Introduction: Greenhouse From Old Windows
This is a brief guide on how I took some old windows from houses they where tearing down in my neighborhood and turned them into a small greenhouse in my back yard. I collected the windows over the course of a year and a half and the build took about 3 months, spending one day a week on it. I spent about $300 for the lumber for the frame and screws, caulk, latches, etc. That's almost 10% of what a greenhouse kit would cost. The size I built was 7 ft high x 10 ft deep x 6 ft wide. But the size of your greenhouse will depend on your windows and the time you want to put into project.
Step 1: Collect Windows and Plan Two Pair of Equal Sides.
Look for old windows and save every one you get. After you have many, lay them out and play a game trying to make two pairs of "walls" both the same height. Two to three inches won't matter as you can cover the difference with wood. Smaller holes will need to have glass cut for them or filled with something else. Keep in mind that one end will need a door and the other a hole for a fan.
Step 2: Create a Frame
Using the windows you chose as a guide, construct a frame for each wall. Use good lumber for this, as it is the structure that holds all the weight. I used all 2 x 4s for the studs and 4 x 4s for the corner posts. Choose a length that allows at least 14" of the stud to be placed in the ground for support.
Step 3: Brace Walls
Start placing the walls up, bracing well so they don't fall over. Be sure to check that they are level.
Step 4: Make the Foundation Secure
To avoid certain problems with pesky city building permits, I built the structure shed height and did not pour a concrete foundation. Instead I buried cinder blocks to stabilize the 4 x 4 corner posts. They keep it from moving an inch.
Step 5: Screw on Windows
I used some nice coated deck screws to affix the windows to the frame. This will allow for easy removal and replacement if any break. This side facing the camera has the empty window for a fan.
Step 6: Get a Floor
I was able to find someone who needed rocks removed from their yard. Using rocks or stones is good for two reasons: good drainage and heat storage.
Step 7: Build the Roof
This was tricky. I ended up getting siding from an old shed someone had torn down. Any material you use, look for lightweight and waterproof material. Be sure that you have some that will open for ventilation, at least 20-30% of your floor space. You can get by with less if you use a fan for ventilation. Also build the slant roof with at least a 4 degree pitch, otherwise rain may not sheet off well.
Step 8: Add the Shelves and Fans.
I found an old picnic bench table and this fan and shelf in the garbage. I figured I can use them in my greenhouse and save them from a landfill.
Step 9: Caulk and Paint
Use a good outdoor caulk and seal all the cracks and holes between windows. Paint the wood to protect it from the weather.
Step 10: Update: Spring 2009
The winter this year was especially bad near me. We had several feet of snow weeks on end. Luckily, I had already emptied the greenhouse and removed the roof panels in late November. I live in a zone 5 area. During the last month I brought out an electric heater to keep the temperature more consistent overnight.
This year I was able to obtain a large picture window and decided to install a windowed roof this spring. It will allow much more light in and therefore heat. I used the same deck screws to affix the windows to the roof frame I already had built. For the roof vents, I took two windows and screwed them together. I found old door hinges and used a piece of PVC as a brace. I added a screw holding it to the frame as a cotter pin. Lastly, In case a huge gust of wind came along and tried to yank open the windows, I nailed a small chain to the frame and window to prevent the window slamming backwards onto the rest of the roof.
I also modified the south facing bench. It connects to the frame on one end and still uses cinder blocks on the other. This will hopefully allow me to utilize the space inside better. It's filling quickly!
Now that the roof will allow so much light through, cooling will be a greater issue this summer. I may place some of the old panels back up in July/August to reflect some of that light. I also have obtained some reflecting fabric.
Lastly, I think in the future, I will completely rebuild the roof, using the windows for a gable type structure. It will force me to use some sort of poly material to cover up the gable ends. The current pitch of the roof is not enough to slope water off the windows completely.
Step 11: Edit: Fan Window
I was unhappy with having to remove the fan/vent window and having to prop it against something while cooling the greenhouse during the day. The frame was already designed to fit the window into it. I decided to have it slide up and be held in place. I started by salvaging some hinges from an old entertainment center. They are the kind that sit completely outside the door. Plus these had a unique shape that fit around a right angle. This allowed the wooden "stops" to swing in place and hold the window up while I was venting or when the fan is in place. Across the frame I nailed some boards to hold the fan window against the frame. Lastly, I found an old pulley and fastened it to the window so I can pull it up easily.
Step 12: Spring 2010 Roof Vent Upgrades
Had a major score! A local community greenhouse was torn down and replaced. I was able to get some great parts. Here is a picture of the new window system. It originally opened the windows on the side of the greenhouse. The wheel is turned and rotates the gear attached to the pipe opening the windows. Makes opening and shutting easy. While every window now must be open at the same time, I can control the angle at which they are open.
Also pictured is a gutter claimed from the trash. The hinge side of the roof windows always leaked profusely. The gutter catches the water and stores it in a bucket for easy watering.
Step 13: Spring 2010 Shading
Bought secondhand some rolling shades which are working great. They easily roll up and down the south facing wall while not taking up too much room.
Step 14: Winter 2012
Here is the greenhouse in a mild winter. I overwinter many potted perennials inside. To insulate the roof, I stretch a sheet of poly across the top to keep out the drafts. Last October, 2011, I repainted both the inside and out. All the wood is doing well. I hope that, with care, the greenhouse will last over 10 years. It has changed the way I garden, making my back yard much more productive.
8 People Made This Project!
- Tegridyfarms made it!
- wendstorm47 made it!
- CsGreenhouse made it!
- MikiD67 made it!
See 4 More
206 Comments
19 days ago
Does not look like there is any response from the people that we need answers from here. Am I wrong?
Question 19 days ago on Step 5
I want specifics on screwing the windows into the frame…please & thank you!
8 months ago on Step 14
I like the framing, it's is nice and solid and independent of the windows, so it will hold up better over time, and doors and windows are more likely to keep opening properly. Changes and improvements can be made without stressing the old windows, which might have cracked glass or made gaps appear. Good job.
1 year ago on Introduction
Thank you!! I love this idea!!
2 years ago
Here's a blogpost about the greenhouse I made in 2017: https://cheryllyda.blogspot.com
Reply 2 years ago
Nice job Cheryl!
4 years ago
Beautiful! So appreciate you providing updates and your innovation sir :)
Reply 2 years ago
nice one
3 years ago
You Sir have inspired me to built this. Thank you so much for the updates as well.
Question 4 years ago on Step 8
What if you don't have electricity except by an extension cord. How do you power the fan?
Answer 3 years ago
Maybe a solar panel. I've been told harbor freight carries inexpensive ones.
6 years ago
Someone commented that a cement floor should be put in, but as was stated in the directions - City approval is required in most places, to put a structure on a cement floor so he used cinder blocks to put the posts in. I suppose he could have also put some cement into the bottom of the blocks, so wood would not touch ground.
As for the lead paint - that was only used on windows of a certain era, correct? Getting windows of a later era should stop that being an issue.
I like the up-cycling of the windows, stones, and old greenhouse parts - what an Awesome amount of re-purposing items that others no longer want/need. Talk about "one man's trash is another man's treasure"!!!!
Reply 5 years ago
That's what I was thinking. Sink the cinder blocks in the ground a bit, place your 4x4 posts in (square them up) and pour cement into the hole. I think I'll lay ground cover then grab some patio stones that come on sale and use that as a floor. Maybe use 4x4s along the bottom outside edge of the structure as well, be a good, solid base I should think? Then frame away...I'm still trying to figure out what to use for 'glass' as old windows seem to be all the rage now, they're expensive!
Reply 4 years ago
Hello,experience told me that wood doesn't like to be cast in concrete, unless you're absolutely sure that it will always be dry ... If you pour small stones, Peebles around the post and squeeze them (stamping), they'll keep the post in place safely, but will drain every drop of water away. Put a round shaped stone at the bottom of the post hole, firmly stamped, so the post doesn't touch the soil. The shades I built with this system are over 10 years old ... It also works for bigger structures : for holes until 3 feet's deep, and posts over 7 inches diameter, and 12 feet high ! In this case, fill up the hole with stones that you smash down with an iron bar, for example, one after the other. So, ready to start your salvage home ? ;-)
Reply 5 years ago
yes - as new windows get more expensive, more & more people are turning to recycling companies to get their windows. And if they have an older house these would keep the "flavour" of the older home. Triple paned windows are not only expensive but don't match homes of older eras.
I would want to know where the recycling companies exist that don't charge an arm & a leg for old, recycled windows! They're becoming increasingly rare!
Reply 5 years ago
....or you could do what we did. There is an abandoned (repo'd by the bank actually) house next door that was built in 1900. We bought it to demo for the lot. I'm scraping EVERYTHING I can out of that house before the bulldozer and backhoe come. Windows, doors, (for a greenhouse build project) brick basement walls (for a grill pit, later) Anything I don't use and is worth $ to get out, i'm having a reclamation company come get it and pay me for the pleasure :)
Reply 6 years ago
to reply only to the foundation part of this convo. My guy poured an 1' wide x 2' deep footing of my footprint and put the future 4x4 post braces in. Done.
Reply 6 years ago
and, you are so right about the trash to treasure. My Windows were all donated and boy! did I Dig through peoples barns at their "garbage" and I now I have wonderful,local,vintage windows!
4 years ago
How could I do this with a bunch of half round windows ? I got a bunch of the half round ones given to me. Looking for a plan to use them for a greenhouse.
5 years ago
Please know that the cover photo of an all window greenhouse is not the one I, OnaFarina, built. Scroll down and see mine after it was built. It is stick built and large and awesome with a tall roof, but is still wrapped mostly wrapped in plastic and there are photos of what windows I had installed when I wrote the post.
