Give Your HDTV the Philips Ambilight Effect on the Cheap
Intro: Give Your HDTV the Philips Ambilight Effect on the Cheap
I love those Philips Amiblight HDTVs - you know, the ones with the rear backlight that projects colours onto the wall behind the TV? Not only does it look pretty, but if you're gaming or watching a film in low-light conditions then the backlight reduces eye strain.
I do suffer from eye strain. Mainly because I watch DVDs or game with only a lamp on. After an hour I'll start to get a headache. Problem is that the lights in my living room are too bright.
I'm perfectly happy with my Hyundai 32" HDTV and don't want to shell out for a Philips one... so it's Ikea to the rescue and you can get a similar effect for under $40.
STEP 1: Get the Lighting From Ikea
OK, first up we need lighting. The lighting is called TRETTIOEN which comprises of 4 LED light strips, the mains adapter and some bendy wires for corners. It's available from all good Ikea stores.
I live in the UK where it costs ã21 for the set which come in White, Green or Blue.
STEP 2: Mounting the Switch
The lighting strips come with a mains adapter that has a rocker switch for easy access. If (like me) you've got your TV standing on a TV cabinet, simply use some of the leftover adhesive strips and stick it to the rear of the cabinet. It'll allow you to easier manage the cabling as well as turn the lights on/off with ease.
Here I've got the switch running parallel to (but lower than) the top of the cabinet. It's out of view but I can easily reach it.
STEP 3: The Finished Result
That's it! Please bare in mind that due to cabling issues, my cabinet isn't stood right against the wall. If it were then the light would be a lot brighter... plus I took really quick shots with my camera :)
STEP 4: The Finish #2
Here you can see it in action with a Wii. (Please note that the lights are much brighter... due to the light from the screen and no flash on the camera, the light is a little dimmer than it really is - but you get the idea).
Now there you go - it took 20 minutes and trust me, it does reduce eye strain. I prefer to play Wii Sports or Xbox Live with only a lamp on and this lighting system does help.
32 Comments
pwiest1 12 years ago
The use of an Arduino to control a string of colored LEDs has been pretty well documented -- search "ambilight arduino clone" or look up Amblone. The only problem is, most of these projects were designed for ambient lights on your monitor, based on software that runs on your computer. If you want to do this for a cable box or a Playstation, for example, you'd have to run the display through your computer via a capture card.
aptilight 13 years ago
i developed ambilight for dvi,hdmi,display port
thanks
ThreeWestCreative 15 years ago
snowpenguin 15 years ago
JshDav 15 years ago
baneat 15 years ago
Padlock 15 years ago
pepitosbazzeguti 15 years ago
Sermos 16 years ago
LasVegas 17 years ago
fastm3driver 16 years ago
LasVegas 16 years ago
A link to it would have helped...
Looks pretty cool... It would be fun to play with.
therealcmj 17 years ago
babylonfive 16 years ago
dmacrae 17 years ago
clippership 17 years ago
psturgeon 17 years ago
