Glass Block Christmas Decoration
Intro: Glass Block Christmas Decoration
I received one of these as a gift last year, and figured how hard would it be to make one. It was not as easy as I thought but just about anyone can make it with a little caution and safety measures.
Use a glass building block to make a decoration, by drilling a hole and inserting Christmas lights, then add some decorations on the outside of the block.
STEP 1: Prepare to Drill the Glass Block.
Items you will need for this step include:
8 in X 8 in X 3 in glass block (Home Depot)
glass and tile drill bit 1/2 inch
Drill press preferably
Water
Gloves
and Eye protection
Water
Gloves
and Eye protection
STEP 2: Drill Glass Block
Take it nice and slow with this step. The glass can and will shatter if not careful. Make sure that the bit is kept cool by dripping or spraying water on the drill bit as you are drilling. If the glass bock is not clamped, use a towel and glove to hold the block down. Don't want anyone getting hurt.
STEP 3: Clean the Inside of the Block.
The inside of the block will have a lot of glass dust inside once you have finished drilling. It will look dirty, don't worry it will come clean. First use a vacuum to get as much of the dust out as possible. There will be a little bit of dust still clinging to the inside of the block. Use a air-compressor to blow air into the hole. CAUTION: do not allow air pressure to build up inside of the block, IT WILL EXPLODE. That is why I do not have a picture of myself using the air-compressor.
Make sure that you have on gloves in this step as the glass dust escaping the little hole will feel like a sand blaster on your hand.
STEP 4: Insert Lights Into Block.
Use a 50 count light strand, not the sting together kind as you won't be able to insert the plug at the end of the sting. These are hard to find, I found mine at a local CVS store.
STEP 5: Lights On
Once all the lights are in the block, pug them in and make sure that you did not pull a bulb loose and that they light up.
STEP 6: Add Final Decorations
You have a couple of options here. You can use window cling decorations or tie a bow around the block and you are ready to go.
The best way to finish the block would be to use a VersaLaser to etch a pattern on the front of the block. Here the ideas are endless, you could engrave a name on it and use it as a night light.
Good luck and enjoy your Light Block.
39 Comments
mrubesch 14 years ago
sandra.russo1 9 years ago
can a dremel drill be used for these to cut and decorate please
mrubesch 9 years ago
http://www.homedepot.com/p/DEWALT-1-2-in-Diamond-Drill-Bit-DW5578/203298764
Hi what do mean when u say the rigid brand?
mickeymoose703 15 years ago
Hi I'am from Australia were can I get these glass block for crafts please? I'am so exited to try these projects thanks
leannenmeeks 13 years ago
what are the chances of the potpourri off catching on fire? because some of them have wood bits not familiar with these just curious thanks
Zorik 14 years ago
moideux 9 years ago
Hi Zorik, I would really like to try drilling these glass blocks - can you tell me what type and size drill bit you used. Thank you very much :)
Zorik 9 years ago
moideux 9 years ago
Thank you for all that info :) - I'm living in Ireland, but the information you have given me should be sufficient to do a search. Will let you know how I get on, well actually how my dear hubby gets on. I do the craft part lol! :)
Zorik 9 years ago
twighahn 13 years ago
Zen Innovations 9 years ago
Looks very Pretty But the lights won't last. Soo many lights crammed into tight space with no air circulation= FIRE HAZARD!
Mrs Donohue 10 years ago
aireamme 15 years ago
