Glass Bottle Match Holder and Strike
Intro: Glass Bottle Match Holder and Strike
Just a cute little way to hold your matches for use and retro decoration.
STEP 1: What You'll Need
Only a few simple materials.
- I found this lovely little green glass medicine bottle in an antiques shop for just £3, any small bottle will do why not try ebay for cheap options.
- Matches and an old match box with the strike strip
- Scissors
- Rag (optional)
- Glue
- Scissors
- Rag (optional)
- Glue
STEP 2: Adding the Strike Strip
Using your scissors cut out a strip of the striking paper bit of the match box, to the size you want.
My bottle was hexagonal so cut a piece to fit one of the sides.
On another matchbox was a matching brand name so I just cut that out too.
* It's not essential to have a multi-sided bottle, as long as the strike strip is paper you can bend it around any shape.
Using Pritt-Stick or PVA glue the reverse sides and apply to the glass.
Wrap a rubber band around to keep tight and in place while the glue dries - about 5 minutes
STEP 3: Optional Stuffing
The matches I had at hand were too short and didn't poke out the neck so I decided to fill the bottle half way with some material. This can also be done with sand or tissue/coloured crepe paper, but you could always just buy the extra long safety matches.
I just cut the material into strips and stuffed them into the bottle using a pencil, until a point where I was happy with the way they stuck out.
STEP 4: Easy-Peasy
All you need to do now is fill with the remaining matches, remove or cut the rubber band and that's you finished :)
Adds a perfect touch of uniqueness to your house, thanks for reading and feel free to comment
12 Comments
mischka 12 years ago
nbrown66544 12 years ago
Thanks
Bosun Rick 12 years ago
I'm not sure about the safety of allowing the matches to rub against each other as you pour them out to get one to light, any other comments on this issue?
I used safety matches which can't ignite by themselves, only when struck with the phosphorus strip, I think the above are strike anywhere matches (pink heads) which could potentially combust by themselves when moved about.
I'm no chemist so I could be wrong.
newb 12 years ago
musicalbee2003 12 years ago
Orkekum 12 years ago
ejsilver26 12 years ago
Keep up the good work.
polycam 12 years ago
Penolopy Bulnick 12 years ago
