Introduction: SUPER CHEAP PEN SYRINGE
Materials needed:
* pen/approximately 1cm wide
* 1ml syringe/with needle if you are a true spy
* sharp knife or small saw
* and yourself
* and yourself
Step 1: Taking the Pen Apart
1.) take out your pen and unscrew everything
2.) take out all the insides of the pen
3.) keep the pen apart
HELPFUL TIP: you may need to use a sander or drill to hollow out the center of the center tube of the pen!!!DO NOT DRILL THE SCREW PART!!!!
THE NEXT SCENES WILL INCLUDE A DIFFERENT PEN....DONT PANIC!!!
Step 2: The Syringe
1.) take a blade and cut off the two grips at the end so your syringe will fit in the pen
2.)cut it so it is round so it wont get stuck in the pen
Step 3: Putting It Together
1.) take the end out of the syringe
2.) put the front end into the pointed end of the pen
3.) screw or slide the tube onto the front point of the pen
4.) take the back end of the syringe and put it through the top
5.) put clip if the syringe pump fits/if not its ok it will still work
CONGRAGULATIONS ON YOUR NEW SYRINGE PEN!!!!!!!
CONTACT ME AT hunter@thebuchs.us OR MESSAGE ME
