Googly Sound (Looking Back!)
Intro: Googly Sound (Looking Back!)
I saw these beautiful horns (Indian taxi horns, minus rubber bulb) at the market going for $20, I saw the chance for a new kind of sound from my iPhone! The horns on this device look a bit like snails eyes on stalks! If you like this I have created other artefacts which I don't have instructables for but they might give you more ideas. Click here.
STEP 1: The Box!
First find yourself a nice box you want to put the electronics in, the box I chose is quite small as you can tell by the phone on it. Of course there will be plenty of sanding involved and lots of varnishing - I love to use Danish Oil, it takes many more coats to give it a great finish, but it's worth it! This box soaked up the varnish like a sponge, I ended up using 11 coats!
The covering inside used up most of the space inside so I removed this and will keep for a later project!
STEP 2: The Horns!
Find yourself some good brass horns to fit on your box. These I found at the markets in a pretty rough condition, nothing that a bit of TLC can't solve! As you can see they are hand made and come all the way from India, the horn on the left has the makers mark. They are both slightly different from each other so will not look symmetrical.
Cut and polish your horns to suit your enclosure.
STEP 3: Adding the Electronics
I couldn't find an amp small enough in my junk box to fit this box so I went out and bought one, it's only mono....but.....it'll do! Take it apart and rehouse it in your box.
The 8ohm speakers were bought at the same time.
STEP 4: Squeeze Everything Into Your Box
It was a tight fit but as you can see I got everything in!
STEP 5: Making It Look Good (Feminine Style)
All I did was 'pretty up' the box using brass rods, beads and finally putting in the iPhone holder, which I painted gold.
Googly sound has a 1/4" jack socket in the back so you can play your music and sing through Googly sound as well. I am going to plug my guitar into this, I'm sure the sound is going to be amazing. This is a LOUD box!
I hope you enjoy creating your own, it is a conversation starter! If you like this have a look at my iPhonograph.
I've put in a guide to other steampunk creations which are absolutely fantastic! How to Steampunk!
30 Comments
conmac863 12 years ago
One suggestion if I may. They have charging cradles that have a line out so you would not have your cable hanging out the top. You can see the line out port on the picture somewhat. Something like this:
bricabracwizard 12 years ago
faralley 12 years ago
Second, please follow conmac63's advice and swap the cradle.
It will sound way better when you'll use the line out instead of the headphone out.
Because you'll bypass the headphone preamp (which works great when headphones are used, but are not that ripping going to a hifi device)
Compare the two options (headphone out vs connector-line out) and be amazed!
(check out this article: http://beavishifi.com/articles/headphonejack)
Maybe a "LOD" cable can be fitted in the existing cadle so there's little work to be done.
Good luck
cheers !
Something like this? Stainless steel ice-maker tubing.
La_Sweeta_Deeva 12 years ago
SkizMaroo 12 years ago
Did you ever try it as a guitar amp? I was thinking there may be some impedance matching problems unless you ran the guitar thru a stomp box, preamp, mixer, or anything that would bring the guitar signal up to preamp/headphone levels. I would be very interested to know how that worked out.
Very nice job!
Sorry it's taken soooo long to reply, I was hoping to put up a vid demonstrating me playing guitar through the Googly Sound (Just been too flat out busy!) . The volume was good although from mid to the highest volume it was distorted (good for grunge guitar). Through a DI box it sounded great, though you wouldn't use it at a gig.
Thanks for the compliments, I hope you make something like this. I would love to see it.
Cheers,
Bricabracwizard
Horatius.Steam 12 years ago
Greetings from The North,
Horatius Steam
Lindie 12 years ago
vpurcell 12 years ago
tannerpotts17 12 years ago
Winged Fist 12 years ago
Aeon Junophor 12 years ago
I am deeply impressed! Take a bow!
Cheers Aeon Junophor
