Introduction: Granny-Square Christmas Stockings
These, lovely Christmas stocking are easy to crochet and sew together a perfect gift, when filled with candy and stocking stuffers!
Step 1: Materials
- about 4 oz of worsted weight yarn in red and white or other preferred colors.
- scissors
- a size 5.5 mm crochet hook
and some Christmas spirit! :)
Step 2: Making the Squares Round One
The stocking is made of granny squares. which can be replicated by,
Chaining up 4,
slip stitching in the last chain from the hook,
chaining up three
crocheting 11 double crochets into the middle of the circle.
slip stitching into the third chain that you made in the beginning of the round.
Step 3: Rounds Two and Three
to begin round two Chain up three,
put two double crochets in between each stitch from the previous round
slip stitch into the third chain from the beginning.
for round three
chain up three,
put three double crochets in between every set of two from the previous round.
Step 4: Round Four
This round is different because you are adding the corners
as usual chain up three,
then put two double crochets in the space next to your chain.
chain two, and place two more double crochets in the same space.
there is your corner!
put three double crochets in the next two spaces created by the previous round.
add your second corner the same way as before, two double crochets, chain two, two more double crochets.
repeat until the end of the round, slip stitch into the third chain at the beginning.
Step 5: Round Five
Last round!
you are going to repeat round four except instead of double crochets you will use single crochets.
so chain two,
put two single crochets in the chain to space from the previous round's corner.
chain two,
put two more single crochets in the chain two space.
put three single crochets in each of the spaces between the corners.
continue until the end.
slip stitch in to the second chain from the beginning.
Step 6: Make Six Squares
To make the body you will need six squares.
Step 7: Sew the Squares Together
Slip stitch the squares together similar to the picture above.
Step 8: Add the Cuff
To add the cuff of the stocking just do as many rounds of double crochets in white around the top of the body of the stoking.
Homemade Gifts Contest 2017
Fiber Arts Contest 2017
3 years ago
Nice stocking. This would also make a great Christmas themed oven mitt.
