Gridding a Picture... Make Any Image Bigger, Smaller, or Copy It.
Intro: Gridding a Picture... Make Any Image Bigger, Smaller, or Copy It.
I am going to give you the basics and with some practice you can do some amazing drawings.
Below is an image one of my middle school students did of me.
STEP 1: Getting Started
Here is what you will need:
Picture or printed image. (For this we will use an 8"x10" printed image)
Pencil
Eraser
Big piece of paper (for this it's 18"x24")
Ruler
Straight edge (long ruler or stick or yard stick)
Start by gridding you 8"x10" image.
1. Starting in the corner of the image and moving across the top, side, bottom and other side make a mark every 1".
2. Your marks on the top and bottom of the image should line up. Same with the sides
STEP 2: Drawing the Grid
Do the same thing from side to side.
This will create a 1" grid over your image
STEP 3: Letters and Numbers
And numbers down the side.
Note: that "1" & "A" are the same square!
STEP 4: Grid the Big Paper...
On your big piece of paper, starting in the corner, make a mark every 2" across the top, down the side, across the bottom and up the last side.
Using the straight edge, stick or yard stick to connect the makrs from the top and bottom.
Connect the marks from the sides with the ruler.
All your lines should be parallel.
*(It's the same as the little paper.... your just doing 2" grid rather than 1" grid)
ABC's & 123's... Across the top of your big paper put a letter in each box...
Down the side put a number in each box. "1" & "A" are in the same box.
When you are done you will have a big paper with a 2" grid.
STEP 5: One Square at a Time...
Now you are going to draw one square at a time.. that's the trick. Anyone can do this and it turns out really cool.
Start in square 1A.. whatever is in that square draw it in square 1A on the big paper...
Then move to square 1B... 1C... one square at a time.
The trick is to draw in the big square... whatever is in the same little square... one at a time.
I am currently working on this drawing and will post the images when I am done.
*(I have included some presentations that I have made that might help)
14 Comments
amberf2386 4 years ago
skobella 2 years ago
ronald.ferreira.39 6 years ago
even though all rulers are 1inch width apart the wooden ones have a coper edge on top that bends on the ends away from the middle which is why grids are crooked
Nelson NoelP 8 years ago
ronald.ferreira.39 8 years ago
i saw a photo of you drawing a grid the beginning inch is not at the edge of the paper .
good job
xokiimm 8 years ago
bellinghammakerspace 8 years ago
Make a mark down each edge of the paper... every inch. Draw straight lines connecting the marks. Then do it on top and bottom, connect lines. It's all about the squares. Dosn't matter how big or small as long as you have the same number of squares on the drawing paper and the picture.
ronald.ferreira.39 9 years ago
i can't make straight lines don't know why just neve ever could
Practice. Make a mark every inch down each end of the paper. Connect the marks and draw the line with a ruler. It takes practice.
SavannahL1 8 years ago
bellinghammakerspace 9 years ago
Make one mark every inch across the top starting in the corner. Then do the same thing across the bottom. Then each side. Connect the marks and your lines should be straight.
