, it follows along.
import requests
import json
import time
import numpy as np
import pyautogui
import math
from collections import deque
import threading
import tkinter as tk
from tkinter import ttk
# Configuration
NODEMCU_IP = '192.168.XX.XXX' # Your NodeMCU IP
DATA_URL = f'http://{NODEMCU_IP}/data'
CONNECTION_TIMEOUT = 3 # Increase timeout to 3 seconds
MAX_RETRIES = 5 # Maximum number of retries on connection failure
# Settings for mouse control
MOUSE_SENSITIVITY_X = 50.0 # Higher value = less sensitive
MOUSE_SENSITIVITY_Y = 50.0
GYRO_THRESHOLD = 0.05 # Minimum gyro movement to register (eliminates jitter)
SCREEN_WIDTH, SCREEN_HEIGHT = pyautogui.size()
SMOOTHING_WINDOW = 5 # Number of samples for smoothing
# For click detection
CLICK_THRESHOLD = 2.0 # Threshold for click detection (acceleration magnitude)
CLICK_COOLDOWN = 1.0 # Seconds between clicks to avoid accidental double-clicks
# For safety (prevent mouse from going crazy)
pyautogui.FAILSAFE = True # Move mouse to corner to abort
# For UI
UPDATE_INTERVAL = 50 # milliseconds
# Global variables
last_click_time = 0
is_paused = False
is_running = True
show_debug = True
baseline_accel = {"x": 0, "y": 0, "z": 0}
baseline_gyro = {"x": 0, "y": 0, "z": 0}
calibration_samples = 20
mouse_pos = {"x": SCREEN_WIDTH // 2, "y": SCREEN_HEIGHT // 2}
# Smoothing buffers
accel_history = {"x": deque(maxlen=SMOOTHING_WINDOW),
"y": deque(maxlen=SMOOTHING_WINDOW),
"z": deque(maxlen=SMOOTHING_WINDOW)}
gyro_history = {"x": deque(maxlen=SMOOTHING_WINDOW),
# Create UI
root = tk.Tk()
root.title("Gesture Mouse Control")
root.geometry("600x400")
root.protocol("WM_DELETE_WINDOW", lambda: set_running(False))
def set_running(state):
global is_running
is_running = state
if not state:
root.destroy()
def toggle_pause():
global is_paused
is_paused = not is_paused
pause_btn.config(text="Resume" if is_paused else "Pause")
status_var.set("PAUSED" if is_paused else "RUNNING")
def toggle_debug():
global show_debug
show_debug = not show_debug
debug_btn.config(text="Hide Debug" if show_debug else "Show Debug")
def start_calibration():
global baseline_accel, baseline_gyro
status_var.set("Calibrating... Don't move the sensor!")
root.update()
# Reset baselines
# Collect samples
accel_samples = {"x": [], "y": [], "z": []}
gyro_samples = {"x": [], "y": [], "z": []}
for _ in range(calibration_samples):
data = fetch_data()
if data:
for axis in ["x", "y", "z"]:
accel_samples[axis].append(data["accelerometer"][axis])
gyro_samples[axis].append(data["gyroscope"][axis])
time.sleep(0.1)
# Calculate averages
if accel_samples[axis]: # Check if we got samples
baseline_accel[axis] = sum(accel_samples[axis]) / len(accel_samples[axis])
baseline_gyro[axis] = sum(gyro_samples[axis]) / len(gyro_samples[axis])
status_var.set("Calibration complete")
sensitivity_x_var.set(MOUSE_SENSITIVITY_X)
sensitivity_y_var.set(MOUSE_SENSITIVITY_Y)
# Reset position to center
global mouse_pos
pyautogui.moveTo(mouse_pos["x"], mouse_pos["y"])
def update_sensitivity():
global MOUSE_SENSITIVITY_X, MOUSE_SENSITIVITY_Y
try:
MOUSE_SENSITIVITY_X = float(sensitivity_x_var.get())
MOUSE_SENSITIVITY_Y = float(sensitivity_y_var.get())
except ValueError:
pass # Ignore invalid inputs
def fetch_data():
"""Fetch data from NodeMCU with retries"""
for attempt in range(MAX_RETRIES):
try:
response = requests.get(DATA_URL, timeout=CONNECTION_TIMEOUT)
status_var.set("Connected")
else:
status_var.set(f"Error: Server returned {response.status_code}")
time.sleep(0.5)
status_var.set(f"Connection error: {type(e).__name__}")
time.sleep(0.5)
return None
def smooth_data(data, history_buffer):
"""Apply smoothing to sensor data"""
history_buffer.append(data)
return sum(history_buffer) / len(history_buffer)
def detect_click(accel_data):
"""Detect a click gesture based on acceleration"""
global last_click_time
current_time = time.time()
# Calculate acceleration magnitude
accel_mag = math.sqrt(accel_data["x"]**2 + accel_data["y"]**2 + accel_data["z"]**2)
# Check if it exceeds threshold and enough time has passed since last click
if accel_mag > CLICK_THRESHOLD and current_time - last_click_time > CLICK_COOLDOWN:
last_click_time = current_time
return True
return False
def process_sensor_data(data):
"""Process sensor data and control mouse"""
global mouse_pos
if not data or is_paused:
return
# Get accelerometer and gyroscope data
accel = data["accelerometer"]
gyro = data["gyroscope"]
# Apply calibration
calibrated_accel = {
"x": accel["x"] - baseline_accel["x"],
"y": accel["y"] - baseline_accel["y"],
"z": accel["z"] - baseline_accel["z"]
calibrated_gyro = {
"x": gyro["x"] - baseline_gyro["x"],
"y": gyro["y"] - baseline_gyro["y"],
"z": gyro["z"] - baseline_gyro["z"]
# Apply smoothing
calibrated_accel[axis] = smooth_data(calibrated_accel[axis], accel_history[axis])
calibrated_gyro[axis] = smooth_data(calibrated_gyro[axis], gyro_history[axis])
# Calculate mouse movement - using gyro for more precise control
# Invert axes as needed based on sensor orientation
dx = -calibrated_gyro["y"] if abs(calibrated_gyro["y"]) > GYRO_THRESHOLD else 0
dy = calibrated_gyro["x"] if abs(calibrated_gyro["x"]) > GYRO_THRESHOLD else 0
# Scale the movement
dx = dx * (SCREEN_WIDTH / MOUSE_SENSITIVITY_X)
dy = dy * (SCREEN_HEIGHT / MOUSE_SENSITIVITY_Y)
# Update position
mouse_pos["x"] += dx
mouse_pos["y"] += dy
# Constrain to screen boundaries
mouse_pos["x"] = max(0, min(SCREEN_WIDTH - 1, mouse_pos["x"]))
mouse_pos["y"] = max(0, min(SCREEN_HEIGHT - 1, mouse_pos["y"]))
# Move the mouse
# Check for click gesture
if detect_click(calibrated_accel):
pyautogui.click()
click_label.config(text="CLICK!")
root.after(500, lambda: click_label.config(text=""))
# Update UI
if show_debug:
accel_label.config(text=f"Accel: X: {calibrated_accel['x']:.2f}, Y: {calibrated_accel['y']:.2f}, Z: {calibrated_accel['z']:.2f}")
gyro_label.config(text=f"Gyro: X: {calibrated_gyro['x']:.2f}, Y: {calibrated_gyro['y']:.2f}, Z: {calibrated_gyro['z']:.2f}")
mouse_label.config(text=f"Mouse: X: {mouse_pos['x']:.0f}, Y: {mouse_pos['y']:.0f}")
def update_ui():
"""Update UI and process data periodically"""
if is_running:
data = fetch_data()
if data:
root.after(UPDATE_INTERVAL, update_ui)
# Create UI elements
frame = ttk.Frame(root, padding="10")
frame.pack(fill=tk.BOTH, expand=True)
# Status
status_frame = ttk.LabelFrame(frame, text="Status")
status_frame.pack(fill=tk.X, expand=True, pady=5)
status_var = tk.StringVar(value="Initializing...")
status_label = ttk.Label(status_frame, textvariable=status_var, font=("Arial", 12))
status_label.pack(pady=5)
click_label = ttk.Label(status_frame, text="", font=("Arial", 16, "bold"), foreground="red")
click_label.pack()
# Debug info
debug_frame = ttk.LabelFrame(frame, text="Sensor Data")
debug_frame.pack(fill=tk.X, expand=True, pady=5)
accel_label = ttk.Label(debug_frame, text="Accel: X: 0.00, Y: 0.00, Z: 0.00")
accel_label.pack(anchor=tk.W)
gyro_label = ttk.Label(debug_frame, text="Gyro: X: 0.00, Y: 0.00, Z: 0.00")
gyro_label.pack(anchor=tk.W)
mouse_label = ttk.Label(debug_frame, text="Mouse: X: 0, Y: 0")
mouse_label.pack(anchor=tk.W)
# Settings
settings_frame = ttk.LabelFrame(frame, text="Settings")
settings_frame.pack(fill=tk.X, expand=True, pady=5)
# X sensitivity
sensitivity_x_frame = ttk.Frame(settings_frame)
sensitivity_x_frame.pack(fill=tk.X, expand=True, pady=2)
ttk.Label(sensitivity_x_frame, text="X Sensitivity:").pack(side=tk.LEFT)
sensitivity_x_var = tk.StringVar(value=str(MOUSE_SENSITIVITY_X))
sensitivity_x_entry = ttk.Entry(sensitivity_x_frame, textvariable=sensitivity_x_var, width=8)
sensitivity_x_entry.pack(side=tk.LEFT, padx=5)
# Y sensitivity
sensitivity_y_frame = ttk.Frame(settings_frame)
sensitivity_y_frame.pack(fill=tk.X, expand=True, pady=2)
ttk.Label(sensitivity_y_frame, text="Y Sensitivity:").pack(side=tk.LEFT)
sensitivity_y_var = tk.StringVar(value=str(MOUSE_SENSITIVITY_Y))
sensitivity_y_entry = ttk.Entry(sensitivity_y_frame, textvariable=sensitivity_y_var, width=8)
sensitivity_y_entry.pack(side=tk.LEFT, padx=5)
# Apply button
ttk.Button(settings_frame, text="Apply Settings", command=update_sensitivity).pack(pady=5)
# Buttons
buttons_frame = ttk.Frame(frame)
buttons_frame.pack(fill=tk.X, expand=True, pady=10)
calibrate_btn = ttk.Button(buttons_frame, text="Calibrate", command=start_calibration)
calibrate_btn.pack(side=tk.LEFT, padx=5)
pause_btn = ttk.Button(buttons_frame, text="Pause", command=toggle_pause)
pause_btn.pack(side=tk.LEFT, padx=5)
debug_btn = ttk.Button(buttons_frame, text="Hide Debug", command=toggle_debug)
debug_btn.pack(side=tk.LEFT, padx=5)
ttk.Button(buttons_frame, text="Exit", command=lambda: set_running(False)).pack(side=tk.RIGHT, padx=5)
# Instructions
instructions = """
INSTRUCTIONS:
1. Click 'Calibrate' and keep the sensor still
2. Tilt to move cursor
3. Quick shake for mouse click
4. Adjust sensitivity if needed
ttk.Label(frame, text=instructions, justify=tk.LEFT).pack(anchor=tk.W, pady=5)
# Start the data processing
root.after(1000, update_ui)
# Center mouse position at start
pyautogui.moveTo(SCREEN_WIDTH // 2, SCREEN_HEIGHT // 2)
# Start UI
root.mainloop()
Step 6: Setting Up the Flex Sensor for Right-Click Action
Alright, let’s get into the fun part—adding the ability to click with our setup! We’ve already got the MPU 6050 and Node MCU working together to move the cursor by tilting the breadboard (pretty cool, right?). Now, we’re bringing in a flex sensor to handle right-clicks.
Powering the Flex Sensor:
  1. Connect the positive leg of the flex sensor to the 3.3V pin on the NodeMCU.
  2. This provides the necessary power for the sensor to function.
Connecting the Sensor Output:
  1. Attach the negative leg of the flex sensor to the A0 (analog) pin of the NodeMCU.
  2. Since the flex sensor provides analog data (a range of values depending on its bend), the A0 pin is ideal for reading these variations.
Adding a Resistor for Voltage Division:
  1. Place a 47K Ohm resistor between the negative leg of the flex sensor and GND (ground) of the NodeMCU.
  2. This forms a voltage divider, allowing the NodeMCU to correctly interpret the sensor’s changes.
Uploading the Code:
  1. Flash the provided Arduino code onto the Node MCU to enable it to process the sensor readings and send click signals to the computer. .ino file is attached in this step. Download it and open it in Arduino IDE.
Updating the Python Script:
  1. Modify the Python script with the updated code to ensure proper communication between the NodeMCU and the computer.
import requests
import json
import time
import numpy as np
import pyautogui
import math
import threading
import sys
from tkinter import messagebox
NODEMCU_IP = '192.168.31.212' # Replace with your NodeMCU IP
MAX_RETRIES = 5
MOUSE_SENSITIVITY_X = 10.0
MOUSE_SENSITIVITY_Y = 10.0
GYRO_THRESHOLD = 0.01 # Minimum gyro movement to register (eliminates jitter)
ACCELERATION_FACTOR = 2 # Exponential acceleration for faster movements
# Movement modes
MODE_ABSOLUTE = "Absolute" # Direct mapping of tilt to screen position
MODE_RELATIVE = "Relative" # Tilt controls velocity, not position
MODE_HYBRID = "Hybrid" # A mix of both with auto-centering
# For UI
UPDATE_INTERVAL = 25 # milliseconds (faster updates)
# Global variables
is_paused = False
is_running = True
show_debug = True
mouse_pos = {"x": pyautogui.position()[0], "y": pyautogui.position()[1]}
movement_mode = MODE_RELATIVE # Start with relative mode by default
# Flex sensor readings
flex_angle = 0
flex_raw = 0
# Debug variables
last_data_time = 0
fps_counter = 0
fps = 0
# Smoothing buffers
# Create UI
root = tk.Tk()
root.geometry("700x580")
# Style configuration for a more modern look
style = ttk.Style()
style.configure("TButton", padding=6, relief="flat", background="#ccc")
style.configure("TLabel", padding=2)
style.configure("TFrame", padding=5)
global is_running
is_running = state
if not state:
root.destroy()
sys.exit(0)
def toggle_pause():
global is_paused
def toggle_debug():
global show_debug
if show_debug:
else:
debug_frame.pack_forget()
def change_movement_mode(mode):
global movement_mode
movement_mode = mode
status_var.set(f"Mode: {movement_mode}")
# Update radio buttons
mode_var.set(mode)
# Clear movement history when changing modes
accel_history[axis].clear()
gyro_history[axis].clear()
root.update()
# Reset baselines
# Collect samples
# Progress bar for calibration
progress = ttk.Progressbar(status_frame, length=200, mode="determinate")
progress.pack(pady=5)
for i in range(calibration_samples):
data = fetch_data()
if data:
# Update progress bar
progress["value"] = (i + 1) / calibration_samples * 100
root.update_idletasks()
time.sleep(0.1)
progress.destroy()
# Update settings display
threshold_var.set(GYRO_THRESHOLD)
acceleration_var.set(ACCELERATION_FACTOR)
# Reset position to current mouse position
global mouse_pos
current_x, current_y = pyautogui.position()
mouse_pos = {"x": current_x, "y": current_y}
global MOUSE_SENSITIVITY_X, MOUSE_SENSITIVITY_Y, GYRO_THRESHOLD, ACCELERATION_FACTOR
try:
GYRO_THRESHOLD = float(threshold_var.get())
ACCELERATION_FACTOR = float(acceleration_var.get())
status_var.set("Settings updated")
except ValueError:
messagebox.showerror("Invalid Input", "Please enter valid numbers for sensitivity values")
def fetch_data():
global fps_counter, last_data_time, fps
# Calculate FPS (Frames Per Second / Data updates per second)
fps_counter += 1
if current_time - last_data_time >= 1.0:
fps = fps_counter
fps_counter = 0
last_data_time = current_time
try:
connection_status_var.set(f"Connected ({fps} FPS)")
else:
connection_status_var.set(f"Error: HTTP {response.status_code}")
time.sleep(0.5)
connection_status_var.set(f"Connection error: {type(e).__name__}")
time.sleep(0.5)
return None
def apply_acceleration(value, threshold):
"""Apply non-linear acceleration to movements for better control"""
if abs(value) <= threshold:
return 0 # Filter out minor movements
# The further from threshold, the more acceleration applies
sign = 1 if value > 0 else -1
normalized = abs(value) - threshold
return sign * (normalized ** ACCELERATION_FACTOR)
global mouse_pos, flex_angle, flex_raw
return
# Get flex sensor data if available
if "flex" in data:
flex_angle = data["flex"]["angle"]
flex_raw = data["flex"].get("raw", 0)
# Check if click is detected from NodeMCU
if data["flex"]["click"]:
pyautogui.click()
# Apply calibration
calibrated_gyro = {
# Apply smoothing to reduce jitter
# Calculate mouse movement based on the selected mode
dx, dy = 0, 0
if movement_mode == MODE_ABSOLUTE:
# Absolute mode: Map tilt angle directly to screen position
# This is similar to your original code
# Update position
# When MODE_RELATIVE is selected, replace the existing relative mode implementation with this:
elif movement_mode == MODE_RELATIVE:
# Get current gyroscope values
gyro_x = calibrated_gyro["x"]
gyro_y = calibrated_gyro["y"]
# Initialize movement deltas
dx = 0
dy = 0
# Only process movement if above threshold to eliminate drift
# This is key to keeping cursor in place when sensor is in neutral position
if abs(gyro_y) > GYRO_THRESHOLD:
# Invert Y axis for natural movement direction
dx = -gyro_y
if abs(gyro_x) > GYRO_THRESHOLD:
dy = gyro_x
# Apply the requested amplification factor (200.0) to make movements more responsive
# This makes small tilts translate to meaningful cursor movement
amplification_factor = 200.0
# Apply amplification and sensitivity adjustments
if abs(dx) > 0:
dx_sign = 1 if dx > 0 else -1
dx = dx_sign * ((abs(dx) * amplification_factor) / MOUSE_SENSITIVITY_X)
if abs(dy) > 0:
dy_sign = 1 if dy > 0 else -1
dy = dy_sign * ((abs(dy) * amplification_factor) / MOUSE_SENSITIVITY_Y)
# Apply exponential scaling for larger movements
# This gives finer control for small movements while allowing fast traversal with larger tilts
if abs(dx) > 1.0:
dx = dx * (abs(dx) ** (ACCELERATION_FACTOR - 1.0))
if abs(dy) > 1.0:
dy = dy * (abs(dy) ** (ACCELERATION_FACTOR - 1.0))
# Get current actual mouse position
# Update position with calculated movement
new_x = current_x + dx
new_y = current_y + dy
# Update stored mouse position
mouse_pos["x"] = new_x
mouse_pos["y"] = new_y
else:
# Normal movement when tilted
dx = dx * (12.0 / MOUSE_SENSITIVITY_X)
dy = dy * (12.0 / MOUSE_SENSITIVITY_Y)
mouse_pos["x"] = current_x + dx
mouse_pos["y"] = current_y + dy
# Move the mouse
# Update UI
if show_debug:
mouse_label.config(text=f"Mouse: X: {mouse_pos['x']:.0f}, Y: {mouse_pos['y']:.0f}, Mode: {movement_mode}")
flex_label.config(text=f"Flex Sensor: Angle: {flex_angle:.1f}° (Raw: {flex_raw})")
def update_ui():
if is_running:
try:
data = fetch_data()
if data:
except Exception as e:
error_msg = str(e)
if len(error_msg) > 50:
error_msg = error_msg[:50] + "..."
status_var.set(f"Error: {error_msg}")
finally:
main_frame = ttk.Frame(root, padding="10")
main_frame.pack(fill=tk.BOTH, expand=True)
# Status frame
status_frame = ttk.LabelFrame(main_frame, text="Status")
status_var = tk.StringVar(value=f"Mode: {movement_mode}")
status_label = ttk.Label(status_frame, textvariable=status_var, font=("Arial", 12, "bold"))
connection_status_var = tk.StringVar(value="Initializing...")
connection_status_label = ttk.Label(status_frame, textvariable=connection_status_var)
connection_status_label.pack(pady=2)
click_label.pack()
# Debug info
debug_frame = ttk.LabelFrame(main_frame, text="Sensor Data")
if show_debug:
flex_label = ttk.Label(debug_frame, text="Flex Sensor: Angle: 0.00° (Raw: 0)")
flex_label.pack(anchor=tk.W)
# Movement mode selection
mode_frame = ttk.LabelFrame(main_frame, text="Movement Mode")
mode_frame.pack(fill=tk.X, expand=True, pady=5)
mode_var = tk.StringVar(value=movement_mode)
mode_info = {
MODE_ABSOLUTE: "Tilt directly controls cursor position (return to neutral brings cursor to center)",
MODE_RELATIVE: "Tilt controls cursor movement speed (return to neutral stops cursor where it is)",
MODE_HYBRID: "Combines features of both modes for more natural control"
for idx, mode in enumerate([MODE_RELATIVE, MODE_ABSOLUTE, MODE_HYBRID]):
mode_radio = ttk.Radiobutton(
mode_frame,
text=mode,
variable=mode_var,
value=mode,
command=lambda m=mode: change_movement_mode(m)
mode_radio.grid(row=0, column=idx, padx=10, pady=5, sticky=tk.W)
# Add tooltip-like description
ttk.Label(mode_frame, text=mode_info[mode], font=("Arial", 8), foreground="gray").grid(
row=1, column=idx, padx=10, pady=(0, 5), sticky=tk.W
# Settings
settings_frame = ttk.LabelFrame(main_frame, text="Settings")
settings_grid = ttk.Frame(settings_frame)
settings_grid.pack(fill=tk.X, expand=True, padx=10, pady=5)
# X sensitivity
ttk.Label(settings_grid, text="X Sensitivity:").grid(row=0, column=0, sticky=tk.W, padx=5, pady=2)
sensitivity_x_entry = ttk.Entry(settings_grid, textvariable=sensitivity_x_var, width=8)
sensitivity_x_entry.grid(row=0, column=1, sticky=tk.W, padx=5, pady=2)
ttk.Label(settings_grid, text="(Lower = more sensitive)").grid(row=0, column=2, sticky=tk.W, padx=5, pady=2)
# Y sensitivity
ttk.Label(settings_grid, text="Y Sensitivity:").grid(row=1, column=0, sticky=tk.W, padx=5, pady=2)
sensitivity_y_entry = ttk.Entry(settings_grid, textvariable=sensitivity_y_var, width=8)
sensitivity_y_entry.grid(row=1, column=1, sticky=tk.W, padx=5, pady=2)
ttk.Label(settings_grid, text="(Lower = more sensitive)").grid(row=1, column=2, sticky=tk.W, padx=5, pady=2)
# Gyro threshold
ttk.Label(settings_grid, text="Gyro Threshold:").grid(row=0, column=3, sticky=tk.W, padx=5, pady=2)
threshold_var = tk.StringVar(value=str(GYRO_THRESHOLD))
threshold_entry = ttk.Entry(settings_grid, textvariable=threshold_var, width=8)
threshold_entry.grid(row=0, column=4, sticky=tk.W, padx=5, pady=2)
ttk.Label(settings_grid, text="(Deadzone)").grid(row=0, column=5, sticky=tk.W, padx=5, pady=2)
# Acceleration factor
ttk.Label(settings_grid, text="Accel Factor:").grid(row=1, column=3, sticky=tk.W, padx=5, pady=2)
acceleration_var = tk.StringVar(value=str(ACCELERATION_FACTOR))
acceleration_entry = ttk.Entry(settings_grid, textvariable=acceleration_var, width=8)
acceleration_entry.grid(row=1, column=4, sticky=tk.W, padx=5, pady=2)
ttk.Label(settings_grid, text="(Higher = more acceleration)").grid(row=1, column=5, sticky=tk.W, padx=5, pady=2)
# Apply button
# Control buttons
buttons_frame = ttk.Frame(main_frame)
debug_btn = ttk.Button(buttons_frame, text="Hide Debug" if show_debug else "Show Debug", command=toggle_debug)
# Connection info frame
conn_frame = ttk.LabelFrame(main_frame, text="Connection")
conn_frame.pack(fill=tk.X, expand=True, pady=5)
conn_frame_content = ttk.Frame(conn_frame)
conn_frame_content.pack(fill=tk.X, expand=True, pady=5)
ttk.Label(conn_frame_content, text="NodeMCU IP:").grid(row=0, column=0, sticky=tk.W, padx=5)
ip_var = tk.StringVar(value=NODEMCU_IP)
ip_entry = ttk.Entry(conn_frame_content, textvariable=ip_var, width=15)
ip_entry.grid(row=0, column=1, sticky=tk.W, padx=5)
def update_ip():
global NODEMCU_IP, DATA_URL
NODEMCU_IP = ip_var.get().strip()
connection_status_var.set(f"Connecting to {NODEMCU_IP}...")
# Clear data history when changing connection
ttk.Button(conn_frame_content, text="Update IP", command=update_ip).grid(row=0, column=2, padx=5)
ttk.Label(conn_frame_content, text="URL:").grid(row=1, column=0, sticky=tk.W, padx=5)
ttk.Label(conn_frame_content, text=DATA_URL).grid(row=1, column=1, columnspan=2, sticky=tk.W, padx=5)
# Keyboard shortcuts info
shortcuts_frame = ttk.LabelFrame(main_frame, text="Keyboard Shortcuts")
shortcuts_frame.pack(fill=tk.X, expand=True, pady=5)
shortcuts = """
• ESC: Emergency stop (move mouse to top-left corner)
• SPACE: Toggle pause/resume (when window is focused)
• C: Recalibrate sensor
• 1/2/3: Switch movement modes
ttk.Label(shortcuts_frame, text=shortcuts, justify=tk.LEFT).pack(anchor=tk.W, pady=5)
# Bind keyboard shortcuts
def handle_key(event):
if event.keysym == "space":
toggle_pause()
elif event.keysym == "c":
start_calibration()
elif event.keysym == "1":
change_movement_mode(MODE_RELATIVE)
elif event.keysym == "2":
change_movement_mode(MODE_ABSOLUTE)
elif event.keysym == "3":
change_movement_mode(MODE_HYBRID)
elif event.keysym == "Escape":
# Emergency stop - move to corner to trigger failsafe
pyautogui.moveTo(0, 0)
# Debug message to confirm key press was detected
print(f"Key pressed: {event.keysym}")
root.bind_all("<Key>", handle_key)
# Function to force focus for keyboard events
def ensure_focus(event=None):
root.focus_set()
print("Focus set to main window")
# Bind focus event to main window and all child frames
root.bind("<FocusIn>", ensure_focus)
main_frame.bind("<Button-1>", ensure_focus)
# Call focus explicitly at startup
root.after(1500, ensure_focus) # Set focus after a short delay
def initialize():
global mouse_pos
# Get current mouse position at start
root.after(1000, lambda: root.focus_force())
# Start updating UI after a short delay
# Show a welcome message
messagebox.showinfo(
"Gesture Mouse Control",
"Welcome to Gesture Mouse Control!\n\n"
"• The default 'Relative' mode lets you control cursor speed with tilt angle\n"
"• Click 'Calibrate' while holding the sensor in neutral position\n"
"• Use the flex sensor for clicking\n"
"• Adjust sensitivity settings if movement is too fast or slow\n\n"
"Press OK to start"
try:
initialize()
root.mainloop()
print(f"Critical Error: {e}")
sys.exit(1)
The idea here is that when you bend the flex sensor, its resistance changes, and the Node MCU can detect that change through the A0 pin. In our Python code (running on the computer, not the Node MCU), we’ll use that data to trigger a right-click. Oh, and in the demo, you’ll see me tilt the breadboard to move the cursor (thanks to the MPU 6050) and then bend the flex sensor to do a right-click.
Step 7: Upgrading to a PCB for a Pro-Level Setup
In this step, we will securely mount all the components onto a PCB board to ensure a durable and professional finish.
Choosing the Right PCB
I am using a dotted PCB board for this project, but if you prefer a more professional approach or are not confident working with a dotted PCB, I have designed a custom PCB and attached the Gerber file for you to use.
Cutting the PCB to the Right Size
  1. Take a dotted PCB board and cut it to the following dimensions:
  2. Width: 35mm
  3. Height: 85mm
Soldering the Components
  1. Start by soldering a female header onto the PCB board. This will allow easy mounting and removal of the NodeMCU.
  2. Follow the circuit diagram carefully to solder all connections. Ensure that each joint is properly secured to avoid loose connections.
  3. After soldering, thoroughly inspect the board for any loose or shorted connections.
Final Assembly
  1. Once you have verified the connections, carefully mount the NodeMCU and the flex sensor onto the PCB.
  2. Make sure all components are firmly in place and aligned properly.
Powering the Circuit
  1. If you want to use an external power supply, you can provide an input voltage between 5V to 12V.
  2. In my setup, I am using 7.4V by connecting two 18650 batteries in series.
  3. Ensure that your power source is properly connected and regulated to avoid damage to the components.
Important Note:
The final code was uploaded to the NodeMCU in Step 5, so there is no need to upload any additional code in this step. Simply power up the setup and test the functionality!
Gerber File Download Link: https://drive.google.com/drive/folders/1TtHFboqVVIowimIzlU4iElT07Ryaj24y?usp=sharing
Step 8: Working Video and Tutorial
Congratulations! You’ve successfully built your Gesture Control Mouse using Node MCU, MPU 6050 AND Flex Sensor. Demonstration video of this project can be viewed here: Watch Now
Thank you for your interest in this project. If you have any questions or suggestions for future projects, please leave a comment and I will do my best to assist you.
For business or promotional inquiries, please contact me via email at Email.
I will continue to update this instructable with new information. Don’t forget to follow me for updates on new projects and subscribe to my YouTube channel (YouTube: roboattic Lab) for more content. Thank you for your support.
