Introduction: Glass Bead Earring, Pendent and Ring
Hello, I wanted to make something cheap, simple, quick, yet elegant, from things easily available at craft store or dollar store. Here is a complete set of earring, pendent with ring.
1) Glass bead
2) sequins or sequins rondel
3) rhinestone stickers - these are beautiful, many glittering plastic beads with sticky back
4) soft jewelry making wire - silver, i brought one with eye loop
5) Quick glue
6) Wire cutter / pliers
Step 1: Collect Items to Make One Unit
Two glass beads, one sequins, one wire, rhinestone stickers and quick glue. We can stick two beads, back and forth to the silver plastic sequins. I did tried using a bead only on one side, but it seems unbalanced.
Step 2: Hook the Sequins in the Wire Eye Loop
Step 3: Stick a Glass Bead on One Side of Sequins
Step 4: Stick Second Glass Bead on Other Side
Step 5: Stick the Rhinestone Stickers on Edge of Bead
Step 6: Stick Rhinestone Stickers on Other Bead Edge
Step 7: Bend the Wire and Cut Excess
As you can see, bend the wire to to form a hook at a distance from beads, this allows you to hook it easily.
Step 8: Add Rhinestone Stickers to the Wire Hook
Use quick glue to add rhinestone stickers to the wire hook
Step 9: Use It As a Pendant in a Chain
Step 10: Make a Ring
I was lucky that the flexible wire was long enough, that I made another hole on the sequins and hooked the other end of the wire to it, then in the similar fashion made ring, by sticking rhinestone stickers to it, I added to rows to look more impressive.
Hope you liked it, if so then don't forget to hit like button.
