Introduction: Get Wax Out of Carpet
Oops!
You spilled some wax, and it's not even your carpet. Whether from burning candles or making your own lip balm, getting wax on the rug is a major bummer. Plus it means someone's going to be pretty ticked at you, and you definitely won't be getting your deposit back.
Maybe you've tried scraping, soaking, or even cutting out the offending wax stain. But I'm here to show you a much faster, simpler, gentler way to treat your wax-soaked fibers.
And yeah, this works with your clothes too!
Step 1: Gather Your Weapons
- Paper towel
- Iron
Step 2: Remove That Blotch!
You've probably figured out the rest by now!
But if you're need some help piecing it together, don't worry! That's why I'm here.
Heat your iron to an appropriate setting for the fibers of your carpet.
If you're in an industrial space, it's probably got a lot of polyester or plastic or some such thing in it, and the highest setting is going to melt those fibers! (Don't worry Eric, I totally didn't do that . . . It's fine. Really. Just trust me!) So set it as high as it can go without doing more damage!
Place your paper towel over the offending stain, and apply the iron to the towel. Let it sit for a few seconds, and check out the towel. If you've got a bunch of wax marks on the towel already, reposition it.
Repeat these steps until all of the wax has been absorbed by your paper towel.
Step 3: Revel in the Miracle You've Just Performed
And don't tell your boss/Mom/landlord!
63 Comments
3 months ago
This article content is really unique and amazing.This article really helpful and explained very well.
Thanks for sharing a very nice blog post amazing.
I love this idea. Thank you so much for sharing!
10 years ago on Introduction
Works good but be careful because the heat ruins the backing of the carpet. Use a plain old ice cube and pull it off. Rub wax with ice cube and pick up chunk of wax, boom done. Works good to get gum out of stuff too.
Reply 3 months ago
I let the wax completely harden on my carpet and tried to pick it out. It DID NOT WORK at all. I couldn't pick out anything. Ironing on low with a paper towel is the way to go. You might be onto something re: gum though. :)
3 months ago
1 year ago on Introduction
We knocked over a bright red Christmas candle on to light beige carpet. Using an iron and almost a roll of kitchen towel, I cannot see anything of the mess which we had before. Unfortunately, we didn't take before and after shots - I wish we had to show just how easy and effective this is. Thank you for posting!
2 years ago
My girlfriend drank 2 bottles of prosecco and put her finger in the candle to make a little river of wax down the side, which went all over our carpet. She cried a bit, then we saw this tip and it saved our relationship! Thank you internet.
3 years ago
Just moved into an apartment. Brand new carpet, but there was still a funky smell in the bedroom closet, so I lit a vanilla candle and let it work for a while. Went to move it to a different location and spilled wax. It was a small spot, but greasy on my brand new carpet.
Luckily I found this. Used paper towels and an iron on "2" setting, and finished up with carpet cleaner.
The spot is gone. Thank you.
4 years ago
As an alternative--if you happen to have a heat gun in your toolbox/garage you can simply warm the wax and dab at it with paper towel/rags once it heats up a little. I would imagine a hair dryer on a high setting might work too, but maybe take a few extra minutes. I just cleaned a fairly large stain this way, took all of 10 minutes. I put the heat gun on a low-medium setting, somewhere in the 350-400' range, on regular household carpet. Big red wax stain on cream carpet--totally gone, and wax had hardened overnight.
4 years ago
Thank you !!!! Just spilled 6 oz of wax on my new living room carpet. This method worked amazingly. Easy and Fast.
5 years ago
I managed to knock a pillar candle that had been burning for hours (so about a half cup of wax) onto a thick, nubbly cable knit wool carpet. This technique got every bit of wax out. If it works for that it will work for anything.
Reply 4 years ago
I knocked over a full wax melter on my bedroom carpet. It's green and smells really good, but I can't have wax on my floor, soo
4 years ago
I don't have an iron so I'm slowly using my 1" barrel curling iron and it works really well!
4 years ago
Stupid question but how do I know when its gone from melted wax to just a wet spot on my shirt? Dark green shirt with virtually colorless wax (It just had to be sugar cookie!)
4 years ago
I spill wax on my carpet at a place i rent i will try anything to get the wax up only thing i dont hve an iron so im gonna use a poy of boiling water cant hurt but jope it works tho. My fault i need to fix this
Reply 4 years ago
Sry suppose to be a pot of hot water nd hope it works out
5 years ago
OMG! Thank you thank you thank you! I spilled an entire candle that had been setting on a warmer, you can't even tell it now! I also done the same thing to a spot I covered with furniture 2 YEARS AGO, YOU ARE AWESOME!
5 years ago
This worked damp wash rag or towel. So thankful i found this post.
5 years ago on Introduction
That works so well!!
5 years ago
WE SPILLED A BUNCH OF BROWN WAX ON WHITE CARPET.
We tried the paper towel method, no good.
The damp towel and warm iron method worked perfectly! Carpets are brand new! LIKE NOTHING EVER HAPPENED!
