How to Make Great Ricotta Cheese From Whey
Intro: How to Make Great Ricotta Cheese From Whey
This Instructable will show you how to make Ricotta Cheese from the Whey that was left over from the Mozzarella Cheese you already made.
Check out my Instructable for making Great Mozzarella Cheese. You will find it at:
https://www.instructables.com/id/Great-Mozzarella-Cheese/
There are tons of Mozzarella Cheese recipes on the Internet. I checked a lot of them out and perfected my own recipe and made an Instructable for it to make it as easy as possible to make Mozzarella Cheese. It seemed like a lot of the recipes I found either left out a step or didn't explain it very well.
Unlike Mozzarella, Ricotta Cheese seems to be almost 100% foolproof.
There are recipes out there to make Ricotta from milk, but this lets you get everything possible out of that gallon you used for the Mozzarella.
Things you will need:
1. Leftover Whey
2. Large bowl
3. Reusable coffee filter. You can also use a clean cloth.
4. Large Strainer that you used for the Mozzarella
5. Small bowl to put the final product in
1. Leftover Whey
2. Large bowl
STEP 1: Heat the Whey
Pour the Whey back into your pot and heat back up to from 200 degrees to boiling. The temperature here is not critical and you don't have to do it slow. Just be VERY careful not to let it boil over. It WILL make a mess.
Some people suggest letting the Whey set out overnight. I have tried that and also started it right away and haven't noticed any difference.
Turn the heat off and let it cool down some. After a little while, if there is stuff floating on top stir it so that it sinks to the bottom. This will help later so you can just strain most of the liquid and it won't clog up the filter so fast.
STEP 2: Strain the Whey
Once the Whey has cooled down to 140 degrees or less, either use a ladle or pour your Whey through the coffee filter. NOTE My pot has a lip on it, so it pours fine like the picture. If yours does not have a lip, it might not pour like that.
Most of the Ricotta is at the bottom of the pot so pour slowly and do not shake up the pot and you should be able to pour most of the Whey through. If the filter gets full just transfer it into another bowl for now, rinse the filter and continue pouring the Whey through until finished. Once the Whey is drained it can be thrown out, used in soups, used to feed animals, used to water plants etc. Didn't know you could get so much out of a gallon of Milk did you?
This step can also be done with a clean cloth. When it fills up, just grab up the 4 corners with one hand and squeeze the Whey out with the other hand. Continue to strain.
STEP 3: Drain
Once you pour it all back into the filter just let it drain for a while until all the liquid is out of it. It could take a while depending on the size of the holes in the filter.
STEP 4: Thats It!
There it is. Told you it was easy. Try it. It should have a slightly sweet taste and boy is it good. As you can see I got about six and a half ounces. it varies ever time.
Enjoy
Enjoy
72 Comments
yochani91 3 years ago
jenniferlynn70 3 years ago
SaraRomans 5 years ago
JesseC76 7 years ago
ata1anta 7 years ago
NanT3 8 years ago
My mozzarella goat cheese has an after taste. Am I doing something wrong? The end product looks good but the taste is not good. What makes the goaty taste, or maybe it is a sour milk taste. Please help, I am about to give it up after 3 tries
gwen.guyn 8 years ago
I found out a few things..
1. Get out all the whey. Seems to contribute to that odor.
2. Add some flavor! Herbs, garlic, etc. We liked rosemary, garlic, basil. Made Italian toast, toasted French bread, tomatoes, fresh basil, thin red onion, back in the oven for a few. Used on pasta, gratins, casseroles.
3. After forming into a tight ball, I left it wrapped in the tied cheese cloth, in the back of my refrigerator for months. Air circulating all around that way. Got harder than most brick style cheeses. Grilled cheese!
4. Making ricotta/cottage cheese with rennit was easier, quicker and we used it faster in lasagna and Mac and cheese, on top of chili, etc.
Hope you're still interested and this is helpful.
MichaelS379 8 years ago
I'm assuming you have the same problem my ex-wife had when she was making goat cheese. You may have a yeast culture in the environment of your kitchen. When ever she tried to make goat cheese in our kitchen the end result was always the same , a cheese product that had a stronger odor than limburger and was inedible. I suspicioned it had to do with her not using proper cleaning procedures in her milk parlor and that she might have been bringing the yeast into the kitchen on her milking utensils. Hope this is helpful and that you find a solution.
PYPERLYNN 9 years ago
I made Mozza today for the first time. It is amazingly good. I made it without a microwave, I used a double boiler and got the internal temp to just over 135 for 5 mins. Was very easy to do just takes an extra 15 mins or so. Texture is just so smooth. Best of all. My wife is so happy on a long weekend, anything could happen now!!!!!!!
TonyC9 9 years ago
So, made the Fresh Mozz......came out AWESOME! Tried to make Ricotta out of left over Whey, followed this recipe exactly. Got absolutely NOTHING! Had used 2 Junket Rennet tablets to make the Mozz....might the Rennet have pulled out so much of the milk fat there was nothing left for the Ricotta?
lynmiller 9 years ago
Works great! I've tried this with whey from mozzarella, which yielded a little ricotta, and with whey from queso blanca which yielded much more. My friend, a veteran cheese maker, tells me you can tell by the color of the whey about how much ricotta it will make. The whiter, "milky looking" stuff has more cheese left in it. I make mozzarella once or twice a week, so I am still making ricotta from that whey as well.
I ended up letting it heat to boiling, and letting it cool thoroughly. I'm also straining through several layers of cheesecloth instead of a coffee filter, mostly because I don't have patience enough to stand there slowly pouring gallons of whey through a filter. I figure I lose just a little ricotta, but the time saved is worth it to me. OOH, I mix the ricotta with onion flakes, or red pepper, and salt, and we eat it with crackers. Yummy! and it saves me from making lasagna every week.
Thanks lots!
nell.matthews.31 9 years ago
My lab mate, a Polish scientist, was showing me how to make pirogi. She insisted that we needed unpasteurized milk but none could be found. Finally, we settled on whole milk (which is skim milk with fat added back to 4% milk fat), buttermilk, vinegar, and some plain yogurt, all to acidify the milk. We incubated at room temp overnight. I suspect that, since all you are trying to do is to denature (coagulate) milk casein and similar proteins, just vinegar and heat to 180°F would have worked. In reading further, I learned that the whey protein that remained after filtering the 'cheese' out could be further denatured by higher heat, 200°F to make ricotta (means recooked). The yellowish liquid left after that filtration was high in riboflavin, hence the color. It's all chemistry. I imagine that in the distant past, it was more an art. Anyway, her cheese pirogi are divine.
rusti1 9 years ago
New here. Well, I kind of cheated :) and have 'whey' from a greek yogurt machine maker, and was looking for a recipe for it. Saw this and would like to make ricotta cheese. Just wondering if it's the same whey?
swiesner1 9 years ago
Ok here goes, my first shot at Mozerella tonight and I will try the ricotta tomorrow and the gjetost probally the following day. This looks to be a fun project!
eculley 9 years ago
our cheese turned out beautiful the very first time. we used fresh goat milk. made cheddar cheese first and used the whey to make the ricotta. I really appreciate this instructable. thank you.
jasonlough 11 years ago
geosurfrider 11 years ago
For Adjustments for Pasteurized or Homogenized Milk:
You can always mix nonfat milk and heavy cream (both are usually not homogenized) together to reach the same fat content in whole milk. The ratio is 1 pint of heavy cream for each gallon of nonfat milk.
If you are using store-bought milk and find that your curds are too soft, you can add calcium chloride. To use this, dissolved the calcium chloride in nonchlorinated water and add to the milk, prior to coagulation. Chlorine can affect the functionality of certain coagulants, so its is best to stick with nonchlorinated or distilled water.
Hope this helps! Happy Cheese making!
mjohnson84 10 years ago
