Introduction: Girls Shorts Made From Boxers
A while ago I found a pair of boxers at the gap. Now normally, I would buy this pair and where them as pajamas, however this pair was easily 4 sizes too big for me.There was only one pair of this print, and they were under three dollars, so I decided to see what I could do with them.They sat in my scrap fabric bin for a while, until I figured out what to do. This was super simple to do, and took me only an hour.
pair of too big boxers
needle + thread
scissors
cotton cord
Step 1: Sewing Up the Slit
This was relatively easy, I simply basted along the slit in short tight stitches until it was all closed.
Step 2: Puncturing the Waist Band
In my pair, the waist band was a thick piece of elastic, sewn on the top and the bottom, with about an inch of empty space in between. This was the perfect channel for a draw string waist. the back had a seam which interrupted the channel, so I made two slits on each side of the seam. Then I made two slits in the elastic on each side of the front slit.
Step 3: Threading the Drawstring
I cut some cotton cord to the length of the waistband, in it's full width. Then I attached a safety pin to each end of the cord. I threaded each of the ends through the slits on each side of the back seam. Using the safety pins, I worked each of these to the holes in the front. Once I pulled them out the slits in the front, I tied off each side with a knot.
Step 4:
Here is a before and after of the shorts. they are pretty wide legged, and high waisted, so they ended up looking a little 50s inspired.
