Giant Button Project
Intro: Giant Button Project
This is my makey makey project, when you press on it, a noise is produced. This project creates a fun way for people to interact with each other. It also creates a collaboration between the button-presser and the computer.
DISCLAIMER: Photos are not completely accurate to the instructions.
STEP 1: Cut Squares Out of Your Sheets
Cut all of the sheets into squares, most of them should all relatively be the same size. Then cut another square inside the cardboard, making a cardboard outline of a square. Cut the card stock paper to fit inside the square hole you have made in the cardboard square.
STEP 2: Poke 2 Wires on Opposite Sides of the Foamboard
Poke 2 wires through the foamboard so that the tip of the wires are visible on the other side. Then tape the tips of the wires to the foamboard so they do not slip.
STEP 3: Layer a Sheet of Foil on Top of the Foamboard
On the side of the foamboard where the two tips of the wires poke out, lightly tape a sheet of foil over it so that the face of the foamboard is completely covered.
STEP 4: Create Your Touch Pad
Tape the smaller piece of Card Stock paper to the cardboard rectangle so it fits in the middle.
STEP 5: Put Everything Together
Place the touch pad you have just created on top of the foil and lightly tape them together.
Penolopy Bulnick 1 year ago
