Introduction: Glow Led's Using AC Current(220-250V)
Note :- THIS INSTRUTABLE SHOULD NOT BE ATTEMPTED UNLESS YOU ARE
FAMILIAR WITH THE RISKS OF WORKING WITH MAINS VOLTAGE
To make this project you will need only few components.
And you could make your own led lamp or decorating light and many more things that you can imagine. This project is just an example to how to build the circuit for glowing led's using 220-250v.
Step 1: Components Required.
>Led's (number as ur choice)
> 4007 Diode (4).
> 250v Polyfilm Capacitor (1) .
> 50v (100 uf) Capacitor (1).
> 1000 m ohm Resistor (1).
> 0.220 k ohm Resistor { should be big in size else the curcit would not work }  (1). or something near this value.
Step 2: Adding Diodes.
Place the diodes on the PCB board as shown in the picture.
and follow the image instructions.
Step 3: Adding Resistors.
1st add the 1000 m hm resistor.
Step 4: Adding the LED's.
I added up only 3 leds. You could add more leds as your requirment.
The current flow would be automaticly divided or multiply itself as required.
Step 5: Testing.
The circut is ready to use.
Just plug the wires in the socket and the led's will turn on.
as in the images below.
You can use this example and make more creative things..
Step 6: Implementation.
Using this circuit i created.
>Led Lamp.
>Led Decorative Lights.
You could construct something else using this circuit.
Use Your Brains and start working on it..
