Getting Started With Arduino and Visual Basic 2008
Intro: Getting Started With Arduino and Visual Basic 2008
Making of Gui is always one of the interesting and enjoyable thing in controlling system. in this instructable we are going to learn making of Gui with visual basic 2008 and arduino .So here we start With Led
Part to be Required
1.LED
2.220 ohm Resistor
3.Arduino board
STEP 1: Bread Board Circuit
Arduino Program
int led= 2;
void setup() {
Serial.begin(9600);
pinMode(led, OUTPUT);
void loop() {
if (Serial.available())
int Blinkdata = Serial.read();
if (Blinkdata=='a')
digitalWrite(led,HIGH);
else if(Blinkdata=='b')
digitalWrite(led,LOW);
STEP 2: Making of Visual Basic Form
Make Form as Shown in Image with the help of
2 buttons,
Label,
2 Combo box,
1 Serial Port
STEP 3: Visual Basic 2008 Source Code
Define IO Libraries
Imports System.IO
Imports System
Imports System.ComponentModel
Imports System.Threading
Imports System.IO.Ports
Public Class Form1
Dim myPort As Array
Shared _continue As Boolean
Shared _serialPort As SerialPort
Exit Button
Private Sub Exit_Click(ByVal sender As System.Object, ByVal e As System.EventArgs)
Application.Exit()
End Sub
Connect Button
Private Sub Connect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Connect.Click
SerialPort1.PortName = ComboBox1.Text
SerialPort1.BaudRate = ComboBox2.Text
SerialPort1.Parity = IO.Ports.Parity.None
SerialPort1.StopBits = IO.Ports.StopBits.One
SerialPort1.DataBits = 8
SerialPort1.Open()
Button2.Enabled = True
Button3.Enabled = True
End Sub
Disconnect Button
Private Sub Disconnect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Disconnect.Click
SerialPort1.Close()
Button2.Enabled = False
Button3.Enabled = False
End Sub
Commport Combo box
Private Sub ComboBox1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ComboBox1.SelectedIndexChanged
If SerialPort1.IsOpen = False Then
Else
MsgBox("You cant change comm Port While its open!", vbCritical)
End If
End Sub
Baudrate Combo box
Private Sub ComboBox2_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ComboBox2.SelectedIndexChanged
Else
End If
End Sub
Form Load
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
'Partial Load
myPort = IO.Ports.SerialPort.GetPortNames()
ComboBox2.Items.Add(9600)
ComboBox2.Items.Add(38400)
For i = 0 To UBound(myPort)
ComboBox1.Items.Add(myPort(i))
Next
End Sub
LED on
Private Sub ON_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
SerialPort1.Write("a")
End Sub
LED OFF
Private Sub OFF_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
SerialPort1.Write("b")
End Sub
End Class
STEP 4: Modify Form and Visual Basic 2008 Program to Control Robokits Wireless 865-869 MHz Robot
Part to be required
Robokits RF 865 Mhz Robot
Cp2102 USB to Uart Module
http://robokits.co.in/development-boards/interface...
Define IO Library
Imports System.IO
Imports System
Public Class Form 1
Public Class Form1
Dim myPort As Array
Connect Button
Private Sub Connect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
SerialPort1.Open()
Button4.Enabled = True
Button5.Enabled = True
Button6.Enabled = True
Button8.BackColor = Color.Green
End Sub
Disconnect Button
Private Sub Disconnect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
SerialPort1.Close()
Button8.BackColor = Color.Red
Button4.Enabled = False
Button5.Enabled = False
Button6.Enabled = False
End Sub
Combobox 1 Commport
Else
MsgBox("you cant change port while connected!", vbCritical)
End If
End Sub
Combobox 2 Buadrate
Else
End If
End Sub
Form Load
myPort = IO.ports.serialport.getportnames()
Next
End Sub
Exit Button
Private Sub Exit_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button7.Click
Application.Exit()
End Sub
Private Sub Button8_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button8.Click
End Sub
Private Sub Label1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label1.Click
End Sub
About Button
Private Sub ABOUT_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles UA.Click
MsgBox("THIS SOFTWARE IS CREATED BY ROBOTICS INDIA FOR MORE INFO PLEASE VISIT WWW.ROBOKITS.CO.IN")
End Sub
Movement Buttons
Private Sub Button5_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles Button5.KeyPress
SerialPort1.Write("D")
End Sub
Private Sub Button6_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles Button6.KeyPress
SerialPort1.Write("A")
End Sub
Private Sub Button4_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles Button4.KeyPress
SerialPort1.Write("S")
End Sub
Private Sub Button3_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles Button3.KeyPress
SerialPort1.Write("W")
End Sub
End Class
STEP 5: Assembling Robokits WIRELESS RF SERIAL LINK 865-869 MHZ ROBOT.
STEP 6: Upload Program to Robokits Roboduino Board
#include //Include motor shield lib into arduino lib
for motor related functions.
#define Duration 100 //Duration for exiting the loop
DCMotor Amotor(1); // Creating instances for Motor 1
DCMotor Bmotor(2); // Creating instances for Motor 2
long previousMillis; // variables to scan for time alterations
long currentMillis;
byte byteRead; // variable to store Serial data
void setup()
Serial.begin(9600);
void loop()
currentMillis = millis(); //note the current time
byteRead = Serial.read(); //Read Serial data
previousMillis = currentMillis;
if(byteRead == 'W' || byteRead == 'w' ) // Compare serial data
Forward(255);
else if(byteRead == 'S' || byteRead == 's')
Backward(255);
else if(byteRead == 'A' || byteRead == 'a')
Left(255);
else if(byteRead == 'D' || byteRead == 'd')
Right(255);
else if(currentMillis - previousMillis >= Duration) // If no signal is
Stop();
void Forward(unsigned char Speed) //Forward Function
Amotor.run(FORWARD);
Bmotor.run(FORWARD);
Amotor.setSpeed(Speed);
Bmotor.setSpeed(Speed);
void Backward(unsigned char Speed) //Backward Function
Amotor.run(BACKWARD);
Bmotor.run(BACKWARD);
void Left(unsigned char Speed) //Turn Left Function
void Right(unsigned char Speed) //Turn Right Function
void LMF(unsigned char Speed) //left motor Forward
void LMB(unsigned char Speed) //left motor Backward
void RMF(unsigned char Speed) //Right motor Forward
void RMB(unsigned char Speed) //Right motor backward
void Stop(void) //All motors stop to stop the robot
Amotor.setSpeed(0);
Bmotor.setSpeed(0);
// delay(10);
STEP 7: Download Zip File
Download Source code and All related Documents
