Giant Slip and Slide
Intro: Giant Slip and Slide
Here is a tutorial on how to create a giant slip and slide. It takes a couple of friends and me about 3 different nights after work to complete. As with anything, the more you do it the better you will get at it. Truth be told, the end product is so awesome, I would still help put it together even if it took 50 times longer to set up.
STEP 1: Things Needed
This is a list of the things needed to build this giant slip and slide. Hopefully if you are trying this you have most of these items hanging around somewhere, otherwise it will be an expensive ordeal.
A pond with a big hill leading right into it
A few free nights and 1 free day
Steel posts. We used 24 of them
Post pounder
100x20 ft 8mil thick sheet of plastic
A couple old blocks of wood (2x8, 2x6, anything will really work)
4 metal stakes or rebar about a foot long
2 round bales, or something else heavy to keep the plastic from sliding (a tractor to move them too)
Tires, we used somewhere around 20
A whole bunch of wire
Drill and 3/8" or 1/4" drill bit and a drill bit big enough for your stakes/rebar
120 feet of 2 inch PVC pipe
9 straight PVC connectors
2 90 degree PVC connectors
1 cap for the end of the 2 inch PVC pipe
Pipe cleaner and glue
Sump pump
2 inch hose from pump to PVC pipe and 2 hose clamps
Hose from pump to pond
A bush hog helps too
Post pounder
Sump pump
STEP 2: Lay Out PVC Pipe
After doing this a few times, we discovered that the plastic will last longer if we bush hog the grass underneath where the plastic will be placed about 5 days before laying the plastic down. The real building of the slip and slide starts about 3 or 4 nights before the big day. We begin by laying out the PVC pipe. We just pick a starting point (make sure it is close enough for your piece of plastic to reach the pond) for the slip and slide and go from there. There is no shame in rolling out the plastic to make sure. We also leave room at the top of the slip and slide for the round bales we will place on the plastic in a later step. We start at the top and lay the pipe 50 feet down on each side or the 20 feet used at the top. It doesn't have to be perfect since the water will have no problem reaching the plastic while it shoots out of the PVC, but remember that you are going to have to pound posts where you lay the pipe, and a little distance between where you are sliding and steel posts won't hurt.
STEP 3: Pound Posts and Wire PVC
After the pipe is in place, we can begin pounding posts. We start up at the top of the slip and slide and put two posts in on each side of where the plastic will be. Don't worry about leaving much space between the plastic and the post for safety, because there will be a hay bale in front of the post to take care of that. Then we will take another post and wire it to the one you just pounded. This makes the post about twice as high as it was previously. From there, just move down about 10 feet and pound another post in. Before you get too far down the hill, it is a good idea to wire up the PVC, just to make sure your posts are in the right spot. Don't forget to throw tires over the post before you wire the PVC to it. To do this we had one of us hold the pipe up at the top, one hold it at the next post, and we wired from there. Keep on moving down the hill on each side, and on the side where water is not coming in, you need to clean and glue a 2 inch PVC cap on the end. Now we are done with both sides of the slip and slide, and we can move onto the middle.
STEP 4: PVC at the Top of the Slip and Slide
Setting up the top of the slip and slide is a little different than the sides as far as the PVC pipe goes, because of the 20 foot gap between the posts at the top compared to the 10 foot gap down the sides. When water starts running through the top pipes, it is going to get heavy, and that's where these extra steps come in. First off, we clean and glue the 2 PVC pipes together with a connector piece, as well as both the 90 degree pipe connectors. Now we pound a post about 8 feet away from the top steel post at a 90 degree angle from the slip and slide. This will serve as an anchor to the two top posts on either side of the slip and slide. Then we wire the PVC pipes that we just glued to the two top posts. With both sides wired, we will give a little tug and take a piece of wire from the anchored post to the top of the post where we just wired the PVC pipe. We will repeat that on both sides to complete half of what we need to do for the top of the slip and slide. Next, we will tighten wire onto the top of the top post that we strung our anchor wire to and spiral our wire around the PVC pipe at the top clear across to the other side of the slip and slide. Then we will wire that up tight.
STEP 5: Roll Out Plastic
Now we are ready to roll out the plastic. Once that is done we can throw some more tires down the sides to keep the wind from picking up the plastic and causing trouble. This is where the blocks of wood and stakes and hay bales come in. Here, we will drill holes big enough to punch the stakes through the block of wood and then we'll pound the stakes through the plastic right underneath where we will place the round bale. We decided to add this step after the plastic was still sliding out from underneath the bales. Then we can place the bales on the plastic at each top corner.
STEP 6: Bring on the Water
With everything going except the water, it is time for us to drill some holes in the PVC pipes. We don't really have any "best" method for this, so we will just take a 1/4" or 3/8" drill bit and drill holes in the pipes. You can always add holes, but it is more difficult to patch them up, so just remember that when completing this step. With the holes drilled, we can get the sump pump and hoses lined out. Now came one of the more challenging parts for us. We had to prime the sump pump, while the water we are pumping is lower than the sump pump. After a while, we will get it to go, and we can connect the pipe to the bottom of the PVC that doesn't have the cap on it. We can tighten up the hose clamps and not worry about priming the sump pump any more.
STEP 7: Slip and Slide!!
Now, we can crank up the sump pump, and watch the water run up one side of the PVC, across the top, and down the other side. Get your swimming trunks on and start sliding!
55 Comments
YoChuck 12 years ago
mitchells365 8 years ago
That is what I would have done if I had a pond to use... I'm surprised this guy didn't, all you would need is some plywood ramp sides cut with a jigsaw, a 2 by 4 frame and some foam mats to put underneath the plastic for padding
You stole my idea... This is what I was planning to do using similiar supplies, 2" PVC Pipe, a sump pump, a bunch of 2 by 4's and plywood, foam mats pool noodles, and a bunch of screws. It was going to be more like an actual waterpark slide though with a high up starting platform and a smallish hill...
Ricardo Furioso 12 years ago
adntigger710 9 years ago
You should definitely ask about the kind of billboard it is before you buy. My roommate works for a billboard company, I'm actually looking at a bunch right now. They have different weaves. I think "posterflex" might be a thicker weave, and you def don't want that. The tighter the weave, the better. I'm a photographer and I use them for backdrops (the white or black side). I always head into the shop with her to pick out the best ones. You want the smoothest surface possible. I'd ask for a closeup pick -- sliding on a thicker weave would probably hurt a ton!
treehouse24 10 years ago
slavik1 12 years ago
World's widest slip and slide -
http://www.youtube.com/watch?v=aF_OQuu3Ap0&feature=relmfu
frollard 14 years ago
In your materials used, it might be important to note you're referring to 8 "mil" (thousandths of an inch) plastic not 8mm plastic, as 8mm is nearly a centimeter thick...
looks like a LOT of fun!
awsumpawsum 14 years ago
awesomekitteh 13 years ago
yanksguy 12 years ago
Valster 12 years ago
I'll bet any amount that the lawsuit comments are all from Americans who live in large cities.
Can't we all just have a little fun?
Spokehedz 12 years ago
Yeah. I think a couple of country boys making the most out of a hill near a pond is going to be A-OKAY.
AwesomeKitteh - If you take 5 days to make this, and then hurt yourself--what were YOU thinking during those 5 days? I don't think any judge would hold someone on the internet responsible for a project that takes 5 days to assemble and then they hurt themselves. Plus, they tell you to use the innertube.
mscalora 12 years ago
Title: WHAM-O Backyard Water Slides Are Dangerous For Adults And Teenagers
See: http://www.cpsc.gov/cpscpub/prerel/prhtml93/93076.html
-Mike
spark master 12 years ago
Then those who said mind your buisiness as they gleefully slid down the track only to wake up in a fracture ward want to sue. They may need to since they can no longer work or play or barely breathe on their own.
I think this is a great inspired instructable, but the gent who posted th ewarning brings a great point. You are responsible and it will be your fault. If you cause your kid to be a quad or die , it is your fault. And no one should be able to sue, cause the danger is always there, and you chose to do it or let your kid do it.
We had a neighbor lose his house over a pool accident. On LI a pair of idiot parents ignored medical advise and let their kid with HCM play football on a team. Now training on a team is NOT the same as on a sandlot team. His heart popped on a beautiful day. The parents said"we couldn't stop him from playing he loved it he was 13" ghee not really. To be on a team around here you mus have the cash for the togs and be driven everywhere, school teams require a MD clearence, (just change MD's to get a clean one).
In HCM one wall gets huge in the heart. Uder stress of activitiy it closes the output valve and the pressure simply over inflates the chamber and the heart pops .
In my opinion they needed to be brought to trial, except they provided a darwinian approach, not unlike the situation discussed here, leading to a very stiff sentence. A dead child (their own) and the knowledge that they could easily have prevented it. A trial with conviction and complete dropping of sentence would have been the smack from society to wake them and other idiots up.
Caveat Emptor and be careful what you wish for.
I have many many many scars all earned from stupid things and a few from things outside my control, as a kid and adult. I never blamed another for my stupidity.
still a great instructable, but maybe one might rethink this before doing it. The idea from the US goverment is that size/age matters. Little kids do not have the issues the adults and teens do.
It is a sheet of plastic, with water sprayed on it. That's all that it is. What you want to do with it afterwards is entirely up to your own judgement.
I don't want to live on this planet anymore.
chrissysno 12 years ago
I have to keep reminding myself that there is something in these people, that has been lost. The childlike wonder of finding out new,( and a lot of times) better ways to do things.
These people obviously HAVE to constantly prove to themselves that they are smarter than all of us. We poor fools, who like to take things in stride and just enjoy sharing knowledge for its own simple state, rely on these people to save us from our stupid selves.
I don't know how I made it to the age of 50, without these people.
Now I think I'll go jump on a slip and slide and have some fun!
Hang in there, buddy!
Needless to say he stopped talking to me as well as a couple of other guys cause we all said the same thing. And until he retired he never spoke to that neighbor again and his kid never ever played with him again.
But I stil lthink this is a great instructable, but perhaps only for kids cause kids under 12 years old are more flexible. At my age I might try this once or twice cuz it looks like its a hoot, but I doubt I would do it after that. (my chioce). I take my kids to amusement parks and only go on a very few rides, cause when I get off them I feel my joints, and I am not that old. But I assume the risk, and thus I don't . Pity now that I can afford rollers I seldom go on them anymore. We love Hershy Park and Canobie lake,(New England).
have a slidey day (safely)
Nope, home made COMPLETELY SAFE AND IN NO WAY INFRINGING ON COPYRIGHT plastic sheeting laid down with water spraying over it.
