Give Your Table Top Drill Press MORE POWER!
Intro: Give Your Table Top Drill Press MORE POWER!
To make this project I was fortunate enough to have access to a full featured machine shop at City College of San Francisco, anyone remotely interested in machine work should seek out their local community college and take a class, before budget cuts are the end of them.
If you aren't as lucky, you can make this project just with another drill press, or without any machine tools if you use an arbor adapter, or a NEMA 48 motor.
STEP 1: Gather Parts and Tools
A second drill press with vise and vee block, or metal lathe
Metric socket set up to 24mm (though 15/16 seemed to work for t
2mm Allen wrench
19/32 drill and 5/8" hand reamer (Just a 5/8" drill will do the trick in a pinch)
Gear puller, or plumbing handle puller.
A welder would be very helpful
Vernier Calipers or ruler graduated in 32nds
Medium (14") Channel Lock pliers
Angle grinder with cutoff wheel, and abrasive brush.
Parts you will need:
New Motor you may use a more powerful motor, but if it gets much heavier, you may need to counter balance the press.
New belt This should work for any NEMA 56 mount motors.
New switch (This is probably optional, but being unsure of the amp rating of the stock switch, I elected to pay the additional $4. This will also allow you to run on 220 if your shop is so equipped)
STEP 2: Disassembly
My first suggestion is to take photos from every angle before taking this apart, it also helps to search the manufacturers website or other tool parts websites to see if they have an exploded view that will help in identifying parts. Here is the link for my press:
Parts diagram and replacement ordering info
The only part that technically needs to be removed in order to complete the upgrade is the motor, unfortunately, in order to lift the motor off of its mounts, you must remove the pulley guard, and in order to remove that, you must remove the idler pulley.
The drive pulley removes easily, there is a set screw in the second smallest ring, loosen that with the 2mm allen key, and pull it off.
The idler pulley (the one above the chuck) is a bit more difficult, it is press fit on a tapered shaft, then secured with a 24mm (15/32) left hand nut.
To remove the nut place the channel locks on the smallest ring of the idler pulley with the jaws opening to your right, and turn the nut CLOCKWISE with the appropriate socket. Remove the nut completely.
The pulley must then be pulled off of the tapered spindle. To do this, I used a steering wheel puller, but would work much better to use a handle puller used for plumbing, or ideally a gear puller.
All three of these work the same way, a center screw presses down, while hooks pull up on the pulley. When you do this, the chuck will be pushed down, rather than lifting the gear up. To prevent this, raise the table up against the chuck. A few turns and the pulley should release.
To remove the pulley guard, unscrew the switch plate and remove the spade connectors to free the wires. There are four screws that hold the guard down and two clips that hold the wires in place. Remove all of them, and lift off the guard.
To remove the motor, unscrew the two hinge bolts and lift the motor up.
STEP 3: Modify the Pulley
You can avoid this step if you find a motor with a half inch shaft, like this one. A NEMA 48 motor will have a half inch shaft, and likely have a small enough distance from base to spindle to avoid the need to modify the pulley guard. Or you can find an adapter to reduce the shaft to 1/2".
First, remove the set screw from the pulley.
I used a lathe, and if you have access, this is much easier. Simply mount the pulley, small end out, in a three jaw chuck, making sure that it is mounted square to the headstock. The easiest way to make sure is to put a straight, 1/2" rod in the pulley, and spin the chuck by hand, watching that the end of the rod does not wobble.
Set the RPM about 300, mount a 19/32" drill in the tailstock, and drill all the way through. No cutting fluid is necessary, as cast iron is self lubricating. Then, mount a chucking reamer in the tailstock, cut the speed down to 200, and run the reamer through. If you don't have a chucking reamer, I suggest using a dead center in the tailstock to keep the reamer aligned.
If you don't have a reamer, you may use a 5/8" drill, but you will sacrifice some accuracy.
If you only have a drill press, follow these steps:
Place a 1/2" drill or straight round bar in the drill press chuck. Clamp the pulley in a drill press vise and vee block, sitting loose on the table of the press. Bring down the 1/2" guide-rod to align the pulley below it. Before releasing the guide, clamp the drill press SECURELY in place, then move the guide up and down to make sure that you are accurately centered below the chuck. Then follow directions to drill and ream as above.
STEP 4: Modify the Motor Mounts
The most logical thing to do, rather than try and bend 1/8" steel accurately was to re-use the hinge part of the mounts.
The first thing was to figure out what the distance was between the hinge mounts and the spindle. I placed the old motor on the edge of a table, and measured from the edge of the table to the side of the spindle, then subtracted .250 to bring me to the center. (see image)
I then cut off the side of the motor plate with the mounts, preparing it to be attached to the new motor flange.
There are three alignments that matter when attaching it to the new flange:
First, the distance from the hinge to the motor spindle should be as close as possible to the original measurement. Second, the top of the hinge should line up with the top of the motor body. and finally, when mounted, the spindle must be vertical.
To do this, I marked a location for the hinge on the new flange using the same method of measuring as above, and clamped it in place with a vise grip. I then mounted it on the press with the pulley guard set in place, and eyballed the minor adjustments.
Removing it from the press, but with the clamp still in place, weld the two pieces together. It is a good idea to weld two spots and then double check alignment before completing the weld.
If you don't have the ability to weld, drill two holes for 1/4" machine screws and tighten well.
The final adjustment was to weld or bolt on a piece of scrap steel to extend the baseplate on the right side, so that the adjustment bumper will hit.
STEP 5: Reassembly
First the motor, and mounting bolts.
Then the pulley guard
Then the pulleys and new belt. Make sure that the set screw is aligned with the keyway in the motor shaft.
Finally the wiring. If you are replacing the switch, the model mentioned pops right in to the existing opening with no adjustment.
Currently, you cannot close the cover, since the pulley is farther out.
See
11 Comments
tedmich 7 years ago
I opted to put a 1/2hp 90VDC motor on my little HF drill press, it uses an SCR speed control which produces good torque down to ~60 rpm as the speed with only 2 pulleys is usually too high for many operations like a dig hole saw in Al. A 3 pulley mod was un-doable so going DC was easier and cost ~$100 with stuff off Ebay.
AllenT8 8 years ago
I was wondering if the motor could be removed by simply cutting the upper mounting bolt. This saves the trouble to deal with the idler pulley.
Skajam 8 years ago
It looks like it could, and if one were faced with spending money on any one of the gear puller options, it would probably be the best bet. My default mode is not to destroy things unless completely necessary, and I had the steering wheel puller already.
roncody 9 years ago
The other solution that I use is a motor off an old treadmill. My bench top drill press now has 2 1/2 HP and it's variable speed! 1 1/2" holes in 1" plate steel no problem. So is my Bandsaw it now can cut most anything I throw at it. The best part is you can get the treadmills for free on Craig's list and they include the controller. Big plus is they are DC motors so small size and lots of power.
ruisantos10 9 years ago
That's the spirit of DIYing, making something better, spending (much)less then buying a equivalent brand new one. There's no point on that, at least for those who actually use the machine, because for the others it's easier to buy a new one when it doesn't come out of their wallet!
Anyway, great upgrade!I have a similar one that is not very powerfull as well, but haven't had many problems with that yet. But it is possible that soon I'll need to improve it's mechanisms, as it is not very precise.
Good work!
DIY Dave 12 years ago
Quick-tune 11 years ago
shannonlove 12 years ago
When I was kid growing up on isolated farms/ranches in rural Texas, we often had to improvise merely because prior to the internet and fast world wide package shipping, it could take days or weeks to find needed parts and get them installed. Heck, just driving to town and back again could burn most of an afternoon in a critical time window.
When you farm, mother nature is your boss and she doesn't accept any excuses. You get things done on her schedule or you starve. My grandfather and uncle, both of pre-wwII vintage, could improvise like you wouldn't believe. In almost every case, there was a better store bought solution somewhere but we just didn't have the time or money to get it right when we needed it. Even today in the developed world, you can still find yourself in that situation e.g. if you don't come from money, you starve in college.
Besides, saying "Instead of hacking something, just go buy a new X for a few bucks more" leads you to spend a lot of money compounded over time and a lot of projects. Those savings mean you can buy more supplies and tools and do more projects in the long run.
Skajam 12 years ago
First, I had already purchased this press long before coming across a project for which it was underpowered, and it wasn't worth much as a used press, so I essentially would have been throwing away a press that I paid ~$80 for.
Second, when you get past 1/2 (stated) hp, the presses tend to get much bigger. I have a small shop and generally do small jobs, so I wanted to keep it small.
Third, just now, I priced 1/2 to 3/4 hp presses, and they are over $300, so in addition to losing what I spent on the existing press, I would be out more than the $120 or so that this project.
Finally, I enjoy doing projects like this!
Drillbert 12 years ago
abstracted 12 years ago
