Introduction: Kaas
This is an instructable that helps you to make gripping a tennis racket.
It is not to hard so you should do it.
PS: Kaas is lekker
Step 1: Step 1:
First you have to look if you have an grip already on your tennisracket.
If you done that you have to get it off.
First you have to look for the little tape and get it careful off.
If you done that you can now get the old grip off from the default grip. If you done that you can go to the second step.
Step 2: Step 2:
Now you have to get all the materials.
You have to get 3 things: The racket, the grip, and the little black tape.
It doesn't matter which colour you have but I chosen for purple.
Step 3: Step 3:
Now you can start with the grip.
You have to first get the beginning point from the tape and you have to look for the plastic that protects it.
If you have the protected plastic you can put the first little beginning on the default grip.
Step 4: Step 4:
Now you can only do this if you done step 3.
Now you are going to take the grip on the racket.
If you have the beginning done you can grip it right over.
Now you should have the grip to the end.
Step 5: Step 5:
you should now have step 1 2 3 and 4.
If you have the grip to the top you can now carefull get the little tape.
The little tape have to half over the grip and half on the racket.
you have to do that because other wise the grip can't stay on the grip.
Step 6: Step 6:
If you have done all these things your are almost done.
You can look if everything is good and if you accept it, it is done!
PS: Kaas is lekker.
Safe and Secure Challenge
4 years ago
Welcome to Instructables. Thanks for sharing with the community.
